Go Back   Team-BHP > Buckle Up > Motor-Sports
Old 31st July 2010, 01:41   #1
Question Webber's problem at Hockenheim
A little technical aspect from the race....
On lap 46, Webber got a radio message from his race engineer: "Your car has oil consumption troubles. Brake hard and late."
Can anyone explain what's the problem and how is it solved by braking hard and late??
I had posted this in the 2010 German GP thread but got no replies..I desperately want to know this!
nvpF1crazy is offline   Reply With Quote
Old 31st July 2010, 20:01   #2
Rehaan's Avatar
Thanked: 23,095 Times
Hmmm... interesting.
Obviously the first thought that comes to mind has something to do with the braking forces possibly getting more oil to the pump (dry sump on an F1 car though).
However, even if the guy didn't brake hard, i'm sure it would do the trick -- so this doesn't seem like a very viable reason.
Do you have a source/link for this radio message? Or did you (mis)hear it on the TV?
cya
R
Old 31st July 2010, 21:46   #3
I was on the F1 Live Timings side-by-side so I noted down exactly what was written there.
Old 1st August 2010, 00:59   #4
khoj's Avatar
Thanked: 1,253 Times
^^+1
Yes that was the message on the team radio infact it is reproduced in the OP 'verbatim'.
Old 1st August 2010, 01:39   #5
bottle's Avatar
Thanked: 133 Times
some more info ?
At about half distance, the team told me about the oil-consumption problem and from that moment onwards my only concern was getting to the end of the race. I nursed the car by braking earlier, changing my downshift pattern and not using the F-duct, and it worked for a while.
After studying the telemetry, the team then told me to brake harder and later, and that was enough to get me to the end of the race.
It was frustrating not to score more than six points, but that was better than nothing
Engine trouble stopped me seeing swap writes Mark Webber | Adelaide Now
bottle is offline   Reply With Quote
Old 1st August 2010, 23:15   #6
Rehaan's Avatar
Thanks bottle!
Translated : The team told him to take it easy, he did, then they told him not to take it that easy!
Bummer. I was hoping for a mind-blowing F1 explanation!
cya
R
Old 19th August 2011, 18:33   #7
haldar_siliguri's Avatar
Thanked: 92 Times
Default Re: Webber's problem at Hockenheim
I'm sorry but the only reason I can of that is, when you brake slowly, you brake over a longer time, so effectively total heat production from the brakes is more, hence fuel consumption more. I maybe wrong but thats all I have.
Also maybe out of topic, but Webber's fault always is his start. He ruins his hard work during qualifying by a bad start....
haldar_siliguri is offline   Reply With Quote
Formula 1: 2016 German Grand Prix - Hockenheim jfxavier Int'l Motorsport 42 2nd August 2016 23:43
Driverless Audi RS7 does Hockenheim in 2 minutes Aditya The International Automotive Scene 1 20th October 2014 17:17
Webber stays with Red Bull. Now what about Kimi? McLaren Rulez Int'l Motorsport 28 10th June 2010 18:40
Webber replaced by Wurz in 2007 gr8guzzler Int'l Motorsport 8 4th August 2006 19:54
Hockenheim 2005!! qualifying ,pre and post race .. turbo_lover Int'l Motorsport 46 28th July 2005 02:15
