| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Certain questions I would like to get answered. 1. Does a stinger/ chamber increase perfromance of a bike? 2. Which is the most optimal design of a stinger/ chamber? 3. Can anybody explain how a stinger/ chamber work, and relevant performance feedbacks.... |
| | #2 (permalink) | |
| BHPian | Quote:
__________________ ..::VeNoM::.. | |
| | #3 (permalink) | |
| BHPian Join Date: Dec 2005 Location: Jersey City
| Quote:
On 2 strokes, a chamber is supposed to pull out the spent charge as quickly as possible and without pulling out any fresh charge with it. In fact, a good chamber will have a pulse going back towards the cylinder to prevent fresh charge from coming out along with the spent charge.
__________________ Horn not working ! Watch for finger ! | |
| | #4 (permalink) |
| Senior - BHPian | A chamber, if made correctly accodring to the bike will increase the performance of 2stroke bikes. Off Topic - Are chambers used on 4strokes too? Or are they mufflers??
__________________ Slow and steady wins the race... But there is nothing like a 300kmph dash to the line!! |
| | #5 (permalink) |
| Mufflers are only used to deaden sound... don't think its used for much else. For 4 strokes, I don't think they're called expansion chambers. But the exhaust system in a 4 stroke is designed for a slightly different purpose. On 2 strokes, the pulse is used to push charge back in. On 4 strokes, the exhaust system should be designed in such a way that no pulse goes back to the cylinder. Also, if not designed properly, on a 4 stroke, you could fry your exhaust valve... Tech whizzes, please correct me if i'm wrong.
| | #6 (permalink) |
| BHPian | Wow! That was an eye opener!! I have put a chamber made manually by my mechanic, for my 4-stroke honda dio, and the performance decreased like anything - specifically : 1) mileage reduced significantly. 2) Pickup reduced. If further explainations as to why the above two inefficiencies took place, I'd be greatly obliged ( if required, i can post the pic of the internal part of the chamber ....) ..... Thankz a lot guys!! |
| | #8 (permalink) |
| BHPian | the chamber he has given looks plain simple, with no emphasis on the actual logic behind it ( as given in earlier posts)..... i'm not good at the technical side so bear with me.... It comprises (from outside to inside) of a cylinder (the exterior shell of the chamber), glasswool, mesh, and finally a thin pipe like thing.... i think u call that the muffler.... I would appreciate some logic on the said above configuration....thankz |
| | #9 (permalink) |
| This sounds more like a simple free flow design sort of exhaust... I have my doubts if he considered factors like back pressure when designing it...
| | #13 (permalink) |
| BHPian Join Date: Feb 2005 Location: Thane
| Think Satya's right here... Your mechanic has only done something to the exhaust system...As expansion chambers (stingers as u call them) can only be applicable to 2-strokes. As for a free-flowing exhaust, I think that if not done properly it adversely affects the exhaust valves...am i right? And it does affect the average also...just makes the bike sound better.
__________________ R.I.P. ROBIN. |
| | #15 (permalink) | |
| BHPian | Quote:
Now don't tell me the dio has got reeds also. U don't put chambers/stingers to four stroke engines. Ur mech must be 2-T specialist..... Use a free flow exhaust sys.And get the tuned length right. And add performace air filter something like UNI or K&N.
__________________ Life begins at 1 Bar.. El Diablo..1.3L SUZUKI Power..U ain't seen nothing yet. Life goes on at 0.5 Bar.. HondaR18...TURBO..iVTEC.. | |
| Thread Tools | |
Similar Threads | ||||
| Complete Connection Audison / Hertz Hi-Energy / Stinger Expert Upgrade Underway. | Tool | Sound Off and Show Off | 92 | 22nd April 2008 21:10 |
| Rx 135 chamber for sale | chiragh_bir | Shifting gears | 0 | 9th December 2007 10:02 |
| Removal of expansion chamber. | adman77 | Modifications & Accessories | 4 | 14th August 2007 12:38 |
| Racing schools/ Perfromance driving schools in India | santro_anil | Motor-Sports!! | 5 | 25th September 2006 10:09 |
| Does a TC increase the CC of an engine? | Shan2nu | Technical Stuff | 8 | 20th October 2004 03:40 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
