Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 13th January 2009, 10:51   #196
Thanked: 103,683 Times
Originally Posted by hoomdo View Post
1. Is it better to change both front tyres together or can it be done one at a time? I was planning to put the new tyre on the front left and the existing front left on the front right and use it a further 3 to 4000 kms.
If the CEATs have run 40,000 kms, I would change all 4 tyres. If not, atleast change the front two as an absolute essential.
3. If I change both the tyres, should I stick to CEAT (they have really served me well)?
As long as you are happy with them.
4. As I mostly drive in city rush (75% of total distance done), guess its best to stick to the same width and profile?
Look up the many 800 tyre upgrade threads for more info.
Old 13th January 2009, 16:00   #197
hoomdo's Avatar
Thanks GTO...will change both my front tyres for now.
Any advise on my below query pls? Is wearing on the inner edge normal?
5. Does the wearing of only the inner edge indicate any problem with the alignment?
hoomdo is offline   Reply With Quote
Old 16th January 2009, 15:23   #198
Atlblkz06's Avatar
Yes. It sounds like you may need to increase your camber. Also check your toe settings. Toe out and too much negative camber will wear out the inside edge of your tires.
Since you do mostly low speed city driving, you can get away with mixing tires. Just don't try to track a high performance car with mismatched tires!
Atlblkz06 is offline   Reply With Quote
Old 14th February 2009, 16:00   #199
joshguy's Avatar
Thanked: 92 Times
Question Tyre upgrade advice - NEW HONDA CITY ZX -Urgent
Hi BHPians,
I need a urgent expert advice on upgrading Tyre for the Honda city ZX.
The tyres are worn out and the existing OE tyres are not giving enough grip in high speeds.We are not looking at 15inches but to get better ride quality and grip.
1.Which is the best upgrade in 14 inch- 185/65 or 195/65 ?
2.Which alloys are good ? OE or After Market or which brand is good.
Please let us know your feedback
Thanks in Advance
Ram
joshguy is offline   Reply With Quote
Old 14th February 2009, 16:58   #200
lohithrao's Avatar
Thanked: 163 Times
josh would suggest "Turanza" bridgestone its worth the money.
lohithrao is online now   Reply With Quote
Old 15th February 2009, 00:37   #201
Xehaust's Avatar
Thanked: 74 Times
Question
i dont know if this is the right place to ask this but:
Can the OEM Hyundai Verna Steel Rims fit on a Hyundai Getz???
Note: If someone knows the right thread for this, please point me in the right direction.
Xehaust is offline   Reply With Quote
Old 15th February 2009, 00:57   #202
iraghava's Avatar
Thanked: 156 Times
Should fit, both are 100 PCD & 4 bolt.
Old 31st March 2009, 13:32   #203
hoomdo's Avatar
Default Tyre Safety
Just found a nice little presentation on tyre safety. You may like to go through the same.
Old 31st March 2009, 15:30   #204
Raccoon's Avatar
Thanked: 105 Times
Its really not a good idea to mix tyres. Diffrent tyres have different grip levels, etc. For eg. the car may not go in a straight line on emergency braking!
Best to stick to one brand. And keep tyres with same/similar wear on the same axle.
Raccoon is online now   Reply With Quote
Old 6th April 2009, 18:27   #205
Vicky_s_world
Posts: n/a
Default Low profiles
Hi!
Good thread GTO, thanks for the ppt is relly usefull.
I wanted to know more on low profile tyres. Are they a bit hard on the suspension, morover is it only for the looks that ppl go in for low profiles??
If your travelling is frequent on the express highway, what type of tyres would you suggest? And what care is to be taken whilst travelling on the expess?
Old 7th April 2009, 02:07   #206
Raccoon's Avatar
Thanked: 105 Times
^^^Low profile tyres will be hard on the suspension. Ride quality will suffer too.
People go for them for looks and handling.
For any kind of high speed travelling, grip is very important. Tyres like Yokohama, Michellin, etc., are known to have better grip.
For high speed travelling, make abs. sure your tyre pressure is correct. Not easy unless you have an accurate gauge. Also, keeping the pressure say a couple of psi higher is recommended for high speed driving.
Old 14th April 2009, 17:42   #207
Sampai's Avatar
Thanks a lot for the info, after going through this I got myself a Uni-Directional tyre, F1. Really good tip. A must read before buying any type of Tyre.
Thanks.
Sampai is offline   Reply With Quote
Old 14th April 2009, 19:14   #208
Originally Posted by Vicky_s_world View Post
Hi!
Hey, it's not my article at all. Rehaan compiled the entire write-up while Iraghava & KPZen provided the excel sheet.
Old 16th May 2009, 21:27   #209
TRAUMASURG's Avatar
tires are like shoes .We dont compromise our footwear then why should compromise for the car.If the tires are not good it does interfere with steering,braking,ride,performance.ideally ,tires(tyres) should be replaced 4 at a time ,rotate regulary at time intervals 5000 miles .If the wear is uneven ,either the alignment is off or the tires are out of balance.out of balance tires will cause the sterring to shake if they are mounted on the front.there is a very goog web site here in USA.Tire Rack - Your performance experts for tires and wheels check it out .they do testing al all the tires in the market.if one is looking for longer thread life then you are compromising the ride qualitybecause the side wall has to be compromised for a longer thread life.If you are using low profile tires the rides are a bit aggressive/harsh, they are meant for performance.and they do compromise on wet traction.
TRAUMASURG is offline   Reply With Quote
Old 11th June 2009, 23:47   #210
Thanked: 32 Times
Originally Posted by iraghava View Post
Attached is a guide of the correct upsizes for cars sold in our market compiled by KPZen and me.
Disclaimer: Not all sizes mentioned in this guide might be readily available in India.
I think this chart has to be updated as many models have been introduced latter & few have changes in the tyre sizes.
kiren is offline   Reply With Quote
READ FIRST: Choosing The Right Set Of Tyres for your Car Rehaan Tyre & Alloy wheel Section 6 7th February 2011 09:57
Choosing right dealer for Fiat Palio in Kochi.. roops4fun Indian Car Dealerships 4 10th January 2009 03:03
which is the right set of tyres kpbhatt Tyre & Alloy wheel Section 3 31st March 2008 15:43
Choosing the right dealership luvjascha Indian Car Dealerships 10 14th September 2006 18:11
