Old 15th February 2012, 12:48   #181
rk_sans's Avatar
Thanked: 778 Times
Default Re: Update - Odo reading 8825 Kms
Originally Posted by naveenroy View Post
Did you also change the pilot lamps - as some "enthusiastic" friends from the CBR club have done?
No, Naveen. Those pilot lamps are white/bluish color, so i did not like it.
rk_sans is offline   Reply With Quote
Old 15th February 2012, 13:09   #182
Hells_Fury's Avatar
Thanked: 58 Times
Originally Posted by rk_sans View Post
One of the long pending upgrade was fulfilled today. Upgraded the stock bulb to philips extreme vision.
Can you please let me know the part number and where you picked it up from? I am also going to fit in it my bike.
Hells_Fury is offline   Reply With Quote
Old 15th February 2012, 14:32   #183
ku69rd's Avatar
Thanked: 1,229 Times
Which is the wattage? would the stock be 55/60 Watts? has it been the same or changed?
ku69rd is offline   Reply With Quote
Old 15th February 2012, 15:02   #184
SunnyBoi's Avatar
Thanked: 2,832 Times
Default Re: New addition to my garage, the new CBR250r
You should have given Halonix +60 60/55 a try, its a Xenon bulb and emits similar whitish light. Costs ~100 or so.
Is the stock bulb 35W?
SunnyBoi is offline   Reply With Quote
Old 15th February 2012, 15:30   #185
rk_sans's Avatar
Thanked: 778 Times
Just ask for Philips Xtreme vision 60/55 H4.
I bought it from chawla motors. After minerava circle towards town hall, first signal take a left and then left on the third cross. Right hand side you can find Chawla motors. You also get this in A.K Traders on the same lane.
yes Mahesh, it is 60/55 w
Halnoix is pure whitish light right ?
And stock is 60/55 W
Old 15th February 2012, 15:36   #186
SunnyBoi's Avatar
There is the standard Halonix bulb which is normal yellow light and there is +60 Xenon which gives you a whitish light. It isn't pure white light.
If you want to give it a try, its available at a shop on A.M Road, close to vijaydeep. Shop is in a basement but he has a Halonix board on the building.
SunnyBoi is offline   (1) Thanks Reply With Quote
Old 21st February 2012, 16:05   #187
rk_sans's Avatar
Thanked: 778 Times
Default Update - Odo reading 9504 Kms
Last weekend did a 600 kms overnight stay with other tbhpians. Bike performed very well without any issues. Also did around 50 kms to-fro dirt riding also.
Now i can hear some squeaking noise in the front shocks when i go over potholes, need to get it checked.
Also tail light stopped working on the return journey. Haven't checked what is the problem, could be a blown out bulb.
Old 21st February 2012, 16:09   #188
ku69rd's Avatar
Default Re: Update - Odo reading 9504 Kms
Santosh,
Would it be from the actual suspension or the Steering Stem where you have the cone set making the noise? Also did you give a proper pressure wash to ascertain no dirt is causing the issue?
Good to know that you clocked 35KMPL at the end of day. Should say very good mileage considering the hi-speeds and broken roads it had to endure.
Old 21st February 2012, 16:56   #189
rk_sans's Avatar
Thanked: 778 Times
Santosh,
Nope, not given it a pressure wash still. Could be steering stem or even dirt, need to check.
Was little surprised to get 35 kmpl, even after high revving and running in lower gears for most of the last 40-50 kms
Old 21st February 2012, 17:00   #190
ku69rd's Avatar
Hmmm, Shall follow your thread as the build quality of Honda on CBR has been good. Will be surprised if there could be anything going kaput for the roads that we did.
Yep 35 was a surpriser for me, was expecting somewhere around 30-32.
Presume Niranjan also managed some decent mileage?
Old 21st February 2012, 22:01   #191
niranjanrvce's Avatar
Thanked: 334 Times
Mahesh, I didn't do a proper calculation but roughly I think I got around 32. I think the last stretch where Aditya and me went mostly full throttle would have made a difference.
niranjanrvce is offline   Reply With Quote
Old 22nd February 2012, 14:56   #192
rk_sans's Avatar
Thanked: 778 Times
Got the tail bulb changed. Found that the squeaking noise had disappeared from morning, So will wait for some more days to get it checked.
Old 23rd February 2012, 17:11   #193
ku69rd's Avatar
Thought only Tata Safari was the self healer appears that CBR is also vying for the same tag eh!!
But on the contrary do give it a thorough eye for any anomalies
Old 8th March 2012, 14:40   #194
rk_sans's Avatar
Thanked: 778 Times
Default Odo Reading - 10014 Kms
After the tbhp chickmangalur trip, found the fairing had become little loose and also found little bit of tappet noise. Left the bike for service.
Found the "Ex" Shims had to be replaced. Again bike back to normal smoothness.
Completed 10k
New addition to the bike. Locally made Radiator Guard. Costed INR 1500
rk_sans is offline   (2) Thanks Reply With Quote
Old 8th March 2012, 14:47   #195
ku69rd's Avatar
Default Re: Odo Reading - 10014 Kms
Completed 10k
Santosh,
Congratulations on completing the 10K mark with minimal fuss/niggles. Wishing you many more miles of peaceful rides. Would it be natural for the shims to be replaced within 10K?
The Radiator Guard seems to be a very good fit and for the money spent its paisa vasool. Was this fabricated by your friend or readily available off the shelf?
Humble Request: Can you please take off the white sticker? Looks like an eye sore?
ku69rd is offline   (1) Thanks Reply With Quote
Honda's 250cc Bike : CBR250R! akhilesh Motorbikes 837 28th October 2015 12:44
New Outlet for my experiments - World's 1st CBR250R Standalone ECU on the way! pranavt Motorbikes 33 8th November 2012 18:44
Honda CBR250R ABS vs KTM Duke 200. EDIT : The CBR it is! Furebo Motorbikes 90 2nd August 2012 15:49
CBR250R gives relief to the RX after 14.5 years: Tale of two bikes IronWolf Motorbikes 62 31st May 2012 18:20
Have booked Honda CBR250R and need some suggestions animeshb Motorbikes 1 15th February 2012 12:46
