| On modifying a car Help articles related to modifying a car |
| | Thread Tools |
| | #76 (permalink) | |
| BHPian | Quote:
Thanks for the info. I have managed to track them down. Just one question - if I fit a complete new exhaust, what will happen to the original catalytic convertor? There is mention of headers, expansion box and muffler but no mention of the catalytic convertor - or am I missing something here? S.S. | |
| | #77 (permalink) | |
| BHPian | Quote:
i think the cat will not be included in it
__________________ Forgive them, but never forget their names!! | |
| | #78 (permalink) |
| BHPian | Hi Alias, Have checked with a well known exhaust manufacturer and you are right. The original catalytic convertor will be removed. How does this affect the law with regard to emission norms? According to the manufacturer, the CO emissions will go up only marginally but, surely the "cat" is fitted for control of other harmful exhaust gases, not just CO? I remember reading an article a few years ago where it stated that a car running on unleaded fuel (all cars these days) which did NOT have a "cat" fitted or removed the "cat" would be belching out pure cancer fumes from the exhaust due to the nature of unleaded fuel? Also, I can't see that car manufacturers would fit an expensive piece of kit like a "cat" just to reduce CO emissions from say 0.01 (already well within emission norms) to 0.008. In fact with MPFI engines, it's the ECU controlling the fuel/air mixture giving one the low(er) emissions, so, why bother fitting a "cat"??? Please correct me if I'm wrong here. Would appreciate yours and anyone else's (Senior Mods/Super Admin) inputs on this matter before I change to a FFE. Suzuki San |
| | #79 (permalink) | |
| BHPian | Quote:
__________________ Longing for a long ride... | |
| | #80 (permalink) |
| Distinguished - BHPian ![]() | You have in option to fit a high flow catcon to have the the benefits me both the worlds (emmisions and power) but you will have to import the same and mate it to the ffe. Else you could also retrofit a larger catcon from a larger capacity car to aid in the free flowing of the gasses.
__________________ Psycho Modding != idea + <ctrl-c> + <ctrl-v> Modding = idea + <ctrl-c> + <ctrl-v> + Finagle's Law of Dynamic Negatives |
| | #81 (permalink) | |
| BHPian | Quote:
i guess you got the answer to your question from the experts
| | #83 (permalink) |
| Team-BHP Support ![]() | This article is being updated to include pointers from Raj Hingorani - who has personally penned this list and thought it to be useful for anyone thinking of modifying their cars: 1. While performance tuning, always first address the breathing cycle of the engine 2. Work first on external control systems outside the engine, before touching the engine. Examples include air filter, throttle body, intake system, exhaust system etc. 3. Engines of today are generally equipped with efficient cylinder heads which do not really require any reworking until much later in the list of modifications. The same applies to high lift cams. 4. Address the intake manifold design next. More power can be gained by analyzing, replacing or improving this component. 5. Address the flywheel weight - fit a lighter flywheel alongwith a better clutch unit at this stage. This improves drivability and throttle response. 6. Address the gear ratios to suit your driving style. Most engines are fitted with poor gearing from manufacturers due to mileage concerns and driving habits of the general public. 7. If one can afford it, fit a properly designed turbo system as a power booster. Good systems will very marginally reduce the mileage, but give a good improvement in power. Limit boost to 10-11 psi due to fuel requirements for the street. 8. Nitrous is a cheaper option - but not very practical for the daily driver due to bottle pressure. Monitoring this and frequent refill is excellent for drag racing but has limited utility for street use. 9. Do one modification at a time. Only then go to the next one. 10. Good tuning requires patience and attention to detail. There is no quick solution to tuning vehicles for ultra-high performance. Towards this, searching for "quick and cheap magic solutions" is not recommended. Only a lot of hard work and attention to detail will get you the desired results. 11. Every engine has its own set of individual modifications that work best for that engine. Evaluate each carefully. 12. Focus on the fundamentals of internal combustion engines. Only this will serve you the foundation to reaching your performance goals. 13. Any engineering fundamentals will always follow laws of fluid mechanics, physics, chemistry and thermal dynamics. These laws cannot be violated irrespective of requirements. Team-BHP officially thanks Raj Hingorani for his contribution above.
__________________ Become who you are. Last edited by theMAG : 5th September 2008 at 01:01. |
| | #85 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Won't torque come down as well?
__________________ Let's get "instigated"..... \ / ][ |) `/ [_] "!" | |
| | #86 (permalink) |
| BHPian | Sorry if the question sounds stupid - but do cars modded with FFE (and cat converter removed) have issues with passing PUC tests? I thought catalytic converters were made mandatory by the central government a few years ago in all vehicles, when unleaded petrol was launched in the country. Some clarification on these points will help me understand the issue.
__________________ You gotta know when to hold em, know when to fold em, Know when to walk away and know when to run. |
| | #88 (permalink) |
| BHPian | Point number 8 should indicate race use only. Most importantly, where can I find an enlarged throttle body for a single cam D block? Maxbore.com throttle body boring service or can someone do this work in mumbai? Can we get an Edelbrock Victor X manifold somwhere in India?
__________________ "No other man-made device since the shields and lances of the ancient knights fulfills a man's ego like an automobile." |
| | #89 (permalink) |
| Senior - BHPian | Dont know if it has been already answered or not. What exactly is a triphase module? and how does it work in petrol vehicles? Are there any negative effects of using it? ![]() Found the info here http://www.team-bhp.com/forum/access...e-reports.html
__________________ 1997 Gypsy MG410W(Sold) 2001 Bolero GLX 1983 Premier Padmini DX 1978 RE STD 350 1999 RE Machismo 350 2005 Zma 225 2006 Accent GLE Last edited by akshay4587 : 26th September 2008 at 06:07. |
| | #90 (permalink) |
| Senior - BHPian | Do Bolt on End cans do any good apart from creating sweet noise? what are the side effects on an engine?
__________________ 1997 Gypsy MG410W(Sold) 2001 Bolero GLX 1983 Premier Padmini DX 1978 RE STD 350 1999 RE Machismo 350 2005 Zma 225 2006 Accent GLE |
« ARTICLE: Points to consider before TURBO-Charging your car
ARTICLE: How to modify a diesel car for more performance »
| Thread Tools | |
Similar Threads | ||||
| ARTICLE: How to modify a diesel car for more performance | GTO | On modifying a car | 201 | 6th November 2009 16:43 |
| How to Modify / Tune your car - 2 - Superchargers! | Psycho | Technical Stuff | 67 | 17th April 2009 17:38 |
| How to Modify / Tune your car - 2 - Nitrous | Psycho | Technical Stuff | 40 | 27th March 2009 14:49 |
| How do you want to modify your car? | GTO | Modifications & Accessories | 58 | 2nd November 2007 17:49 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
