Go Back   Team-BHP > Buckle Up > Motor-Sports!!
Motor-Sports!! Extreme racing and performance.
Thread Tools
Old 1st February 2005, 11:09   #1 (permalink)
Default FW 27 launched
On January 31st the FW27 was revealed at Valencia in Spain. As with other new cars that have been launched, the appearance of the FW27 shows the effects of the new regulations for this season, with a slightly higher front wing and further forward back wing
Unlike its predecessor, which had a radical front wing dubbed the 'walrus', the FW27 has a more conventional single-keel design. The cooling system is "aggressive", according to technical director Sam Michael, with low engine bodywork and sidepod undercuts. Reducing weight and increasing stiffness were also key elements in the design process.
Michael explained that reliability was another focus for 2005. "While reducing weight, a lot of attention has been placed on reliability, in particular the gearbox," he said. "The FW27 gearbox has been running on the track since November 2004 with no major problems and any issues we had with last season's gearbox have been resolved."
BMW, Williams' engine partner, is equally determined. "For four years we surpassed our targets," said motorsport director Mario Theissen. "Then in 2004 we found ourselves in a trough, failing to meet our expectations for the first time. We now aim to accumulate successes once more with renewed strength."
It's a new race driver line-up for Williams in 2005; at the launch it was announced that Nick Heidfeld will be teammate to Mark Webber this season, while Antonio Pizzonia will continue his test driver role. Frank Williams is, naturally, convinced that they will be a strong squad.
__________________
MY NEW RIDE : HYUNDAI VERNA CRDi WITH ABS.
haryan is offline   Reply With Quote
Old 1st February 2005, 11:11   #2 (permalink)
More Facts and Figures about BMWWilliams FW 27
Williams BMW FW27 Technical Specifications
Transmission: WilliamsF1 semi automatic
Clutch: AP
Chassis: Carbon Aramid epoxy composite manufactured by WilliamsF1
Suspension: WilliamsF1
Steering: WilliamsF1
Cooling system: Water and oil radiators
Brakes: Carbon Industrie carbon discs and pads operated by AP calipers
Lubricants: Castrol
Fuel: Petrobras
Wheels: O.Z: 13x12 front, 13x13.7 rear
Tyres: Michelin
Cockpit Instrumentatior: WilliamsF1 digital data display
Steering wheel: WilliamsF1
Driver's seat: Anatomically formed in carbon/epoxy composite material with Alcantara covering
Extinguisher systems: WilliamsF1/Safety Devices
Front track: Maxiumum allowance
Rear track: Maximum allowance
Weight: 605 kg including driver and camera for qualifying, 600 kg for race
Engine: BMW P84/5
Type: Normally aspirated V10
Cylinder angle: 90 degrees
Displacement: 2,998 cc
Cylinders: Four valves per cylinder
Valve drive: Pneumatic
Engine block: Aluminium
Cylinder head: Aluminium
Crankshaft: Steel
Oil system: Dry sump lubrication
Engine management: BMW
__________________
Old 1st February 2005, 14:09   #3 (permalink)
shravan316's Avatar
This is awesome! The cars are being launched, the testings are underway, now i cant wait for the season to start!
__________________
"You can have it in any colour as long as its black..."-Henry Ford
shravan316 is offline   Reply With Quote
Old 1st February 2005, 14:48   #4 (permalink)
Hatari's Avatar
it looks nice and i'm happy to see no radical designs..
esp after the walrus episode
but more importantly.. nick heidfeld is the 2nd racing driver..
with pizzonia remainging as test driver
think its good move.. nick is def the quicker of the 2..
bmw will be happy.. he was no doubt their pick ( he's german )
( nick is the happier looking of the 2 ! )
Hatari is offline   Reply With Quote
Old 1st February 2005, 14:54   #5 (permalink)
BMW.Williams F1 Team will be a team with 0 Wins against BOTH their Driver records ....
Last time it happened was in 1999 when team had Ralf Schumacher and Alex Zanardi
and in 2000 also with Ralf and Jenson Button ......
I think that record will be changed by the end of the season as i expect BMW Williams to score one or two victories and Nick and Mark both are capable of doing that ... Time for them to have champagne on the Top Step ....
__________________
Old 1st February 2005, 17:11   #6 (permalink)
Fascinating facts and figures on the new Williams FW27, which was launched at Valencia:
1.3 terabytes of aero data processed in CFD (1 terabyte is a thousand million bytes, equivalent to 69,333 volumes of the Encyclopedia Britannica.
250,000 man hours of design time has been spent on the FW27, with a further 250,000 man hours required in fabrication and build.
4,500 drawings have been produced in the design of the FW27 chassis. End-on-end, these drawings would stretch for 5.350km with a further 4 km expected to be produced to support the FW27’s lifecycle. By the end of the season, drawings would reach from London to Buenos Aires.
The FW27 will accelerate from standing to 200kmh in five seconds, and deceleration forces on board will reach 5g. 1g equates to driving into a brick wall at 30kmh.
Brake temperatures to generate the deceleration will reach 600 ºC in one second On board the FW27, exhaust temperatures reach 950 ºC and even the air temperature in the pneumatic valve system reaches temperatures two and half times boiling point at 250 ºC.
The BMW P84/5 contains 5,000 individual components, and takes 100 man hours to build. BMW have historically produced approximately 200 engines per season, but this figure will reduce in 2005.
BMW produce 1,000 drawings in the design of each engine.
The BMW engine weighs less than 90 kilograms.
At 19,000 rpm, 316.7 revolutions and 1,583.3 ignitions take place each second in the BMW F1 engine. 9,500 engine speed measurements are made, the pistons cover a distance of 25 metres, and 550 litres of air are drawn in. In the P84, maximum piston acceleration was 10,000g. Peak piston speed was 40 metres per second.
Source BMW WilliamsF1 Team
raihan is offline   Reply With Quote
Thread Tools
Just Launched ! MonkSansFerrari Introduce yourself 10 20th September 2008 20:53
SX4 Petrol / SX4 Diesel (To be launched) / NHC VTEC+ / NNHC (To be launched) ? autoenthusiast Sedans 24 19th June 2008 19:24
New Bolero launched jp1 The Indian Car Scene!! 79 5th April 2007 14:30
New Zen To Be Launched!!! shiva_cool87 The Indian Car Scene!! 1 30th May 2006 13:55
Evolution Ix Launched !!!! iceman91 The International Automotive Scene 11 16th July 2005 12:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
