Old 16th August 2012, 14:52   #211
rk_sans's Avatar
Thanked: 784 Times
Default Re: New addition to my garage, the new CBR250r
Originally Posted by djay99 View Post
Hi RK,
Enjoyed reading your thread. Red CBR looks really good.
Triple colour was on display and quality and fit and finish looked improved compared to the test ride bike(1st lot).
They improved quality a lot after the 1st lot.
Which dealer do you suggest buying a honda from? if decide cbr. I did not like the way saphire honda sales person interacted with me.
You know all dealers are same, would suggest in this order Sapphire/Anand/Silicon/City/Haiku/Planet.
Try Anand, heard from a good friend, who is into such business that they are good.
rk_sans is offline   Reply With Quote
Old 17th August 2012, 19:34   #212
rk_sans's Avatar
Thanked: 784 Times
Default Update - Odo reading 17410 kms
Got the 4th Service done. Had to change the chain, front and rear sprockets. Also replaced the fork oil as it had seen awesome roads in Spiti and Leh areas.
Cost of Chain and Sprockets was appx INR 2000
Fork Oil was appx INR 400
Paid service charges was little high INR 500
So total bill was around INR 3600 with misc things.
Old 14th November 2012, 14:15   #213
rk_sans's Avatar
Thanked: 784 Times
Posting the link of my trip on CBR to Spiti and Leh
http://www.team-bhp.com/forum/travel...r-horizon.html (6 riders, 4000 kms - A glimpse of Spiti and Leh from a Biker horizon)
rk_sans is offline   (1) Thanks Reply With Quote
Old 29th December 2012, 11:02   #214
ku69rd's Avatar
Thanked: 1,230 Times
Originally Posted by rk_sans View Post
Santosh,
Appears that you and your set of friends had good fun on the Led ride. How did the bike perform in high altitudes? Did you folks face any issues whilst cold starting the engine first time of the day?
Can you please elaborate on that part? How was the handling with all the luggages and it's setup?
ku69rd is online now   Reply With Quote
Old 31st December 2012, 13:00   #215
rk_sans's Avatar
Thanked: 784 Times
Originally Posted by ku69rd View Post
Santosh,
It was really fun and depth of experience riding in Leh.
No cold start issues in any of the bike. One crank and the engines were bubbling with activity.
Frankly speaking i personally did not feel any difference in handling but only thing was if you put down your bike, then lifting it alone would be problem because of the additional weight.
Old 31st December 2012, 20:14   #216
ku69rd's Avatar
Ahhh, guess that's the mistake which many of us bikers do when our motorcycles fall down. There is an entirely different way on how we can lift the fallen motorcycle. The bike has to be lifted with our back facing it and then lifting. This ways even a 200+ kilo bike can be lifted without exerting ourselves and alone. Will talk you through if you are still unsure on it when we catch up.
ku69rd is online now   (4) Thanks Reply With Quote
Old 5th February 2013, 12:54   #217
rk_sans's Avatar
Thanked: 784 Times
Adding link of the travelogue did few weeks back.
http://www.team-bhp.com/forum/travel...-kundadri.html
Old 6th March 2013, 11:16   #218
rk_sans's Avatar
Thanked: 784 Times
Default Update - Odo reading 24036 kms
Was time for 5th paid service.
Had a small sound in the cone sets. Eventually had to be changed. Cost INR 1100 for both the pipes.
Started hearing knocking sound in the engine. Got the shims checked and they had to be replaced. 2 exhaust and 1 inlet had to be changed.
Total Service cost was INR 3728
Now its time to think about the tire changes, specially the rear one.
Old 6th March 2013, 14:44   #219
naveenroy's Avatar
Thanked: 782 Times
Default Re: Update - Odo reading 24036 kms
Whats the odo reading? Not changed the tires till now? What are you planning to get?
naveenroy is offline   Reply With Quote
Old 6th March 2013, 15:42   #220
ku69rd's Avatar
Santosh, Think this is the third time am observing about the Shims, is it a regular maintenance affair or is it just a one off case where your example seems to have some issues?
Well Rear tire, think you can put in another 10K before you wanna replace them. You going in for conti or michelin?
Old 6th March 2013, 17:19   #221
rk_sans's Avatar
Thanked: 784 Times
24k
Had mentioned to you about the issue but changing it for the second time. I remember reading the manual as every 12k, Valve clearance has to be inspected and if required adjusted accordingly. So in that case looks like a regular maintenance affair.
No Mahesh, rear tires cannot take another 10k probably couple of thousands kms that's it.
Which tire is actually a big question but do not have options as of now in indian market.
1. Contigo
2. Dunlop Tuff Grip
3. MRF Zapper Q (Tube) (Not sure on this still if it fits)
4. PSD (Hardly available, if available over-priced and Soft Compound)
Old 6th March 2013, 17:26   #222
ku69rd's Avatar
Santosh,
Suppose you want to stick to stock dimensions of 140/70*17? Have heard a lot about the ZapperQ, and their performance in all round conditions including dirt, slimy, gravel conditions. Are you sure this is a tube tire?
Zapper Q is available in 140/70*17 size, did consider them briefly for my RD but then the current set are doing just fine and more importantly did not feel the need to splurge those Gandhis
Old 6th March 2013, 18:33   #223
rk_sans's Avatar
Thanked: 784 Times
If you had considered for RD, it confirms that it should be tubed right ?
Old 6th March 2013, 18:55   #224
aargee's Avatar
Thanked: 2,143 Times
Mine is due for shim change at 42K; when I get the work done, this will be the second time; first was during 22.8K
Rear tire lasts a good a little over 19K that's all; anything above that is inviting trouble
2. Dunlop Tuff Grip
Choose one of these; there're no better choices; MRF is tube type though it supports tubeless while Dunlop is tubeless.
If you're replacing the front, MRF Revz 110/70-17, think no further, brilliant tire for the moment in the market
Forget it for now
aargee is offline   (1) Thanks Reply With Quote
Old 6th March 2013, 19:02   #225
ku69rd's Avatar
Tubeless tires can be used on regular spoke wheels with a tube in it
Honda's 250cc Bike : CBR250R! akhilesh Motorbikes 837 28th October 2015 12:44
New Outlet for my experiments - World's 1st CBR250R Standalone ECU on the way! pranavt Motorbikes 33 8th November 2012 18:44
Honda CBR250R ABS vs KTM Duke 200. EDIT : The CBR it is! Furebo Motorbikes 90 2nd August 2012 15:49
CBR250R gives relief to the RX after 14.5 years: Tale of two bikes IronWolf Motorbikes 62 31st May 2012 18:20
Have booked Honda CBR250R and need some suggestions animeshb Motorbikes 1 15th February 2012 12:46
