| | Thread Tools | Search this Thread |
![]() | #1441 | |
Senior - BHPian Join Date: Sep 2005 Location: Back in the HOOD near you!
Thanked: 33 Times
| ![]() My friend is using Petro-Canada Semi-Synthetic. He told me to use that. According to him they are good and it uses synthetic base oil for the Synthetic Blend Oil. Quote:
![]() | #1442 |
BHPian Join Date: Jun 2007 Location: bangalore
| ![]() Is it necessary to use engine flush again after using synthetic oil? |
![]() | #1443 |
| ![]() Which is the best synthetic oil... shell helix or castrol edge. i m using mobil 1 and its time for oil change. |
![]() | #1444 |
BHPian | ![]() |
![]() | #1445 |
BHPian | ![]() the synthetic oils from total have been gaining quite a reputation on the global scene and they are now available in india. this is surely a must try. Also check with manufacturer. i am using agip semi synthetic in my uno 15W40, and i can honestly feel a much smoother acceleration after switching to it, the engine feels a lot more energetic. this has been observed only after about 2 changes. long run synthetic is better. my honest suggestion is use any regular mineral oil and change it every 5K kms. this should be more than enough. |
![]() | #1446 |
BHPian | ![]() |
![]() | #1447 |
BHPian Join Date: Sep 2007 Location: Bombay
Thanked: 25 Times
| ![]() I just bought 8 litres of Mobil 1 from Opera House @ 950/- per litre. |
![]() | #1448 |
Thanked: 25 Times
| ![]() Shell Oils are no longer available from their Petrol Pump. :( |
![]() | #1449 |
Senior - BHPian | ![]() OK folks time for oil change presently am usig Magnetec and my car has done 55k kms... SO firstly can i go for synthetic oil now? If so Helix or Mobil 1 or anything else?? i want to go for 5W-50 Mobile do we get the same grade in Helix?? Thanks folks |
![]() | #1450 |
Senior - BHPian Join Date: Jan 2008 Location: Poona
Thanked: 105 Times
| ![]() ^^^No reason why you can't go for fully synth if your engine is in good shape and you want to spend the $. Any special reason why you want to use 5W50? It will be too thick for most modern cars. |
![]() | #1451 |
BHPian | ![]() |
![]() | #1452 |
Team-BHP Support ![]() | ![]() Nope, an engine flush is useful to remove dirt / deposits from the engine as well. Even when using the exact same type of oil! |
![]() | #1453 |
BHPian | ![]() |
![]() | #1454 |
Thanked: 105 Times
| ![]() ^^^Yes, there is - NEVER! ![]() |
![]() | #1455 |
BHPian | ![]() |
Thread | Thread Starter | Forum | Replies | Last Post |
Synthetic Oil in Bangalore | epyupc | Modifications & Accessories | 50 | 8th December 2017 22:23 |
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? | Max | Shifting gears | 27 | 14th June 2015 23:41 |
Oil change..Synthetic, where to source | DRC | Technical Stuff | 21 | 2nd December 2007 15:00 |
Synthetic Oil | karthik247 | Technical Stuff | 10 | 8th November 2005 18:02 |
