Old 8th September 2011, 14:56   #16
BulZire's Avatar
Thanked: 133 Times
Default Re: Repairing a dent in a chrome mudguard?
I kept my bike unused and unclean for some days and that's the cause, I will check the rust removing powder and update if it works.
BulZire is offline   Reply With Quote
Old 9th September 2011, 21:57   #17
Gill's Avatar
Thanked: 12 Times
Default Re: Chrome Mudguard:- Dent Repair.
Originally Posted by Rennjit View Post
^ ah, my bad . pl read my prev post as "Consider silver solder (non- lead alloy) instead of..."
Chrome holds to silver solder but pl clarify with your plating shop, mostly they'll prefer copper base. lead ruins job, sorry if i created confusion. it looks like an RD m'gd ?
Read bit more about the fillers. The silver solder is used but mainly for small pits, it's adhesion in big areas are debatable. The lead may be used, but it must to coated with copper, as the plating preparation for lead and steel is totally different. Bronze is another option.
But for fillers to be effective, the part must be stripped of chrome.nickel/copper, else the filler will crack up.Lead has low melting point,should be avoided on exhaust.
Gill is offline   Reply With Quote
Old 11th September 2011, 20:38   #18
ku69rd's Avatar
Thanked: 1,229 Times
Gill,
Practically did the very same for my RD project, would suggest Copper as the the electro plating lays itself better on than on Nickel.
My silencer also had couple of minor dents which were filled with Copper brazing before electro plating. The result is, Have forgotten where filling/dents were done/present. All that you would need is a willing guy who spends quality time to finish off the surface once the brazing has been done. Takes time much more than brazing part and needs atleast 2 days for a careful job.
ku69rd is offline   Reply With Quote
Royal Enfield Classic Chrome 500 - "The Chrome Decimator" xydon Motorbikes 17 9th February 2016 12:12
Maruti Versa : Rust on the floor board and front mudguard Irfanulla Technical Stuff 4 14th March 2011 21:34
Repairing Baleno Headlight bracket shuvc Technical Stuff 11 7th May 2007 07:33
