Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
On modifying a car Help articles related to modifying a car
Thread Tools
Old 19th May 2007, 15:07   #16 (permalink)
Team-BHP Moderator
navin's Avatar
BTW we all forgot about damping. Anyway the ICE forum now has a thread just for this.
The enviroment in the car needs to be damped, isolated and deadened.
Various products help from butyl rubber based sheet (doors, trunk and under carpet) to spray ons (great for underbody). You can never have too dead an enviroment in a car. What with so much acoustically live glass area. So my suggestion is to damp like it is going out of style!
__________________
Scixelsyd Etinu
Old 25th May 2007, 03:12   #17 (permalink)
Hi there.,
Been reading a lot of the posts now that I a retired person and some time to my self. What has come to the fore is that there is a lot of first hand knowledge out there that is not being used properly for the benefit of the Brother's and sisters (I hope there are ladies interested in cars as well) out in the BHP world. There should be a thread just for the gurus who give a listing of what was fitted, why it was chosen, how it was fitted, how long it took to fit, how hard or easy it was to fit, HOW MUCH IT COST TO FIT, and where the hardware was bought all with pictures. In this way there should be a benefit for us in as much that these supplier will realise that it is in there own benefit to give a good and fair service for them to be mentioned in such a forum. And this thread over time would come a very powerful reference point for us that dreaming of that great sounding ICE. I am a great believer in market forces and to get a better service from our retailers then we should hold them to account and praise them when are good and belittle them when they are not. From a Lot of the posts there is a fear of getting shoddy goods and services and maybe some of the home grown and some multi national will learn to give warranty that is worth the paper it is written
__________________
And God said let there be light, and lo and behold there was. But OUR EYE'S ARE SHUT
supernova is offline   Reply With Quote
Old 25th May 2007, 04:05   #18 (permalink)
Sam Kapasi's Avatar
Hi supernova!
There is such a thread (well almost) where people discuss what they bought, how much they paid for the equipment, pictures of the fitting.
here, take a look with your own eye's.
http://www.team-bhp.com/forum/sound-...hat-price.html (What ICE & @ What Price)
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 25th May 2007, 04:46   #19 (permalink)
Hi There
I had a Look at that. But I trying to say is that the gurus are the ones who are fitting them and they can by virtue of their job give a experts opinion on that fitting. With a few comments on how the system sounded in that car. We are only going to sample 1/2/3 cars were you are fitting and testing, after the fit that everything is right, the QUALITY 10/20/30 or more cars and your opinion carries a bit more weight. We the punter will normally give a biased view, slanted to our thinking and pocket, where as the gurus are not they are just fitting what the client has asked and some times we get it wrong no. From your own experience how times is that true.
__________________
Old 18th July 2007, 14:10   #20 (permalink)
bottle's Avatar
any idea about how blaupunk markets low end component speakers ? can they actually be called compos or are they just a speaker + tweeter set since they do not come with a crossover. i have one such set in my car and it cost me 2.4k
bottle is offline   Reply With Quote
Old 13th August 2007, 15:36   #21 (permalink)
nitrous's Avatar
Gurujis, I still don't understand the concept of ohms in subwoofers.
Can someone explain in layman terms?
__________________
When in Rome, Do a Roman
Old 21st November 2007, 20:41   #22 (permalink)
montyguru's Avatar
ohm's law is the relationship between power, current, volts, and resistance. ohms as commonly used is a unit of measurement for electrical resistance. wiki it... you won't understand until you know what the other terms mean.
for layman's use... if an amp makes 100w @ 4 ohms, and is 2 ohm stable, it will usually be rated for 200w @ 2 ohms. (lesser the resistance, more the power) so a 2 ohm subwoofer connected will give more power.. 200w... whereas a 4 ohm subwoofer will give only 100w. and a 4 ohm DVC with coils connected in parallel will be at 2 ohms and will give 200w.
if you have multiple woofers and amps that go low upto 1 ohm... you can play around. but one should also consider the specs of the subwoofer... they vary at different ohms. and not all amps can drive such low loads of resistance. typically an amp that's 1 ohm stable or 1/2 ohm stable will cost much much more. however it will have nearly twice to 4 times the sound output and also drain the battery much much less. say if the above amp were 1 ohm stable... it would probably be rated 400w @ 1 ohm.
__________________
life is a song!
montyguru is offline   Reply With Quote
Old 30th November 2007, 00:30   #23 (permalink)
sabret00the's Avatar
wow this is definitely a great effort...really helpful
__________________
________________
2003 Kinetic GF170 Laser Sport Edition
2007 Bajaj Pulsar 180 DTSi
2007 Suzuki ALTO xFun
________________
sabret00the is offline   Reply With Quote
Old 2nd December 2007, 09:55   #24 (permalink)
jerish666's Avatar
Guruji's if i am wrong please ignore it.There are so many diffierence in installing SPL setup and SQ setup. For that Guruji's have any comments.Comments like selecting speakers,subwoofers,HU,Cables.
jerish666 is offline   Reply With Quote
Thread Tools
ARTICLE: The Car Care guide (Aesthetics) Rudra Sen On owning a car 257 1st July 2008 16:33
ARTICLE: The Team-BHP Guide to BASIC Car Audio navin On modifying a car 22 1st December 2007 17:09
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
