Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 5th February 2013, 17:56   #436
Thanked: 175 Times
Default Re: ARTICLE: Choosing The Right Set Of Tyres for your Car
Originally Posted by sukiwa View Post
Please stick to stock size as Fusion already has enough ground clearance (assuming you have petrol Fusion). I haven't compared A-drives & XM2 in this size, but XM2 has stiffer sidewall compared to XM1 or even C-drives.
Having said this, if daily run consists of 20% semi-rural roads, please consider Bridgestone Turanza ER 60.
Looking at usage pattern, my preference would be BS turanza, Yoko A-drive, Michelin XM2 in that order.
Thank you so much Sukhiwa. Will definitely revert to stock size. And will check out the Turanza'a too.
Thanks for the advice. Cheers
thumpingheart is offline   Reply With Quote
Old 16th March 2013, 00:47   #437
norhog's Avatar
Thanked: 123 Times
Hi guys , any tyre for zen and wagon R on R13 rims having maximum resistance to punctures? I have learnt that tyres from Indian makers like MRF have a hard compound hence less grippy but on the positive side fewer punctures. My driving is urban and semi rural roads. So what is the best inbetween solution?? Thanks in advance.
norhog is offline   Reply With Quote
Old 26th April 2013, 21:50   #438
I got mrf zvts tubeless for my Zen couple of years back. Done 30 k. No flats so far.
ajayc123 is offline   Reply With Quote
Old 4th May 2013, 13:40   #439
Bivash's Avatar
Default Upsizing : How big is too big?
Hi All,
This is my first post here since I became a member a couple of days ago! Feels great to be part of a community that has helped me on so many occasions in the past!
I'm upgrading to a Corolla Altis, and desperately want to upsize on the stock rims, which are 195/65R15. After loads of R&D, have zeroed in on the following guiding principles:
1. Max rim upsize by 2 inches
2. Max tread upsize by 20mm
3. Max diameter variation +/- 2.5%
Considering all this, have narrowed it down to either:
215/45R17 (diameter smaller by 9mm/1.5%) or,
215/50R17 (bigger by 12mm/2%)
Basically want the wheel wells to look as full as possible. My biggest nightmare is to drive into a pothole and have the tyre hit the inside of the wheel arch!
Would really appreciate any points of view / advice / sharing of past experience etc on this!
Cheers!
Bivash is offline   Reply With Quote
Old 21st May 2013, 14:40   #440
Chris_Xtreme's Avatar
Thanked: 27 Times
Hi Norhog,
I had replaced my WagonR's shoes to Michelin Energy XM2 tubeless tyres. I had them replaced in my OE steel rims and had driven approximately 2.5k kms without any issues/punctures. The driving and handling has increased considerably.
Chris_Xtreme is offline   (1) Thanks Reply With Quote
Old 19th June 2013, 14:09   #441
bhp
bhp's Avatar
Thanked: 152 Times
Need help.
I am upgrading to 17'' rims on the latest generation accord.
The tyre i am thinking to opt for is 225/45-17.
This is having a diameter variation of -4.5% as compared to stock. is it advisable ??
bhp is offline   Reply With Quote
Old 21st June 2013, 07:58   #442
Sandman689's Avatar
Thanked: 25 Times
So the stock Apollo hawkz on my 2009 tavera used to make screeching noise when taking turns in 50kmph. So went to this store that my friend recommended. I was really keen on some Michelin. But unfortunately the only soft tyre that they had was of Kumho, a name which I have seldom heard of. Eyes closed, bought a set. I was worried at first because it was a bit cheap. but thankfully it performs brilliantly, and I can now drive with more confidence.
Sandman689 is offline   Reply With Quote
Old 21st June 2013, 09:13   #443
Santoshbhat's Avatar
Thanked: 3,899 Times
Originally Posted by bhp View Post
Need help.
Not advisable to beyond 3% variation of stock. With a variation of -4.50% your car's GC will go down, the ride will suffer and also the speedo and odo reading will be messed up. 225/50/17 should be a better fit.
Santoshbhat is online now   Reply With Quote
Old 26th June 2013, 00:44   #444
Bivash's Avatar
I just upgraded to 225/45R17s on my Altis, and the grip is unbelievable! Rides a tad bumpier, but the stability's worth it!
Old 26th June 2013, 07:33   #445
shankar.balan's Avatar
Thanked: 5,350 Times
Kumho is from Korea. Many Hyundai vehicles used to come with Kumho as standard OEM.
Old 3rd July 2013, 06:46   #446
Sandman689's Avatar
Thanked: 25 Times
Yes I did some research right after coming home. there had been word that they were using impurities in their products. But till date I have had absolutely no problem.
Old 3rd July 2013, 14:09   #447
Thanked: 15 Times
Just changed the tyres on my Optra Magnum LS Diesel, replaced the Michelin Pilot Precedas 205/50/15 with the Primacy LC 195/60/15. As mentioned earlier by many members, the Primacy is a super quiet tyre and I am just loving it.
The ride has improved dramatically and the noise levels - oooh I love it. Would recommend the PLC any day.
kewlferrari is offline   Reply With Quote
Old 19th July 2013, 23:14   #448
urajkumar's Avatar
Thanked: 288 Times
Thinking of upgrading from 195/65/R15 to 205/65/R15 since the guy said while 225/55/R16 size is available, the tread would be simple & 16 Rims dont have much choice. Also the difference between both these upgrades are 20,000 which is not worth it (nor do i have the vitimin M for it)
He has offered to upgrade tires from 195/65/R15 to 205/65/R15 at a good rate (considering exchanging my new tyres) but i am confused with the options (not much difference in cost). Even if i get goodyear tyres, i get to upgrade them to slightly bigger tyres and better brand at a reasonable cost.
Michelin / Continental / Pirelli / Yokohoma / Bridgestone GR60
What do you guys think I should choose? my requirement is as below. This will be driven inside the city only and no highway driving.
1) Improve Grip (no ABS on this version)
2) Improve Ride quality (Ecosport ride is little stiff)
So which among these tyres are best suited to my requirement? hope some tyre guru helps me out here
urajkumar is offline   Reply With Quote
Old 19th July 2013, 23:29   #449
d_bhowmik's Avatar
Hi All,
Need advice for upgrading tyres of my Ritz vxi. Currently riding on stock JK tornado - 165/70/R14. Have kind of zeroed on Bridgestone taurenza 185/70/R14. Need suggestion.
d_bhowmik is offline   Reply With Quote
Old 20th July 2013, 19:39   #450
Nikhilb2008's Avatar
Thanked: 6,661 Times
Bridgestone Turanza is a good tyre. If you have zeroed in on it, dont worry. Go ahead.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
READ FIRST: Choosing The Right Set Of Tyres for your Car Rehaan Tyre & Alloy wheel Section 6 7th February 2011 09:57
Choosing right dealer for Fiat Palio in Kochi.. roops4fun Indian Car Dealerships 4 10th January 2009 03:03
which is the right set of tyres kpbhatt Tyre & Alloy wheel Section 3 31st March 2008 15:43
Choosing the right dealership luvjascha Indian Car Dealerships 10 14th September 2006 18:11
