Old 2nd January 2012, 09:19   #196
aargee's Avatar
Thanked: 2,124 Times
Default re: Honda CBR 250R Review
Originally Posted by akshay4587 View Post
Since,you have ridden a lot,what do you think is the sweet spot for crusing on highways-as in the maximum comfortable speed,before the bike starts begging for mercy.
It depends from people to people; initially (after the replaced engine) I thought the bike was begging after 135 or so; but these days I feel there's nothing to be called as mercy for the very reason there's no stress on the engine even at 150. But if you mean the screaming, then, probably I can quote an example...
Few days ago I was riding my friend's N250R along with my C250R with him; I couldn't hear any noise of my C250R though we were riding a little closer. But I was able to hear noise of N250R right from 100ish. Yes, both of us were doing about 130. Coming back to the point, if you really want to hear (or scream) the noise of C250R's engine, it starts from 115 & above.
Originally Posted by xtremeshock View Post
I have bought...his personal vehicle for one.
+1; Didar is good. And remember, most people who don't even own the bike are calling it by names just from the reviews of other people. They only take one bad comment & spread it like cancer in which most good things are lost!!!
aargee is offline   (1) Thanks Reply With Quote
Old 2nd January 2012, 21:48   #197
aargee's Avatar
Amidst of all struggles & difficult times, ODO goes on; this happened today...
Sry about the bad quality of pic, as I only had camera on my mobile that didn't have flash; neither the surrounding supported for a good pic.
Old 3rd January 2012, 10:32   #198
n_aditya's Avatar
Thanked: 2,748 Times
Wow. That was quick. Its only a few months and she's already crossed the 12k mark. Looks like you're thoroughly enjoying the bike inspite of the small issues and niggles.
Have you switched to synthetic oil or still on the factory spec?
n_aditya is offline   (1) Thanks Reply With Quote
Old 3rd January 2012, 10:48   #199
nomadabhi's Avatar
Thanked: 73 Times
aargee, when you updating about noise is it the exhaust note you talking about or any *noise* from bike. If its about the exhaust note and *noise* both then next time get my Nomad along
Such struggle and diffi-cult time are long forgotten with one smooth ride and create special relation with ride. Good to see that 12k mark. Wishes for crunching more and more kms under the Ceebar-Tooth.
nomadabhi is offline   (1) Thanks Reply With Quote
Old 3rd January 2012, 11:28   #200
aargee's Avatar
Certainly Adi; every time I take it out, it never fails to put me to smile.
Factory spec is both 20W40 mineral as well as 10W30 synth; I've moved to 10W30 FS specifically & would very strongly recommend it to everyone.
Its exhaust note; but...to clear my confusion, which post are you referring to?
Such struggle and...more kms under the Ceebar-Tooth.
Tks; when I'd a plan to buy a bike in mind, I always had one thing in mind that, my wallet should be able to afford for any kind of trouble the bike undergoes. Fortunately the only issues for which I'd to pay were...
- Sprocket kit
- Fairing & headlamp
- Brake pads
- Regular service
I wouldn't take this lightly because one of the biggest issue on braking is yet to be resolved. The front brakes aren't that effective especially for the speed the bike shoots to.
Old 4th January 2012, 17:09   #201
@aargee Am planning to buy one. Just wanted to know what is the difference between the ABS and Non ABS version. Is the ABS that significant? Thanks.
vijayvb is offline   Reply With Quote
Old 4th January 2012, 17:50   #202
aargee's Avatar
Vijay - Don't want to give long & lengthy advice/suggestion/opinion; go for ABS; you'll not regret.
Old 11th January 2012, 21:18   #203
aargee's Avatar
1268x on ODO & now I begin to hear some noises; not sure if they're from fairings or is it due for replacing the shims (yes, it has not been changed until now & personally proud of it). But no signs of drop in FE or top speeds or noise in the engine.
I'm already in need of small rubber bushes between the fairings & the order seems to have been placed during Dec 1st week, but the dealer hasn't got it yet.
Hopefully this noise thing should be gone when the bushes are replaced.
Another interesting (not enthu though) observation is that, sometimes during last week the rear tire ran flat on high speeds; the reason for puncture is unknown (still a mystery). The tire just opened up & the air leaked off; after the puncture is fixed, there's a small amount of air leak + there's another location where the puncture should be fixed. Quite surprisingly the air lasts for over 4-5 days with a drop of 10 Psi.
I'll be taking it to ASC sometimes this week or next to address these issues.
Old 11th January 2012, 21:46   #204
rk_sans's Avatar
Thanked: 602 Times
Even i found the noises but was fixed by replacing the plastic clips/bushes on the fairings. Try that. Costs around INR 30 for the full set of plastic clips.
rk_sans is offline   Reply With Quote
Old 12th January 2012, 11:06   #205
n_aditya's Avatar
What do you mean tire opened up? Was it a tire burst?
If you still have air leaking, the puncture in all probability was not repaired properly. Also check if the valve is good or leaking air. Do you have the puncture sealant liquid in your tires?
Old 12th January 2012, 18:01   #206
aargee's Avatar
IMHO, its the rubber bushes that might need replacement, not just the plastic clips; also the plastic clips are not available as individual units, they're bound with the fairings & the cowls. Most importantly, these spares are not available from HMSI...atleast, that's what the dealer says.
Well...I don't want to think in those lines
That guy did a good job, no doubt; one strip was barely sufficient to close the hole & it has very very minor leak from the patch; also, there's another location where the air is leaking very minor. Don't know when that would...
That's what the dealer suggested me; the sealant is for tubeless tires, but, he tried it on his Splendor with 17 nails (and pulled out) & he's still riding it. Not sure how much of it is true!!!
I might try that product this weekend or early next week.
Old 13th January 2012, 12:00   #207
n_aditya's Avatar
I That guy did a good job, no doubt; one strip was barely sufficient to close the hole & it has very very minor leak from the patch; also, there's another location where the air is leaking very minor. Don't know when that would...
If you are saying that one strip was not enough to plug the air leak and there is another puncture which is leaking air and might give way, i seriously suggest you to get a new tire, irrespective of whether the manufacturer or dealer offers you a replacement or not.
Safety is prime. A new tire will cost a few thousand bucks.... a lot cheaper than hospital bills.
Be safe bro.
Old 19th January 2012, 08:15   #208
aargee's Avatar
Default Do these happen due to my enthusiasm for experiments or just me?
I landed up buying Motul C2 chain lube road (Black below) & which is genuine one. Any idea how this is different from the old one (Silver+Red)?
And ofcourse the chain clean C1 from the old Silver+Red combo
Spec & content wise I couldn't find any difference on the net. Any help pls?
Old 19th January 2012, 10:41   #209
n_aditya's Avatar
Default Re: Do these happen due to my enthusiasm for experiments or just me?
Motul has upgraded the color of the canister from Silver to Black. Apart from this there is no change or difference whatsoever in the quality of the product. Both are genuine.
Old 19th January 2012, 12:07   #210
aargee's Avatar
Sure Because I don't seem to find this mentioned anywhere on the net
Honda CBR 250R - Initial Ownership Review mantrig Motorbikes 267 7th March 2017 06:23
Honda gives CBR 150R, CBR 250R new colours, decals for 2015 ashwin.terminat Motorbikes 23 31st October 2015 22:32
Honda recalls CBR 150R & CBR 250R for defective starter relay Added_flavor Motorbikes 0 15th August 2015 11:42
2014 Honda CBR 250R shares design with the recently unveiled CBR 300R JayPrashanth Motorbikes 6 25th October 2013 17:21
CBR 250R or CBR 600F2 sharad_kmc Superbikes & Imports 8 14th March 2013 21:04
