Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
On modifying a car Help articles related to modifying a car
Thread Tools
Old 26th August 2007, 00:34   #91 (permalink)
Originally Posted by BUSA View Post
FYI Diesel engines dont have headers which can be changed
then BUSA is thr anything tat can be done in the engine department to get more power out of diesels,.....
kicksperliter is offline   Reply With Quote
Old 26th August 2007, 01:29   #92 (permalink)
HEADER - A type of exhaust manifold made from formed tubing welded to a steel inlet flange and an outlet collector. less restrictive than a factory iron exhaust manifold and can be "tuned" to provide additional power through scavenging by optimizing tube length.
can find the above definition on this site Technical Information
check the diesel drag truck project photos on the following
2007 Chevy Class Turbo Headers Photo
just cause in India diesels are not modified for performance, that does not mean stuff like headers for diesels do not exist..... please let me know if I have given some wrong info.
Last edited by GTO : 27th August 2007 at 17:04. Reason: Formating correctly and removing FONT tags
dinar is online now   Reply With Quote
Old 28th September 2007, 20:52   #93 (permalink)
BUSA's Avatar
The only difference between petrol and diesel engines is the fuel/ignition systems. The rest, including the intake, exhaust, and intake and exhaust valves is basically the same.
So all the different methods of getting more power still apply! More airflow equates to more horsepower, so adding a Turbocharger, or a supercharger, or Nitrous Injection all work just fine! Generally chip tuning works too on modern turbo diesels. The same result is produced by manually increasing the boost level, and subsequent fuelling. The only problem is the way the fuel is burned is slow so 5000 rpm is about it for a car diesel engine! All the tuning does is increase torque lower down the rev range. Consequently conventional tuning brings little gain on a diesel.
Never try adding extra diesel fuel via the air intake though! It will pre ignite during the compression cycle... You may run over your own crankshaft! If you need extra fuel because you have fitted a turbo, turned up the boost level, or fitted Nitrous Injection you must either fool the normal injection system into giving more fuel, or add Propane (because it will not ignite due to compression alone) in the intake system.
This works because Propane (or LPG, Methanol, or high octane petrol) have a high Octane Rating. Octane is a measure of the fuels ability to not ignite under compression alone! So the ignition point in a diesel still depends on the normal Diesel injection pump's timing. The extra Propane fuel is ignited by the diesel burning as it Self ignites upon injection via the injector. Diesel is very low Octane, so the heat of compression alone is enough for reliable ignition as it is injected.
Engine tuning for diesel cars - how to!
Tuning Chips like Petes, Air filters can help.
I am very well aware that diesels have headers but due to the complicatedness and high NVH of diesels they are not changed atleast in India people dont. There was a Indica with a tuner with a FFE and new headers, quite noisy i must add.
__________________
Got Bhp? Team-Bhp.com
Old 16th October 2007, 19:47   #94 (permalink)
Anyone has tried Pete's on Verna VGT. Please, share your experiences. Price and performance figures.
shatrughna is offline   Reply With Quote
Old 16th October 2007, 20:36   #95 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
all of you here who were interested in the petes box for the innova look here
http://www.team-bhp.com/forum/access...ir-filter.html
akshay1234 is offline   Reply With Quote
Old 19th October 2007, 16:48   #96 (permalink)
What happened viewers and friends?. I am not getting any feedback on Pete's for Verna VGT. Is it the wrong place to expect some responses on it at this forum. . wondering. or Verna VGT is a wrong car for Pete's ( that is no need to try Pete's) as car may not take more power?
Old 15th December 2007, 00:54   #97 (permalink)
anyone using petes tuning box for fiesta 1.4 tdci? would like to get some reviews. Really disappointed with the performance .
nish is offline   Reply With Quote
Old 15th December 2007, 07:19   #98 (permalink)
CrAzY dRiVeR's Avatar
I think the car already has awesome power.
Before going for more power, please make sure the handling is also worked on, else it'll be inviting trouble.
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 15th December 2007, 22:04   #99 (permalink)
BUSA's Avatar
Verna can easily handle mre power and so can the Fiesta, I dont know why people are a bit scared to take the plung, but if i had a Verna, it would have been Peted, the day i bought it, so good is the product. You need to drive a Peted car to find the diffrence.
__________________
Old 15th December 2007, 22:09   #100 (permalink)
akshay1234's Avatar
people arent worried about the verna taking the extra power.. they are worried about the handling after gettin all that power since the handling is supposed to be quite bad even with the stock 110bhp.
Old 15th December 2007, 22:17   #101 (permalink)
BUSA's Avatar
Getting better tires can sought out the handling issues to some extent. Otherwise Hyundai has a speed boat
__________________
Old 16th December 2007, 12:56   #102 (permalink)
dockap's Avatar
guys any info on availablity of box for optra magnum D
dockap is offline   Reply With Quote
Old 17th December 2007, 01:06   #103 (permalink)
BUSA's Avatar
Should be here anytime soon
__________________
Old 17th December 2007, 06:56   #104 (permalink)
a few questions for the diesel gurus and tuners(who have been neglecting us diesel heads-till pete came along)
have we started getting LPG fumigation for diesels in india? the process seemed relatively easier than TCing or using NOS. it also seems a lot more practical and can be done in older vehicles, or did I get the wrong idea?
so far, the most promising diesel seems to be a palio 1.9D which is Normally Aspirated, there seems to be a lot of potential, and the chassis could handle all the extra power.
any ideas on whether LPG fumigation is coming soon?
also, why cant our mahindras be tuned for a few more BHP say 10-20. I dont want to turn them into rockets, but a little more power is always useful. and the torque will be useful during rock hopping. what they also need is a taller final ratio that will let the engine relax on the highway, the NVH will also get better, which means you can travel further to look for offroad tracks
__________________
Enjoy your dictatorship! I'm outta here
Old 17th December 2007, 10:50   #105 (permalink)
After all the good things I have heard on LPG fumigation from Psycho, I too was wondering how come it hasnt really caught on in India. Period. Its only going to take one tuner / suppliers initiative to make it popular; just look how Petes has popularised the powerbox.
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Thread Tools
ARTICLE: How to Modify / Tune your car GTO On modifying a car 107 28th October 2009 01:41
Bought Maruti Gypsy With Toyota Diesel Want to Modify Nahal Modifications & Accessories 14 13th October 2009 00:40
How to modify a diesel engine??? v12 A Collection of the best threads 64 6th March 2008 21:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
