Old 5th May 2011, 17:15   #16
Leepower's Avatar
Thanked: 70 Times
Default Re: My '74 Yezdi Type B Project!
Dunlop 3.25 16incher is real cheap around 850 bucks only!!! Speedways costs around 1550 bucks and god knows about the quality. By the way even the Yezdi classic's pic in the website of the non-existent company has Dunlop tyre!!! So did the brand new Yezdi's come with Dunlop tyres like MRF tyres on Royal Enfield bikes???
I know Bhau (Satalkar) is the best when it comes to Yezdis. But the man is becoming older and slower and has too much job at hand. To get the job done, you will have to go and sit with him. But he did wonder with the gears. Now, my Yezdi is like any other bike . Can stop in the traffic and then change gears or fall into neutral!!!
I have also heard about Jikov and its flooding tendency. Got a petrol lock, won't forget to turn it off!!!
Leepower is offline   Reply With Quote
Old 5th May 2011, 17:34   #17
Thanked: 19 Times
Had put a brand new Jikov in my JAWA and the mech tried to do a lot of adjustment but still the damn thing gave problems, now using a paco rajdoot carb, brand new costed me Rs 850 in mumbai
82rawath is offline   Reply With Quote
Old 5th May 2011, 17:45   #18
jawabiker's Avatar
Thanked: 13 Times
Oh Man i think then i made a mistake ordering speedways they cost me 1140 for a single tyre plus frieght extra, Dunlop would have been a good bet.
Please update me the address of the shop where its available in pune.
Also when coming to bhaus work its better to wait a few days rather than redoing the work again when done in a hurry.
Which gears did u use was it vijaydep?
on Jikov your bike will fly.
if new and ordered recently i doubt the authencity of the product as in jikovs the jawas can be tuned to the best dead beats.
Ranjit
Note from the Team-BHP Support Team: Please use the "edit" button if posting within 30 minutes of the first post, instead of creating another back-to-back post. Thanks.
Last edited by karlosdeville : 5th May 2011 at 18:14. Reason: See moderator note in post
jawabiker is offline   Reply With Quote
Old 5th May 2011, 18:00   #19
Thanked: 19 Times
Hi Jawabiker
What could be the reason in a power drop, if the bike is in second gear and i try to throttle to max in between the power drops and i have to rethrottle
Old 5th May 2011, 18:14   #20
jawabiker's Avatar
Thanked: 13 Times
Does the slide open up properly??
may be the carb has some problem, as u are not facing the same problem with pacco right?
Old 5th May 2011, 18:34   #21
Thanked: 19 Times
The slide opens up perfectly and the carb is also ok
Is it due to pressure plate problem on the contrary the gear changes smoothly. Is it because of block piston issues ??
Old 5th May 2011, 20:33   #22
jawabiker's Avatar
Thanked: 13 Times
is the problem persisting now also with pacco?
Old 5th May 2011, 21:19   #23
Thanked: 19 Times
Yes it is, the problem is not with the carb, i am sure that the pressure plate needs to be changed but not sure if this causing the drop in power ??
Old 5th May 2011, 21:39   #24
jawabiker's Avatar
Thanked: 13 Times
loss of power may be due to coil etc etc reasons
Cant comment unless i need a test drive of your bike
where are you located in mumbai?
Old 5th May 2011, 21:47   #25
Thanked: 19 Times
Lol, you are welcome anytime my friend, i will PM you my number
Old 5th May 2011, 22:32   #26
Leepower's Avatar
Thanked: 70 Times
Dude, check you clutch plates. They might be worn out!!! And check the throttle cable also.
Jawabike, the gear thingy is Bhau's own famous creation. Now the gear is butter smooth too!!!
Old 5th May 2011, 23:07   #27
jawabiker's Avatar
Thanked: 13 Times
hey now atleast 5 years you will not have a gear problem as the engine gears are set by Bhau.
Hey update me the shop where u got the dunlops as i need them
Old 5th May 2011, 23:36   #28
Leepower's Avatar
Thanked: 70 Times
Check your email Jawabiker, I have sent you the shops' names.
And Amen on Bhau's gear thingy. Will take the Yezdi for a ride tomorrow. Hope all goes well...
Old 6th May 2011, 13:22   #29
jawabiker's Avatar
Thanked: 13 Times
Did u fire it>?
hows the exhaust note
also i did not recieve your mail...
Old 7th May 2011, 01:38   #30
Leepower's Avatar
Thanked: 70 Times
Ok I have again send the email to you. By the way, I can't send private messages to you cos you have chosen not to receive it!!!
I took her for a short spin today. Exhaust note is okay okay. Have to change the exhaust the tinny sound is missing. She preformed pretty well, went up a hill in 3rd gear and stuff.
Started off at Aundh Road and took her via Senapati Bapat road to FC Road and then later to Katraj. At SB road she stalled, kick umpteen number of times, still not starting. Then took her to the roadside and guess what was the diagnosis -- the newly installed fuel lock was in off mode!!! Switched it on and started off again only to be flagged down by a cop. The cop was pretty curious about the bike -- konsa bike haiiii???. konsa sal ka haiii???, average kitna deta hai??? Showed him all the necessary documents and he let me go by saying Mast gaadi haiii!!!
Drove more than 60km today, will post some pics tomorrow
Restoration Project: '96 Yezdi 350 Twin Collector Motorbikes 32 2nd March 2016 21:41
Restoration: 78 Yezdi Classic B Type Twinn Motorbikes 4 8th August 2013 12:22
xx's Yezdi 250 project xxaarraa Motorbikes 40 26th October 2012 19:52
Restoration - at long last. 1980 Yezdi Standard Type B RT13 Motorbikes 8 11th August 2010 14:43
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
