| On modifying a car Help articles related to modifying a car |
| | Thread Tools |
| | #47 (permalink) |
| BHPian | i dont have closed loop. i have open loop as of now to make it closed additional components worth 6k is required as per my installer. there is a seperate ecu for gas control, lambda sensor is pre installed in mpfi cars. stepper motor has to be installed. stepper motor is supposed to operate a flapper valve, think might be a one piece system. have to confirm that
__________________ Baleno1.6,Carputer:AMD Athlon 3000+,2gbram,80gb HD,centerfuse FE,satguide gps. |
| | #48 (permalink) |
| BHPian | my present kit contains tank multi valve changeover switch with led indicator gas solenoid vaporaiser emulator plumbing & wiring all cost 17k for installation in sep06. 2k for rto guys extra At that time he was asking for 6k extra to make it closed loop. he had a set lying with him which he had installed in his car (baleno) but removed since he didnt find any marked performance improvement. that kit he was offering for 6k
| | #49 (permalink) |
| Super-Admin | There are actually piece-meal packages with gas installations? I was expecting to see complete fully-loaded kits....
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #50 (permalink) | |
| Senior - BHPian | Quote:
Im sure they can send you one. It covers almost everything you need to know before converting to gas, it even gives a pictoral representation of kits and tells about which parts are important for safety and reliability. Its a good comparison between the two kits and talks about the pros and cons of both. Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari | |
| | #51 (permalink) |
| Senior - BHPian | Quote: Originally Posted by drifter This is good overview given by GTO. For more information, do check the first issue of What Car? magazine, it has an investigative report on CNGvLPG by yours truly. Its a bi-monthly issue. Check October-November 2006. Drifter can you, please ?
__________________ If you can use, some exotic booze, Theres a bar in far bombay Come fly with me, we'll fly we'll fly away - Frank Sinatra |
| | #52 (permalink) |
| Newbie Join Date: Mar 2007 Location: Delhi
| Wolf, I've been thru your detailed review of Xeta CNG. In fact I'm also in dilemma between Wagon R petrol or Xeta CNG, and heavily inclined towards Xeta. But few people are saying that CNG, being a dry fuel eats up the engine. Any info on that??? Scorpio118 |
| | #53 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| Eats as in..! I had an Oil change done at 10,500 there was no change in level on the dipstick..! See practically for 3 years, Your car is covered under Manufacturers warranty- So all defects are covered..! Plus with proper service and regular Oil Change, You have a well maintained car...!
__________________ " When was the last time, You did something for the first time " |
| | #54 (permalink) |
| BHPian Join Date: Mar 2007 Location: thiruvananthapuram
| Recently tata dealerships in kerala was offering brc(itly) kits for their cars including fiat. There are two kinds of kits one with ecu and one without it. They claims that the kit with ecu will give better power and mileage than petrol. It costs about rs 35000 and another normal kit costing 21500. The above said charges are including fitting, they told me that warranty will prevail even after conversion. Does anybody thing that what they claim about the ecu is crrect or will it be a simple wastage of money. |
| | #55 (permalink) |
| BHPian | Hi, I would like to add my thoughts to the existing thread. Like Esteem Lover pointed out, The initail run with LPG or CNG on an ESteem can be extremely painful. Leaving the endoresements aside...Here are a few pointers. LPG is a cheaper fuel than petrol, but you will have constantly tune it till you reach a point of perfection...As the mileage that you would get would be less. The first cylinder that I used gave me 100, After numerous tunes..it gave me 173 and then after a good tune-up I managed to 190 KMS / 18 KG cylinder. Another point to keep in mind is the flow of gas to the engine. This is extremely important, At high speeds especially during highway travels...The cylinder cools off pretty fast and if you shift from 5th to 3rd to slow down..Engine cuts off...So you need to make sure that you heating element is intact and working. The gas when it settles down on the convertor leaves WAX residues..SO if you are person who is a sparse user of the car, avoid LPG/CNG as you might have reduced efficieny and spend quite a bit of your time cleaning the filter and the gas condensor and convertor. It is extremely important to go for authorised and recognised LPG convertors, DO NOT go for local ones, They may appear to cost effective at the begining but the maintainance and efficieny would be low
__________________ Master Practicing |
| | #56 (permalink) |
| Senior - BHPian | I think what he meant is one for the MPFI cars which come with the ECU & the other is for the carb cars without the ECU. i dont think the kit itself has a ECU.
| | #57 (permalink) |
| BHPian | esteem lover, lpg kit comes with ecu of its own and that is what should be installed in any mpfi car. kits without ecu are ment for carb cars only, however in india we are still continuing to use the crude system without ecu on mpfi cars, and spoiling the cat converter and getting lower mileage than possible.
| | #58 (permalink) | |
However a simple option is available to add the ECU, Lambda sensor and Stepper motor and convert to closed loop. Cost an additional Rs 6000.
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* | |
| | #59 (permalink) | |
'ksethuram',a chennai member is running his Swift ZXi on LPG(BRC kit)and researched th net about the above theory and it was true.He told me just that. I checked with a couple of experts and they confirmed. This is why LPG run cars have engine heads requiring overhaul at around 80000 kms.There is a product that can counter this problem.Its called a 'Valve saver kit' and the brand I know of is 'FlashLube' from Australia. Also, another problem that he's facing is with Spark plugs wearing out fast.
__________________ When in Rome, Do a Roman | |
| | #60 (permalink) |
| Senior - BHPian | Funny you should say this nitrous. I have driven my previous car M-1000 for more than 80k Kms without the engine needing any overhaul & have never had to change spark plugs frequently too. How many KMs has sethuram driven ? & does he not use petrol occassionally ?
| Thread Tools | |
Similar Threads | ||||
| My experiments with LPG and CNG | .anshuman | Long-Term Ownership Reviews | 33 | 4th January 2008 11:07 |
| CNG Vs LPG | VishalMukherjee | Technical Stuff | 2 | 10th December 2007 16:34 |
| LPG / CNG kits | amu1983 | Modifications & Accessories | 6 | 27th February 2007 22:13 |
| Diesel --> CNG/ LPG?? | panky12345 | Technical Stuff | 5 | 24th June 2006 11:30 |
| Cng Vs LPG.. | Rice_tuner | Modifications & Accessories | 1 | 27th February 2005 13:20 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
