Old 9th November 2010, 18:39   #16
iron's Avatar
Thanked: 33 Times
You are Welcome. i am Glad to help you out.
Did you record the video when you were tuning points and adjusting carb settings?
Sounds too good. You can also check the condition of your spark plug after riding the bike for 3 minutes or so to know if your running lean or rich.
iron is offline   Reply With Quote
Old 10th November 2010, 08:23   #17
Thanked: 99 Times
What will be the color(s) in each condition respectively?
(Alok) is offline   Reply With Quote
Old 11th November 2010, 10:54   #18
voodoochild's Avatar
Thanked: 175 Times
Electrode colours would be whitish/black when running lean/rich respectively.
When running fine, the plug would be brownish and clean, without oil or carbon deposits.
Rahul
voodoochild is offline   Reply With Quote
Old 11th November 2010, 11:49   #19
jeepster's Avatar
Thanked: 1,035 Times
today re torqued the head nuts & bolts.
adjusted the carburetor & CB points again.
here is a video of CB point adjustment.
bike is back firing a little. (video between 48 sec to 1m 05 sec)
is carburetor set a little rich?
jeepster is offline   Reply With Quote
Old 1st December 2010, 18:12   #20
jeeva's Avatar
Thanked: 558 Times
Jeepster, that was an excellent DIY stuff.
Samrat makes aluminum alloy rocker arm sets. Less friction and less load on the valves/guides and smoother/silent working. You need to check that out.
The ignition coil mounted on the frame gives me jitters..incase of some short circuit.
jeeva is offline   Reply With Quote
Old 2nd December 2010, 22:46   #21
jeepster's Avatar
thanks.
i know, i always check ignition coil periodically.
Old 22nd March 2011, 15:19   #22
bj96's Avatar
Thanked: 130 Times
Default Re: DIY Service: Royal Enfield
Reviving this thread with a DIY I performed about six months ago on my Bullet. Hope it is useful to the boarders.
Task: Replace front disc brake oil
Model
: 2006 Electra 5s (ES+DB)
Tools needed:
DIY Service: Royal Enfield-brake_00001.jpg
1. Philips screwdriver + spanner (8-9 or 10-11 I think?)
2. A can to collect used oil and tube (e.g. from old fish-tank) to drain oil
DIY Service: Royal Enfield-brake_0001.jpg
3. Vaseline
4. New brake oil (DOT3 or DOT4. I used leftover from Safari top-up).
5. Syringe or "Holee" color gun to suck out old oil.
6. A piece of old rag
Steps:
1. Cover the painted surface (fuel tank) with rag
DIY Service: Royal Enfield-brake_01.jpg
2. Unscrew the oil reservoir cover on the handlebar
DIY Service: Royal Enfield-brake_02.jpg
DIY Service: Royal Enfield-brake_03.jpg
DIY Service: Royal Enfield-brake_04.jpg
DIY Service: Royal Enfield-brake_06.jpg
3. Loosen lock nut on drain nipple near caliper
4. Apply Vaseline around the drain nipple (makes airtight joint)
5. Attach the tube and the collector jar to the nipple
DIY Service: Royal Enfield-brake_07.jpg
DIY Service: Royal Enfield-brake_08.jpg
6. Suck out the old oil, leaving a little in the reservoir
7. Fill new oil
8. Press brake lever and pump out old oil
9. Repeat steps 7-8 till the old oil is pumped out completely.
10. Ensure no air bubbles, dirts get into the system
11. Replace the cover on reservoir and tighten lock nut on drain nipple.
12. Dispose of old oil in the can responsibly. Do not flush.
-BJ
bj96 is offline   (3) Thanks Reply With Quote
Old 22nd June 2011, 18:26   #23
jeepster's Avatar
Default DIY Service: Royal Enfield
hi this is my 1001th post for enfield.
tools for carburetor cleaning.
  • spanner 14-15 & 10-11
  • a water spray filled with kerosene
  • small screwdriver
  • big screwdriver
  • bottle for west petrol & kerosene
  • a plate
  • a brush
DIY Service: Royal Enfield-dsc04353.jpg
DIY Service: Royal Enfield-dsc04356.jpg
move the air-filter & remove the carburetor.
DIY Service: Royal Enfield-dsc04306.jpg
DIY Service: Royal Enfield-dsc04307.jpg
DIY Service: Royal Enfield-dsc04308.jpg
remove the throttle assembly.
DIY Service: Royal Enfield-dsc04309.jpg
remove the 4 screws.
DIY Service: Royal Enfield-dsc04310.jpg
beware of petrol.
check for water.
DIY Service: Royal Enfield-dsc04311.jpg
remove the pin & then the float.
DIY Service: Royal Enfield-dsc04312.jpg
DIY Service: Royal Enfield-dsc04313.jpg
now remove the valve (?).
DIY Service: Royal Enfield-dsc04314.jpg
if necessary clean it with brush & kerosene.
DIY Service: Royal Enfield-dsc04315.jpg
DIY Service: Royal Enfield-dsc04316.jpg
DIY Service: Royal Enfield-dsc04317.jpg
DIY Service: Royal Enfield-dsc04318.jpg
use the kerosene spray to clean. (all the holes)
DIY Service: Royal Enfield-dsc04319.jpg
now re fit it.
DIY Service: Royal Enfield-dsc04322.jpg
DIY Service: Royal Enfield-dsc04323.jpg
DIY Service: Royal Enfield-dsc04324.jpg
DIY Service: Royal Enfield-dsc04325.jpg
DIY Service: Royal Enfield-dsc04327.jpg
use small screwdriver to remove the jet.
DIY Service: Royal Enfield-dsc04329.jpg
DIY Service: Royal Enfield-dsc04333.jpg
check if the hole is blocked.
DIY Service: Royal Enfield-dsc04334.jpg
DIY Service: Royal Enfield-dsc04336.jpg
dont play with this screw.
DIY Service: Royal Enfield-dsc04337.jpg
fit the float.
DIY Service: Royal Enfield-dsc04338.jpg
clean the bottom.
DIY Service: Royal Enfield-dsc04340.jpg
now fit it back.
the carburetor is cleaned.
to be continued..
jeepster is offline   (5) Thanks Reply With Quote
Old 22nd June 2011, 18:36   #24
jeepster's Avatar
part 2...
now align
the notch & fit the throttle assembly.
DIY Service: Royal Enfield-dsc04343.jpg
DIY Service: Royal Enfield-dsc04344.jpg
DIY Service: Royal Enfield-dsc04345.jpg
check for the gasket & plastic spacer. (if damaged replace them)
DIY Service: Royal Enfield-dsc04346.jpg
DIY Service: Royal Enfield-dsc04347.jpg
DIY Service: Royal Enfield-dsc04348.jpg
now fit the carburetor.
DIY Service: Royal Enfield-dsc04349.jpg
DIY Service: Royal Enfield-dsc04350.jpg
use new rubber if needed.
DIY Service: Royal Enfield-dsc04351.jpg
DIY Service: Royal Enfield-dsc04352.jpg
& you are done.
(dont forget to fit the petrol pipe.)
rgds,
Nikhil
jeepster is offline   (9) Thanks Reply With Quote
Old 27th June 2011, 23:05   #25
jeepster's Avatar
no replys!!
looks like my post was not that good.
anyways had to change re set the CB points as i had changed it when i serviced the carb which was a bad thing to do.
i badly need the new cylinder head as current one is non standard one & is giving trouble to set the tappets.
rgds,
Nikhil
Old 28th June 2011, 14:12   #26
bj96's Avatar
Thanked: 130 Times
Thanks for the nice pictorial.
Sharing my experience regarding the float needle fitment: pay attention to the needle valve- the pointed tip goes up. I had fitted it in the down direction (doing first time) and petrol started leaking slowly. The needle is so designed that it can be fitted wrong side down . Ideally they should have designed such that it will be difficult to fit in the wrong direction.
TIP: just to clean the float valve (reason stuck needle, water in the petrol etc) no need to remove the entire carb. Just unscrew the bottom four nuts and take the bowl out.
-BJ
bj96 is offline   Reply With Quote
Old 26th September 2012, 22:58   #27
Thanked: 99 Times
After changing the engine oil I started the engine and noticed continuous oil flow from feed pump bolt. I loosen the bolt at the time of draining the oil and retighten it.
Oil is not going upwards and getting out from bolt. What to check & how to fix?
Please also tell to whom this feed pump feed the oil, to rocker oil pipe or piston rings?
thanks
Old 27th September 2012, 11:46   #28
Thanked: 456 Times
no replys!!
Your posts are brilliant man, thanks for them and please keep them coming.
I'm just waiting to learn enough so that I can stop visiting the RE service centers for minor jobs and can finally do without their shoddy service.
BTW, do you take the pictures yourself while doing the work? I know that can be a pain, if I was in the same city as you, would gladly volunteer to come and take pics while you carry out the work. If anyone in Bangalore is planning a similar DIY tutorial, just drop me a PM, would be glad to come and take pics to be posted here.
am1m is offline   Reply With Quote
Old 16th November 2012, 00:03   #29
Thanked: 99 Times
thanks
Problem solved. Copper washer inside the bolt was the culprit. It is not easy to found the same the washer, local dealer refused for that. Finally packed with fiber washers & checked the oil flow at rocker end.
DIY Service: Royal Enfield-photo-012.jpg
DIY Service: Royal Enfield-photo012.jpg
Old 16th November 2012, 03:53   #30
ArizonaJim's Avatar
Thanked: 2,105 Times
The "bolt" you removed is a transfer tube or jet that provides oil to the crankshaft.
Once in the crankshaft, the oil moves to the big end of the connecting rod journal where it provides the lubrication for the floating sleeve bearing at that location.
As the oil is thrown off of the connecting rod bearing it splashes onto the cylinder walls where it provides the lubrication and cooling for the piston and piston rings.
The heavy mist (cloud) of oil vapor created by all of these moving parts provides the lubrication for the rolling element bearings that support the crankshaft. Ball and roller bearings do not require a lot of oil to work efficiently.
In addition to the oil supplied to this oil transfer bolt, oil also travels thru a drilled hole to the banjo fitting on the forward side of the engine.
From this banjo fitting it travels upward thru a tube (on the Iron Barrels and AVL's) to provide oil for the rocker arms and valve stems.
The excess oil from this area drains back down thru the tunnel for the pushrods providing cooling for the cylinder and lubrication for the valve lifters.
ArizonaJim is offline   (1) Thanks Reply With Quote
My foray into the biking world - Royal Enfield Thunderbird 500. EDIT: Charger DIY too abirnale Motorbikes 86 23rd January 2017 10:58
Royal Enfield DVD - The Bible of UCE Engines (DIY) adrian Motorbikes 41 28th April 2015 11:26
DIY: Royal Enfield Bullet - Ignition key assembly cleaning / replacing adrian Motorbikes 3 11th January 2015 11:18
When did Royal Enfield become "Enfield"? pullin Motorbikes 1 25th June 2010 13:34
500cc Royal Enfield vs NEW 350cc Enfield scottoe Motorbikes 22 13th October 2009 16:47
