Old 16th August 2011, 12:47   #16
adrian's Avatar
Thanked: 602 Times
Default Re: Is my mechanic ripping me off? Enfield Thunderbird
Hi P1tbull, Most of the local mechanics have no idea of the UCE mechanisms. I have personally seen a local mechanic acknowledging the fact that he doesnot know how to fix it and advised the owner to take it to RE service. Not all guys need to be the same. The smart alec you call your mechanic might have seen it as a chance to rip an UCE machine apart and study the internals. You should have sticked on with the RE service. With the fact that what has been done cannot be reverted back, we will hope that everything goes well for a long time. Wish you luck
Regards Adrian
adrian is offline   Reply With Quote
Old 16th August 2011, 14:14   #17
jeeva's Avatar
Thanked: 558 Times
Originally Posted by P1tBull View Post
Sorry for the late reply. Its pretty much done. Just want to know how much I got ripped off by.
Don't regret for the damage done. Much water has flown down the bridge now.
From now onwards, I suggest you do the basic checks (oil level, leaks etc..) before taking off everyday.
jeeva is offline   (2) Thanks Reply With Quote
Old 16th August 2011, 15:28   #18
Randhawa's Avatar
Thanked: 270 Times
@Pitbull
You got ripped off big time.
1. Crank of TBTS or AVL can not be repaired no matter how expert the Lathe guy is. It wont last long and I think there was nothing wrong with your crank to start with as there is a little bit of play in the crank from new which is under tolerance level. It has a NRB which can not work with no clearance/tight clearance hence the con rod moves a bit.
Did you got robbed ?
Engine Packing - 850/- No
Engine Oil Seal - 350/- Yes
Engine Bearings - 1800/- Royally robbed. Crank NRB is around 500 and rest around 200 each genuine SKF bearings
Connecting Rod Offset - 3800/- Royally robbed as the bearing is not more then Rs 200 and if they have skimmed the rod or the pin then you now have a non standard crank pin.
Rings - 1200/- Dont know- earlier the whole kit was for 3k then increased to 8k and rings were for Rs250 so could have increased to Rs 1200
Head Valves - 820/- It's cheap
Engine Buffing - 2800/- Royally robbed
Fork Cone set - 380/- No
Fork Oil Seal - 220/- No
Gearbox Bearings - 1100/- Royally robbed
Lathe charges - 1200/- Royally robbed
Carbon deposit you saw on the piston head was totally normal and you should have done the compression test before even touching the valves. If piston rings were not seated properly then you would have seized your bike by now. UCE engine can run with just a litre of oil without any damage and gearbox+engine has just one oil to share everywhere.
Randhawa is offline   (2) Thanks Reply With Quote
Old 16th August 2011, 20:53   #19
Thanks for the advice, guys. This is my first bike in 11 years and I haven't got too much of an idea about Enfields. I have been driving Japanese cars for the last 11 years and the worst I saw was a leaking coolant hose.
Never even had to see the inside of an engine or worry about low oil levels for that matter.
I'll take this as a lesson learned and avoid this guy in the future. Probably stick to an A.S.S.
P1tBull is offline   Reply With Quote
Old 16th August 2011, 23:54   #20
Randhawa's Avatar
Thanked: 270 Times
You are on such a wonderful forum, do care to ask if not sure for future troubles if you encounter any.
Randhawa is offline   Reply With Quote
Old 12th December 2011, 23:38   #21
lazyrider's Avatar
Thanked: 20 Times
I have a similar question, there was some noise coming from the engine (Machismio AVL 500), so my mechanic said it should be opened, found that there was a lot of play in the connecting rod, he said it was because of the rod bearing which has to be replaced using a lathe, I also asked him to replace the pistion rings. My question is after the replacement of the rod bearing, will my bike perform as it used to, and will this effect the life of the engine in the long run?
lazyrider is offline   Reply With Quote
Mechanic for RE Thunderbird in Vadodara ricky_1605 Motorbikes 0 28th July 2010 11:43
Is Hyundai ripping off my friend for no reason? inder_s1 Technical Stuff 11 5th November 2008 15:02
Ripping vids to the Hd manson Shifting gears 6 13th October 2006 13:48
Ripping Audio from Video ScarySkulls Shifting gears 2 7th November 2005 20:23
