Old 7th June 2011, 10:10   #16
Thanked: 198 Times
Default Re: Pulsar 180 Engine Overheating, emits White Smoke - Please help
I would suggest the following simple checks points .
1. Check the engine oil level. Ensure that optimum range low & high oil level is not good.
2. If engine oil is low that means engine oil is finding its way inside the combustion chamber resulting in bluish white smoke
3. If oil is burning then check the piston rings for leakages , replacement is the only option.
4.Try to stick to manufacturer recommended oil only, inferior quality oil can severely damage the engine.
tj123 is offline   Reply With Quote
Old 7th June 2011, 13:46   #17
EssYouWe's Avatar
Thanked: 16 Times
You mentioned the specs to be 15W50 for the Motul 3000T in your first post. Are you sure if the oil is 20W50 only?
This is the Motul product line: http://www.motul.co.jp/eg/product_li...4stroke17.html
EssYouWe is offline   Reply With Quote
Old 7th June 2011, 13:58   #18
Spitfire's Avatar
Thanked: 707 Times
Default Re: Pulsar 180 Engine Overheating - Please help
Originally Posted by para_7k View Post
My doubt is on the Genuineness!
From my experience Motul oil has the highest number of fakes floating around of all the oils.
If I was you and I had that doubt, I could be draining the oil first thing before brushing my teeth.
Spitfire is offline   (1) Thanks Reply With Quote
Old 7th June 2011, 14:05   #19
para_7k's Avatar
Thanked: 65 Times
This is the Motul product line: MOTUL
Bajaj's Recommended spec is 20W50. The one that I bought is 15W50.
No big deal.
Thanks for that. I'm not experienced enough to find out from the can or from the look/feel of the oil.
The bike has been lying idle after I noticed these symptoms and I just did not find enough time to visit a mechanic.
This is the first job in my list for the evening. If I cannot see one, I'm going to change the oil myself!
para_7k is offline   Reply With Quote
Old 7th June 2011, 14:16   #20
Spitfire's Avatar
Thanked: 707 Times
The fake packaging is of such high order that not many (including me) will ever make out looking at one.
Even the rubbing between the thumb and index finger wont help.
Best thing to do is find out who the distributor for Motul is for your town. I remember seeing a topic somewhere here on those lines. Maybe you can search on it here.
Order only from there. The distributor in Bangalore used to deliver the oil to my doorstep. I don't have an idea whether it is done now.
Be careful though. Oil for an engine is like the blood for our body. If you are doing it for the first time take all precautions.
Spitfire is offline   Reply With Quote
Old 7th June 2011, 14:29   #21
sagarpadaki's Avatar
Thanked: 1,337 Times
One way of identifying original motul is that they have a pull up flexible hose to pour the oil and this hose can be capped n can be pushed back in .The duplicate motul ones wont have these!!
Old 7th June 2011, 14:33   #22
dhanushs's Avatar
Thanked: 4,507 Times
I guess the best way is to buy directly from the distributor, as spitfire suggested. I ALWAYS do the same while buying oil for my bike.
Old 7th June 2011, 16:34   #23
EssYouWe's Avatar
Thanked: 16 Times
No big deal.
Of course it is a big deal. Please stick to the recommended spec.
Old 7th June 2011, 17:17   #24
Gansan's Avatar
Thanked: 914 Times
It is NOT a big deal. For example if the specified oil is 20W40, we are PERFECTLY safe so long as the lower number is 20 or less, and the upper number is 40 or higher. This applies universally to all vehicles and Pulsar should be no exception.
Old 7th June 2011, 17:37   #25
EssYouWe's Avatar
Thanked: 16 Times
I would beg to differ here. The lower number is indicative of the viscosity of oil at low temperatures. While this loses relevance a few minutes after startup, Indian bikes with their crude clearances are best left undisturbed.
I know of people experiencing clutch slippage after using the incorrect oil. While it may not be a very big deal, I would still consider it as the obvious reason for the oil burning.
Old 7th June 2011, 17:51   #26
Gansan's Avatar
Thanked: 914 Times
^^clutch slippage can occur only if a car oil is used for a bike where the engine and gear oil is the same.
Old 7th June 2011, 18:02   #27
EssYouWe's Avatar
Thanked: 16 Times
Slippage can be caused in any wet-clutch setup where the oil is not according to the recommended specs. The oil that the fellow had used, *was* JASO-MA certified for wet-clutch usage.
But then again, it boils down to how much faith you have in the recommended specs and your own oil seals.
Old 8th June 2011, 00:06   #28
DRIV3R's Avatar
Thanked: 1,433 Times
Gansan is right. It's not about the grades. I've myself used various grades on my Pulsar. Thicker ones during summers and lighter ones during winters. That's the way it should be. A 5W50/10W50 should be good enough all thru the year.
And Motul's official distributor in Chennai is near MIOT hospitals. Get your stock from him, you can get it for almost the wholesale price.
DRIV3R is offline   Reply With Quote
Old 8th June 2011, 03:08   #29
torquecurve's Avatar
Thanked: 670 Times
When you change your oil grade you can change to a lower/higher number on the lower temp number (xxW30 to XW30) but as far as possible dont touch the top number.
White exhaust smoke and smoke from the oil inlet could also be caused by oil entering the top of the piston with the fuel. Check for leaking O rings or gaskets. Oil is not designed to burn resulting in improper combustion and so white smoke.
Also some oils have higher detergent capability than others. If the oil you switched to has higher detergence then it will clear away gunk which is on some parts of your engine. The issue here is your regular never cleaned it and so your engine is used to it, many times rubber seals are scuffed but still maintain good seals. With the higher detergence this will clear off the gunk which could lead to gaps and so you see this. If this gap happens inside your cylinder, between the piston and block it could lead to fuel entering the oil (marginal amounts) which because the oil is hot will evaporate immediately leading to hissing sound from the filling cap and silencer.
Check for this.
torquecurve is offline   Reply With Quote
Old 8th June 2011, 07:23   #30
para_7k's Avatar
Thanked: 65 Times
You may be right in your own way but I did not want to get too technical.
IMHO, being a twin spark engine, the Pulsar engines become hot very quick and this grade should not make much difference (at least to me!)
Thanks for the pointers guys. As of now, I have drained the oil and replaced with Bajaj OE 20W50 which I bought from an ASC. It was a 20 minutes DIY.
I'll have to see how it goes and will look for the next steps if the symptoms persist.
White / Blue smoke - Diesel engine RedOne Technical Stuff 16 10th November 2014 15:30
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
Turbo emits lot of smoke and top speed has gone down RajTurbo Technical Stuff 40 22nd March 2007 18:28
