Old 5th September 2011, 14:48   #1
Karlitoz's Avatar
Default Knocking noise on a Mach 500 LB only in a warm engine
Guys, I really need some help here.
I have owned and have been riding Enfield for close to 16 years now. The last one I purchased was a Machismo 500 LB, 2 years back.
The bike was doing excellent, until about 6 months back, when a weird sound started coming from the engine. The moment I rev the bike and the RPM is coming down, it makes this strange tak-tak-tak noise. This even happens when I am doing gearshifts.
This only happens when the engine is slightly warm, maybe just done 4-5 kms. This noise does not come when the engine is at extreme temperatures, like a cold engine in the morning, and a heated engine after 10-15 kms.
Have spent close to 23k and got the engine opened twice, at a company owned Service center in Bangalore, but the sound still remains.
Has anyone faced a similar issue ? and what can be the probable cause for the same ?
Karlitoz is offline   Reply With Quote
Old 6th September 2011, 13:31   #2
Leepower's Avatar
Thanked: 70 Times
Default Re: Knocking noise on a Mach 500 LB only in a warm engine
It sound like piston slapping. It basically affects worn pistons. I had it some time back on my 1978 Bull. The bike was still running on its original factory installed piston. Got my piston checked. It needed replacement. Got it change. And now the sound is gone.
Leepower is offline   (1) Thanks Reply With Quote
Old 6th September 2011, 14:51   #3
Karlitoz's Avatar
Thanks @Leepower....will check with the guys at the service center and see. By piston slapping do you mean that there is a gap between the piston and the bore ? I did read a few online articles on the same, and it seems more related to the Piston rings.
Old 6th September 2011, 17:08   #4
Spitfire's Avatar
Thanked: 707 Times
Carb issue. Remove, clean and replace. Issue would be solved. Check airfilter and routing too.
Why the heck did you open the engine and what did you replace for 23k? Piston slap or whatever could have been made out the first time you lifted the head.
Spitfire is offline   Reply With Quote
Old 6th September 2011, 17:21   #5
jingaboysr's Avatar
Thanked: 18 Times
Is it a sound like 2 metals rubbing together? Could be an issue with the worn out cams. The AVLs are notorious for their cam wearing out, I had this problem thrice in my AVL350, and finally sold it off..
jingaboysr is offline   Reply With Quote
Old 6th September 2011, 17:23   #6
Karlitoz's Avatar
Thanks for the suggestion. Will try that too. But do you think Carb would have a link with the engine temperature and the issue.
I use a K& N RC1060 filter with a 130 jet. Will check the routing also
I know, 23k is a lot of money, but being the authorized service center, I usually believe their work. The first time I gave the bike, they checked the Cam etc and did a bot of lathe work. The second time I gave, they said its an issue with the Crankshaft bearings, and replaced the same. The labour charge was also inevitable both the times. This time I am not going to pay a single buck to them, and am pretty angry about this whole episode...
Lets see what happens ?
Yes. I think that might be the issue. Am trying to add a sleeve to an old LB Cam that I have and see if it works. Else, will order a new one, which takes more than two months to source.
But I don't want to dispose off this one because I think LB's are the best machines RE ever came up with.
Thanks for your inputs though
Old 6th September 2011, 19:34   #7
navpreet318's Avatar
Thanked: 894 Times
I have seen 2 particular cases with this kind of noise. One if the camshaft and rocker arm being defective of or worn off. and the second being a shaft in the gear box. Its a very thin shaft in the gearbox. It fits into a small orifice in the gearbox and at the end of it is a ball similar to that of a ball bearing. I don't know the exact name etc. This was the problem with my bike. The mechanic changed the ball and the noise went away. It was a constant clacking at mid temperatures just as you said.and now its been close to 8000 on the odo and there's still no noise.
navpreet318 is offline   (1) Thanks Reply With Quote
Old 6th September 2011, 20:58   #8
Karlitoz's Avatar
Hey Navpreet. Thanks a lot for your inputs. Will definitely be checking on these two possible causes highlighted by you. I have somehow had this feeling right from the beginning that the issue is not related to the Cam, and is something to do with the gearbox. Will keep you posted.
Old 6th September 2011, 23:50   #9
Leepower's Avatar
Thanked: 70 Times
If you are opening up the engine check oil rocker, tappets also. If engine oil is not circulated properly, then also strange noises can come. My 78 Bull used to make strange noises while on the move. Took it to lot of service centres, couldn't get it solved. Finally took it to St. Jude Motors in Wanowrie, Pune run by Pramod Sonawane. He diagnosed the problem and fixed. The fault was the lack of oil circulation.
Leepower is offline   Reply With Quote
Old 7th September 2011, 01:24   #10
I have an LB500 for a little more than 2 years now. Its all brillant.
Had a Thunderbird before this and i faced the problem you are talking about.
It was fixed by replacing the gudgeon pin. To know more about what this is : Gudgeon pin - Wikipedia, the free encyclopedia
I would advise you to get the gudgeon pin checked and also get the tappets re-adjusted.
23K sounds like an enormous amount of money - how many kms has your bike done and where all has she been ?
May be a change of mechanic is the most important thing to do now :-)
kcstheg is offline   Reply With Quote
Low engine temperature - Engine isn't getting warm enough anish5225 Technical Stuff 38 9th November 2015 19:17
KTM 390: Knocking below 3,500 rpm rallyrider Motorbikes 2 16th November 2013 09:24
Knocking Problem at 1,500 rpm sudeep11787 Technical Stuff 3 31st March 2013 13:11
Knocking/Crunching noise on reversing at an angle abhi182 Technical Stuff 6 11th March 2008 14:16
Petrol leak from Carburettor - Mach 500 Ketan Technical Stuff 5 12th July 2007 13:19
