Old 12th October 2011, 09:05   #1
sagarpadaki's Avatar
Thanked: 1,337 Times
Exclamation Acceleration issue in my Bajaj Pulsar 180 UG3
Make-Pulsar 180 UG3
Kms Done- 29000
Riding terrain- Till 25000 kms 30% city and 70% Highway. From 25000 till now,its reverse.
Now the Issue.I noticed this yesterday when i was tried to overtake a slow moving indica.I was at 50 kmph in 5th gear,4000 RPM.I twisted the throttle.The engine roared but the speed didnt increase proportionally.Its as if the engine is revving but not able to transmit the power to the wheels.I drive properly and my bike is serviced every 2500 kms.Just had a engine overhaul 3000 kms ago. I am to take it to the Bajaj service but wanted to know what is causing this problem so that its diagonised properly and Bajaj wont rip me off telling nonsense reasons!
sagarpadaki is online now   Reply With Quote
Old 12th October 2011, 09:57   #2
bullboy's Avatar
Thanked: 35 Times
Default Re: Acceleration issue in my 180 UG3
Check the Clutch has proper play in it.
Ensure that the bike has not slipped into false neutral. Pulsar has this problem of false neutrals but mostly attributed to improper clutch settings and engine oil.
Check you have proper engine oil filled.
bullboy is offline   (1) Thanks Reply With Quote
Old 12th October 2011, 16:14   #3
DueLLeR's Avatar
Thanked: 61 Times
Looks like your clutch is slipping / starting to wear out. Considering you have done 29k and the last 4k have been 70% city riding, it is quiet possible that your clutch may have crossed 50%-70% of its useful life.
Besides, AFAIK, Pulsars clutches are very cheap to replace and usually last around 30k to 40k kms.
Cheers!
DueLLeR
DueLLeR is offline   (1) Thanks Reply With Quote
Old 12th October 2011, 16:21   #4
hellmet's Avatar
Thanked: 638 Times
Definitely looks like a clutch issue. Shouldn't usually die at 29K but you never know.
hellmet is offline   (1) Thanks Reply With Quote
Old 12th October 2011, 16:25   #5
sajjt's Avatar
Thanked: 97 Times
Cheers!
DueLLeR
+1 that, also a wrongly aligned clutch cable can easily wear out, am one of the victims. Check for the cables and plates condition at the first place. These grease monks have a dirty habit of tighting the clutch cable too much and in effect its wearing out prematurely.
sajjt is offline   (1) Thanks Reply With Quote
Old 12th October 2011, 22:32   #6
Default Re: Acceleration issue in my Bajaj Pulsar 180 UG3
Its not false neutral.If in false neutral the bike would not even accelerate.But in my case it accelerates very slowly but the engine revvs up fast!
I have used only Motul 300V fully synthetic oil with a change interval of 5K kms till now
Cheers!
DueLLeR
Thanks for the input Dueller.Any idea how much clutch costs?
Thats what even i was wondering.I hardly use the clutch except for changing gears.And during highway rides, i am in 5th gear most of the time.
But this issue has cropped up since day before.I got my last service 2K kms back.Till last week it was running superb and i even touched 115 kmph last week !And i have not touched or fiddled with the clutch cable mechanism.Dunno how it can get misaligned
Old 12th October 2011, 23:00   #7
DueLLeR's Avatar
Thanked: 61 Times
As far as I remember, Pulsar 180 UG3 clutch cost around 800 bucks, while a Karizma's clutch was about 2.5k. But this is 2006/07 info. I've quit riding now, so I'm not up-to-date with the pricing. Even adjusting for inflation and time gone by, I think a new set should not cost more than 1500 rupees maximum.
Please pardon if I'm totally off scale.
Cheers!
DueLLeR
EDIT: Found this link: http://in.answers.yahoo.com/question...2115308AAHfi7a , which again dates back to 2006. Hope it helps.
DueLLeR is offline   Reply With Quote
Old 13th October 2011, 00:04   #8
narula123's Avatar
Thanked: 514 Times
It could be the clutch and/or the chain-sprocket set. Around 29k is when the Pulsar's sprocket set needs a change. But from the symptoms mentioned it seems like a clutch issue.
FYI, i changed my 220s clutch at 21,000 kms. But then that has a lot to do with my riding style with a few hours of stunting thrown in for good effect.
While you're at it, do get your fuel-air ratio checked. At times, due to a lean running engine, the engine dosnt make enough power despite a wide open throttle.
narula123 is offline   Reply With Quote
Old 13th October 2011, 09:52   #9
bullboy's Avatar
Thanked: 35 Times
Clutch life is around 30k in pulsar if you are riding properly. Mine was changed around 32k when there was gear slipping to neutral.
If sprocket issue then you will get some sort of grinding sound. Check the play and clutch cable as well.
I'm not sure pulsar really need synthetic oil ,Motul 5100v 15w50 is quiet good.
I have read somewhere that synthetics are not good for wet clutch.
So my advice is adjust the clutch.lubricate the cable adjust play and change oil to Motul 5100.You can consider clutch change if this will not work.
bullboy is offline   Reply With Quote
Old 13th October 2011, 13:35   #10
Ya I too feel the clutch is shot. Chain set was changed at 25k so its perfectly fine
Ya my clutch is almost at the end of its life. Also the clutch mechanism has become very hard. I am getting pain in my fingers from the day this clutch slipping has started.
I have switched the oil to semi synthetic motul you mentioned fro the last change since I found fully synthetic to be very costly
Old 15th October 2011, 15:45   #11
hellmet's Avatar
Thanked: 638 Times
From your post above, I feel like it could also be your clutch cable lacking lubrication, hence your clutch getting stuck in half position or something. I'd highly recommend you try lubricating your clutch cable yourself or at your friendly mechanic's place and see if there is a difference. Make sure the mechanic lubricates into the cable with oil and not just applying grease at the top - near the lever.
hellmet is offline   Reply With Quote
Old 28th December 2011, 12:08   #12
ToroRosso's Avatar
Thanked: 87 Times
I have a problem with my 180 UG2, Offlate its drinking oil, Its consuming around 400 ml for every 1000KM.My bike is 06 Make and done close to 25K.
I have been running with a K&N for the past 15K KM and been running with an FFE as well for the past 7K Km.Also i am running 120 section Ceat tyre.
The problems that i face now
a) Engine Oil cosumption - 400 ml for every 1K, I am using Motul 300V synth, i had tried using Motul 5100 Semi synth, but still the same result
b) Top End whack is reduced - Before it used to do close to 115, now its around 105-110
c) At times in gear acceleration feels a bit strained (This may be my imagination as well)
I had showed to Bajaj *** and they suspect my engine is shot , and would need new bore piston and the works.
So Do I need to change the same or shall i continue using the bike and topping up the oil every 1K Km.
Would highly appreciate any help/guidance on this.
ToroRosso is offline   Reply With Quote
Old 28th December 2011, 13:59   #13
bullboy's Avatar
Thanked: 35 Times
Go to a competanet local workshop and chech the bike .An experienced mech will be able to identify the issue.
From the issues you mentioned i assume that the piston rings are gone so might be the valves.
The bike might continue to run but will be smoky and the power will be affected. Not good and it might cost you more to fix it up later.
Old 28th December 2011, 14:03   #14
ToroRosso's Avatar
Thanked: 87 Times
I did go, but they wanted to open up the head and had put a disclaimer that things may be worse if they put it back together.
The question that i have now is, Does FFE + K&N really mess up the bike?
I really do take care of my bike with regular service and et all..
Old 28th December 2011, 14:13   #15
jkdas's Avatar
Thanked: 1,436 Times
Go to a competent local workshop and check the bike .An experienced mech will be able to identify the issue.
+ 1.
First check if there's any oil leak before you take out the bike a ride every morning by inspecting the ground. If no, check if the bike 'smokes' bad when you rev. If its smoking, Bajaj a.s.s. maybe right.
Sudden electrical system failure in my Pulsar 180 UG3 sagarpadaki Motorbikes 6 4th April 2014 14:47
Puzzling gear shift behaviour in my Pulsar 180 UG3 sagarpadaki Motorbikes 11 13th January 2012 22:29
Tires for Pulsar 180 UG3-Your suggestions please! sagarpadaki Motorbikes 3 13th October 2010 16:59
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
