Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 28th July 2008, 13:44   #181
Bouncer's Avatar
Originally Posted by rakowli View Post
Hey can anybody advice me which is a good conversion for Ford Ikon 1.3 Flair.
Should i go for LPG or CNG.
Do you travell out of Mumbai? LPG is available in many cities while CNG is available in select cities. In Maharashtra, at least I am not aware of any other city for CNG than that of Mumbai.
My LPG installer states he has faced problems in Ikon for LPG. Don't know about CNG. You better do some research before you decide.
Bouncer is offline   Reply With Quote
Old 28th July 2008, 20:19   #182
nitrous's Avatar
Thanked: 285 Times
Originally Posted by Bass&Trouble View Post
So it seems like CNG is the way to go. Hence two very important questions.
1. Is the cost of a sequential CNG kit, which I assume must be about 75k or so, justified for a Swift that drives 50-70 kms a day?
2. Is CNG easily available in Mumbai? i.e. No queueing for hours on end?
While 75k sounds approximate, Im sure you can get it for a better price,Ajay.
I would suggest you see sequential installs done by the CNG installer and test drive them to be sure you're giving your car to a knowledgeable person.
Old 29th July 2008, 11:28   #183
Thanked: 226 Times
Default cng vs. lpg on Diesel Engine
LPG , as I have seen are fitted on petrol engine only. Never came across Diesel Engines retrofitted with LPG. CNG is most ideal for Diesel Engines, so you can see them on buses in Delhi and Mumbai. Petrol Engines also can be retrofit with CNG viz., Autorikshaws.
If you retrofit CNG on to Ford Ikon, you can use inside city with pride saying environment friendly.
Dwarak
dwaraka is offline   Reply With Quote
Old 25th August 2008, 15:11   #184
AirWind's Avatar
Thanked: 85 Times
Do you know if it is possible to source the Wagon R Duo's sleek LPG tank (guess its 22 litres) in the outside market? Reason for asking - I own a Swift Vxi and would like to see if I can convert it to LPG (obviously fit this tank) without compromising on the boot space.
AirWind is offline   Reply With Quote
Old 25th August 2008, 15:31   #185
nitrous's Avatar
Thanked: 285 Times
Isn't it the toroidal tank thats easily available?
ARTICLE: CNG vs LPG Comparision-sterlingtank.jpg
Old 28th August 2008, 14:16   #186
abhik's Avatar
Dwarak
For a Diesel engine to be made compatible for LPG/CNG combustion the engine has to be re-done or re-designed completely as they are high octane fuels so compression ratios/pistons/heads etc have to be redone. The cost of which will be too huge for an individual user to undertake.
The busses plying in Delhi were diesel engines, re-built to accomodate CNG since the volume of busses/engines operating could'nt be dumped for new busses, which financially would'nt make sense rather less than half the amount of purchasing new busses was spent to re-build them.
LPG can be used simultaneously with diesel to boost performance. The process is called LPG Fumigation where LPG is injected with diesel into the cylinders to combust simultaneously. The results, as far as i have heard, are similar to NOS on a petrol car, only difference being it can be used for longer durations and does not do much harm to the engine.
But since this process is fairly new and unheard of, its practice it very limited and so method of injecting LPG and installation(which ideally should be the same as CNG/LPG) is also not fully known. The major hick-up would be the quantity of LPG to be induced as LPG being highly flamable, would pose a great threat to burn with Diesel.
abhik is offline   Reply With Quote
Old 28th August 2008, 14:40   #187
abhik's Avatar
Check this link out by GTO for more info(ref. to point 6):-
http://www.team-bhp.com/forum/modify...rformance.html (ARTICLE: How to modify a diesel car for more performance)
Old 28th August 2008, 23:04   #188
Bouncer's Avatar
Yes, it is very much available. I had it in my 2001 Wagon R much before the Duo was launched. It should be easily available with authorised LPG kit dealer in any city. These tanks are made or marketed by Sahuwala Cylinders (P) Ltd in India. Their mail id is sahuwala@excite.com
Old 29th August 2008, 16:32   #189
AirWind's Avatar
Thanked: 85 Times
Thanks Nitrous & Bouncer! I was shown the big tank and when enquired about the smaller tank they said it only comes OE with Wagon R Duo, i will try other workshops now.
Old 29th August 2008, 16:48   #190
ab1xlr8's Avatar
can CNG be fitted on luxury cars like a corrolla or say cedia,will a standard kit do or do you need a highend kit, also will the car have to pass a RTO check
ab1xlr8 is offline   Reply With Quote
Old 29th August 2008, 16:59   #191
rjvora_2000's Avatar
Thanked: 41 Times
Rto visit is must after CNG or LPG.
There is one endorsement in RC book as well.
Corrolla can have CNG installed.
There are lot of brand in the market which can be installed.
Money you spend will change 10% to 15% deppending up on the brand you chose.
rjvora_2000 is offline   Reply With Quote
Old 29th August 2008, 17:17   #192
esteem_lover's Avatar
Thanked: 451 Times
Only specific brands are approved. It differs for every car. Make sure you get the right kit.
Old 29th August 2008, 18:28   #193
ab1xlr8's Avatar
so you are saying is that only type A kit is allowed for say a corolla, while type B for cedia.A installer who i spoke to was saying that on certain highend cars a kit could not be installed cause the RTO had not tested the kits on that model,is this a lie
Old 29th August 2008, 21:10   #194
phamilyman's Avatar
Thanked: 3,533 Times
Esteem lover is right. Check the ARAI website for more.
Old 30th August 2008, 09:13   #195
abhik's Avatar
Not a lie, the fellow probably does not have an approved kit for the Corolla.
iDrove an i10 - An opinion, A Comparision herculesksp Test-Drives & Initial Ownership Reports 19 21st July 2008 16:08
Civic-Octavia-Optra Magnum-Corolla-Elantra-Cedia Specs and Feature Comparision hitinv Sedans 3 20th June 2008 18:05
An AT tranny Comparision : OHC AT v/s NHC CVT Dippy The Indian Car Scene 13 11th July 2007 14:24
