Old 28th August 2012, 20:44   #256
Mpower's Avatar
Thanked: 1,686 Times
Default Re: Honda CBR 250R Review
I can see how the CBR250 appeals to the gentleman biker. A baby VFR.
Elegant grown up styling, fantastic blend of civility and usability all the while packing a punch when needed.
Mpower is offline   (1) Thanks Reply With Quote
Old 29th August 2012, 15:24   #257
Thanked: 56 Times
I'm 39 and feel am just getting started!! Dreaming of buying a Superbike someday..
But then when you are 22, U think 40 is really old... Not to worry. Time catches up with everybody..
Puffdamgcdragon is offline   Reply With Quote
Old 31st August 2012, 11:28   #258
aargee's Avatar
Thanked: 2,136 Times
This happened few days ago...
It was a trip to Shirdi-Mumbai-Pune & back; as usual Tks to the undisputed king of Indian roads, HVKumar Sir, for the routes; some tit bit pics between Ahmed Nagar - Sangamanere - Akole - Bhandadhara - Ghoti
And some pics between Pune - Wagholi, enroute to Ahmed Nagar
After this trip, I'm in love with MH
aargee is offline   (2) Thanks Reply With Quote
Old 1st September 2012, 23:53   #259
damanshaheed's Avatar
Thanked: 54 Times
[quote=aargee;2888354]This happened few days ago...
wow is that 32,000 kms I see, good going bro. How often have you been changing the brake pads? Mine has done 11,000 kms and needs a change both front n rear. I was also reading thru your tire thread. How long did the second conti last n have you changed the front as well.
Another thing which is quite niggling is rust. My bike has been thru its first monsoon n there is quite a bit of rust all round n considering the fact that your part of the world has more rains, how has she coped. As for me my weapon of choice is a can of WD40
damanshaheed is offline   Reply With Quote
Old 2nd September 2012, 22:16   #260
aargee's Avatar
First - 10890
Second - Around 22K
Third - Awaiting
Rear - 17640, 29890 & now running on MRF 140/70-17
Front - 29890 MRF 110/70-17; ideally it should've been changed around 20K
Where? Which places?
I double wax once in two months & planning to buy http://www.collinite.com/marine-wax/liquid-metal-wax/
Old 2nd September 2012, 22:20   #261
sagarpadaki's Avatar
Thanked: 1,330 Times
Which is the mrf model which you have put as front and rear tyres? How do they compare with the stock continental?
sagarpadaki is online now   Reply With Quote
Old 2nd September 2012, 22:25   #262
aargee's Avatar
There's only one model available in MRF for the stock size of CBR
Front is SUPERB (probably same as KTM, need to check) & most importantly it's RADIAL. Had two foot in mouth times & the front behaved as it has to & both were on wet weather. I'm sure Conti would've danced on those circumstances.
The rear is almost same as Conti, except that, MRF gives a little peace of mind than Conti. The rear tire change at 29890 was completely unnecessary as the wear & tear was very less. But there were 2 large cut marks on the tire; as a matter of fact, I did the entire GQ trip with one large cut mark & really God saved me!!!
It's little early for me to comment about the rear tire as I've only done nearly 3K km both in rains & dry weather. Let me do some more miles before commenting on rear.
Old 2nd September 2012, 22:29   #263
Can you please share the tire model names if possible?
Old 2nd September 2012, 22:37   #264
aargee's Avatar
Front I don't remember, it's some REV followed by some alpabet
Rear is Zapper Q
Look out for these info in http://www.mrftyres.com
Hope you're aware that most people opt for (Pirelli Sports Demon) the remaining pieces of PSD that has been banned from importing for last 8-10 months now.
Old 2nd September 2012, 23:18   #265
Rear is Zapper Q
PSD banned??!!! Why?
Old 3rd September 2012, 16:21   #266
dreamseller's Avatar
Thanked: 426 Times
No ISI certification on them. Apparently the last consignment is still sitting with customs and have not been cleared due to the fact that tyres sold in India should mandatorily carry the ISI tag.
EDIT: And the Duke front tyre, IIRC, is RevZ-C.
dreamseller is offline   Reply With Quote
Old 18th September 2012, 07:51   #267
aargee's Avatar
Not a good pic as I took from my phone camera (was too lazy to pull out my P&S from tailbag) last Sunday; time 7:46 AM
aargee is offline   (1) Thanks Reply With Quote
Old 26th September 2012, 10:54   #268
aargee's Avatar
Some pictures from my last ride...
Old 4th October 2012, 11:15   #269
aargee's Avatar
Got the CBR serviced for 345xx Km; no engine work, just the fairing noises has to be arrested (and needless to say, there's still even after the service); I guess the entire rubber bush kit inside the fairings needs to be replaced. Not sure though
Other than this, the mouth for the rear tire has to be changed as the pressure on the tire is loosing gradually. JSP Honda doesn't have tools to fix this issue, most near by tire stores don't have paddock to remove the wheel. Err...aaarggh!!!!
Replaced side stand as I'd been using it extensively to tilt the bike for lubrication & it was bent; I guess I learned my lesson to buy a paddock.
Replaced engine oil filter & air filter in addition to the engine oil.
Switched to Motul 10W40 FS 300V Factoryline engine oil; for now the gear shifts are amazingly smooth; typical Motul. Have to check extensively for next few 1000 Km for the smoothness of the engine.
Old 4th October 2012, 21:29   #270
Thanked: 38 Times
What was the total service cost, and how much for oil filter and air filter?
rajpandey10 is offline   Reply With Quote
Honda CBR 250R - Initial Ownership Review mantrig Motorbikes 271 26th January 2018 13:16
Honda gives CBR 150R, CBR 250R new colours, decals for 2015 ashwin.terminat Motorbikes 23 31st October 2015 22:32
Honda recalls CBR 150R & CBR 250R for defective starter relay Added_flavor Motorbikes 0 15th August 2015 11:42
2014 Honda CBR 250R shares design with the recently unveiled CBR 300R JayPrashanth Motorbikes 6 25th October 2013 17:21
CBR 250R or CBR 600F2 sharad_kmc Superbikes & Imports 8 14th March 2013 21:04
