| Motor-Sports!! Extreme racing and performance. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2004 Location: Mumbai
| The new Mercedes-Benz SLK 55 AMG:leading the way as the official FIA Formula 1 safety car Affalterbach, Mar 03, 2004 Following its world premiere at the Geneva Motor Show, the new Mercedes-Benz SLK 55 AMG will be showing what it is capable of in its new role as the official Formula 1 safety car. Specifically, the compact eight-cylinder roadster will be celebrating its circuit debut at this year’s Grand Prix season opener on 7th March 2004 in Melbourne, Australia. Thanks to modifications to its braking system, chassis, cooling system and exhaust system, as well as weight-reduction measures, the SLK 55 AMG safety car will be showing off its optimised driving dynamics and maximized stability. And the improvements will prove very useful: After all, the newcomer will have to lead the world’s fastest drivers around the track at high speed in the event of a circuit emergency, while ensuring maximum safety. And the new C 55 AMG estate is also making its first appearance at the most prestigious level of motor sports. Prof. Sid Watkins, the Grand Prix chief medical officer, will be able to use the high-performance official medical car with the AMG V8 engine to ensure the fastest possible response in the event of a emergency. The powerful AMG cars will be ready for action at all 18 Formula 1 races, where they will be able to demonstrate their sporty prowess in front of billions of race fans worldwide. With Bernd Mayländer, 34 - a professional racing driver - behind the wheel, the safety car is taking on the challenge of keeping the Formula 1 cars out of harm’s way in the event of crashes and bad weather conditions. In other words, Mayländer will have to position himself at the head of the field and drive at top speed in front of the Formula 1 cars. And if the speed becomes too low, the high-tech engines that power the sensitive Formula 1 race cars could start to experience problems. For example, they could overheat due to an inadequate supply of cooling air, while the tyres could cool down too much and lose their grip. Fast laps at top speeds of up to 240 km/h at the world’s Grand Prix tracks are therefore everyday occurrences for the safety car, which masters these situations with no problems. Few - but focussed - technical changes to the new SLK 55 AMG For its demanding assignment as the Formula 1 safety car, the SLK 55 AMG required modifications that were few in number but very sharply focused. The distinctive sporty strengths of the new two-seater developed by Mercedes-AMG were only supplemented in areas that would generate maximum high-performance and reliability for circuit operation. In place of the standard 18-inch tires, for example, new multi-part 19-inch AMG light-alloy, double-spoke rims with special 235/35 R 19 and. 265/30 R 19 tires have been used. And together with the firmer chassis tuning, the car can handle higher curve speeds and has even more agile handling. The enhanced performance of the new, enlarged braking system ensures that the car remains perfectly stable and exhibits optimal deceleration. Composite brake discs with six-piston brake callipers are installed on the front axle, and internally ventilated and perforated steel brake discs with four-piston callipers provide the stopping power in the rear. Channels that direct cooling air to the front brakes - which have to bear particularly high stresses - were specially engineered for the safety car’s use in a racing environment. Weight reduction: nearly 100 kilograms lighter than the series-production car In order to deliver world-class racing performance, the weight of the safety car was trimmed by nearly 100 kilograms in contrast to the series-production vehicle. And this was achieved despite the fact that the car became heavier right from the outset because of its added components - including communication equipment, lights, cooling systems for the rear axle and brakes, and larger wheels and brakes. Aluminium was used in place of steel for the bonnet and other components, representing a weight saving of about 12 kilograms. The DaimlerChrysler specialists at the Bremen plant played a key role in slashing the car’s weight. Keeping the vario-roof closed at all times made it possible to dispense with its mechanical and hydraulic systems, saving another 17 kilograms. The front and rear valences are made of an extremely lightweight, high-strength carbon-fibre laminate material. Carbon-fibre laminate is a high-tech solution known for its applications in Formula 1 and the DTM. The valences weigh ten kilograms less than those used in the series-production SLK. Additional weight reductions were realized with the headlamps (4 kg), seats (25 kg), the car’s entire wiring (4 kg), its interior (40 kg) and numerous other measures, giving the safety car a curb weight of 1,370 kg. In comparison, the curb weight of the SLK 55 AMG series-production vehicle is 1,465 kg (not including the fuel and driver). All these modifications also result in optimised weight distribution, which means superior handling on the circuit. The car’s battery and windscreen fluid reservoir were moved from the engine compartment to the boot, enhancing this advantage even more. Engine and drive: characteristic V8 sound with optimised cooling The engine and drive of the unique Mercedes-AMG SLK greatly resemble their series production versions. The 5.5-litre V8 engine from AMG delivers 265 kW/360 hp and accelerates the silver two-seater from 0 to 100 km/h in under five seconds. What’s more, its convincing eight-cylinder sound is sure to appeal to racing fans watching at the track or on TV. The sports car was given a newly developed exhaust system with reduced back pressure and a special sound for Formula 1 use. And to ensure that even the toughest of weather conditions are no problem, the SLK 55 AMG safety car is also fitted with a high-performance water cooler, two engine oil coolers in the sides of the front apron and a larger transmission oil cooler. The rear differential has cooling fins and a separate cooler installed into the rear valence. The air stream is distributed through it by a diffuser, thus helping to prevent the rear-axle oil from overheating. When the car is stationary, an electric fan is employed to increase safety even further. Roof lights send out clear signals to the Formula 1 drivers Two visual features make the safety car stand out from the series-produced SLK 55 AMG: the FIA Formula 1 logos and the light system on the roof. The green lights are turned on by Mayländer’s co-driver, Peter Tibbets (UK) from the FIA, when the safety car pulls out and first has to overtake all of the racing cars. As soon as the safety car has taken the lead, the orange light signals to the Formula 1 drivers that overtaking is strictly forbidden. The white strobe lights in the headlights and tail lights remain active whenever the car is in use and have a neutral signal function. To enable communication with the race organisers, the safety car is equipped with a radio system, a TV monitor and cameras installed inside and out. This extra equipment requires a separate electrical circuit with a second generator. The very special character of the new Mercedes-AMG FIA safety car is typified by the two bucket seats with four-point seatbelts, the exclusive black-and-silver leather fittings, Formula 1 tread panels, a particularly eye-catching AMG sports steering wheel and high-quality carbon trim. C 55 AMG estate: Medical car for Formula 1 chief medical officer Sid Watkins Professor Sid Watkins, the official FIA Grand Prix chief medical officer, now has a new Mercedes-Benz C 55 AMG estate as a medical car to ensure that he can reach and treat racing drivers who have been involved in an accident as quickly as possible. The communication system, chassis and brakes of the high-performance car, which is powered by a 5.5-litre V8 engine that delivers 270 kW/367 hp, were remodelled especially for the Formula 1 world championships. On the monitor of the medical car’s COMAND system, the occupants can follow the race live. The car also boasts a radio system for communicating with the race organisers, roof lights and strobe lights front and rear. A high level of safety for Professor Sid Watkins and the three medical assistants is guaranteed by four-point belts at each seat. The roomy boot of the C55 AMG estate houses a complete emergency aid kit to treat severely injured patients. Cooperation between production and overall vehicle development at AMG AMG production, which specialises in small-batch series and customised individual components, and the test team from AMG overall vehicle development were responsible for the development, track tests and bodywork of the two safety cars and two medical cars (one main vehicle and one replacement in each case). The engineers and technicians responsible were greatly helped by the company’s 37 years of experience in motor sports and the development of high-performance sports cars. Numerous test drives were conducted at different Formula 1 tracks in order to determine the chassis tuning and ensure that of all the components satisfy strict safety requirements. Racing driver Bernd Mayländer was involved in every stage of the development. Two highly qualified AMG engineers are overseeing the operation of the AMG vehicles at all 18 Formula 1 race meetings. Six generations of Mercedes-AMG safety cars since 1996 Following in the footsteps of the C 36 AMG (1996), the first CLK 55 AMG (since 1997), the CL 55 AMG (since 2000), the SL 55 AMG (since 2001) and the CLK 55 AMG (2003), the new SLK 55 AMG is the sixth official safety car from Mercedes-AMG. An AMG E-Class coupe with a V8 engine was employed as a medical car as far back as 1984. The activities of Mercedes-AMG testify to the long-standing involvement of DaimlerChrysler in the Formula 1. Source: DaimlerChrysler Media
__________________ Don't Immitate, Innovate®. |
| | #6 (permalink) |
| Team-BHP Support ![]() | Hey That article sure made for some interesting reading (I read through the whole thing). Did you know that while it does not appear so on our televisions, the safety cars are actually pushing the pedal to the metal with the Formula 1 cars cruising slowly behind them. F1 cars have no radiator fans, and rely on the wind factor to cool their radiators/engines...thus they are incapable of going too slow lest the engines toast! So under the safety car period, Schumy and Raiko are just about beyond their idling rpm (idling = 4500 rpm), its the driver in the safety car who is really pushing his car to the absolute limits. Why, there was also one embarassing incident for the FIA when the leading safety car lost grip and crashed!! GTO
__________________ GTO Change the way you think, and watch the world change around you.
| | #7 (permalink) |
| Senior - BHPian | with F1 cars gettin more and more powerful , i guess a time will come when the safety car will be a F1 car itself. Or how about this car...........err sorry......SUV?? I guess they had developed this X5 for track purposes. It has a Le Mans V12 engine producing 700 bhp and a top speed of 278 kmph. ![]()
__________________ Enfield Cafe Racer completed. Yamaha Cafe Racer started. |
| | #8 (permalink) | |
| BHPian Join Date: Mar 2004 Location: Mumbai, India
| Quote:
Anyways my guess is that Mercedes has paid a ton of money to the FIA officials to get their car on the races and i highly doubt that they are going to sell that Marketing to their biggest rival which is BMW. Its just to show that their cars are capable of keeping up with the high speeds of the F1 cars which proves quite a lot. Anyways just my Two Cents
__________________ "You own a Ferrari when you want to be someone, you own a Lamborghini when you are someone" | |
| | #10 (permalink) |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay / New York
| Wowww...love the wheels (dont liek the new slk looks though) the cayene LM looks hot as well! Hey GTO thats awesome.....i never really realised that they were pushing it hard! And i agree radiator fans dont make sense in any high speed sport as it seems they will actually block more air ! (are there any sports that use radiator fans? other than rock crawling?).....interesting.. i wonder? cya
__________________ The memory of you will ride by our side forever. |
| | #11 (permalink) |
| Team-BHP Support ![]() | The new safety and medical car really look good. I guess they moved to a compact merc for the Safety Run. I have also seen a Diablo Safety car one in F1 dont remember when though.... Cheers
__________________ My name is Adrian Sutil. You can call me ADDY - Force India dippy@team-bhp.com |
| | #12 (permalink) |
| Distinguished - BHPian ![]() | The Westfield XTR will be perfect for the job. It's got the power and the road grip to take corners at speeds that'll leave the others running off-track. it's a differen thing that the F1 cars will still ned to cruise........ Regards... Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE |
| | #13 (permalink) | |
| Quote:
__________________ Don't Immitate, Innovate®. | |
| | #14 (permalink) |
| Guys what about the Mclaren Mercedes SLR
| | #15 (permalink) |
| Team-BHP Support ![]() | Yeah Rishabh actually when i saw this years Aus GP I actually thought that the safety car is the SLR but then it was the new SLK . They share a similar front nose I guess Cheers
| Thread Tools | |
Similar Threads | ||||
| SLK55 AMG spotted! (Oops, its not an AMG) | Rtech | Super-Cars & Imports in India | 45 | 9th August 2008 12:23 |
| Its Here:The C63 AMG!!! | merve_extreme | The International Automotive Scene | 47 | 26th July 2007 21:50 |
| Spotted : W124 E300 AMG/W202 C AMG/C124 | v12 | Super-Cars & Imports in India | 5 | 27th December 2006 10:28 |
| Mercedes CLK-DTM, SL65 AMG, S65 AMG brochures!! | Pferdestärke | The International Automotive Scene | 1 | 19th June 2004 01:36 |
| What the C55 AMG could do??? | Revvmaster | The International Automotive Scene | 12 | 15th March 2004 00:39 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462
