Old 20th September 2015, 23:09   #16
rider60's Avatar
Thanked: 47 Times
Default Re: Water in Fuel tank of my Pulsar 180
Get a custom made cover on the tank from a bike seat cover maker.
Ask the seat cover tailor to use a layer of thick plastic beneath that rexine which covers the tank's fuel lid, this prevents most of the water that gets in through the cap.
Apache and Xtreme have a small hole in the contour where the fuel cap sits, its job is to dispense any water that gets in through the fuel lid of the tank. But this doesnt prevent huge amounts of water from getting into tank when parked/travelling in rain.
I did this on my apache and the problem was solved.
I suggested a custom made one, because the ready made ones, dont come with a plastic sheet lining inside and lets water inside. And these usually have some space to hold small note books or rags. These when drenched, absorb water and takes time to dry leading to unwanted water seepage.
Mine was just a layer of rexine strip on tank and a open-able sheet on the fuel lid. This entire thing has a thick sheet of plastic lining beneath it.
rider60 is offline   Reply With Quote
Old 21st September 2015, 09:55   #17
Thanked: 165 Times
Get the petrol tank empty and also the carb empty. Fill-in fresh petrol and see if the issue persists or no.
Also get the gasket under the fuel tank lid changed + the drain line cleaned. Looks like it is clogged.
The drain line was cleaned the last time. However I will check it again. As far as carburetor is concerned, shall I put in a new one altogether?
Swapnil4585 is offline   Reply With Quote
Old 21st September 2015, 10:53   #18
Thanked: 14,602 Times
Before you get the carb replaced, get down to the root cause. If the issue resurfaces with the new can then you'll go crazy further. So drain it totally and clean it.
It will help you in two ways. When you open it you'll get to know the condition inside. If it not worthy then replace it fully.
I own a 2009 Karizma R which is hardly used (25K kms in 6+years). Initially everything was good but later on the bike never used to cross 80 kmph and if it did, it vibrates. With a friend, we got the carb opened, cleaned and refit. Got a new battery, cleaned the spark plug and more she runs like a charm. Good is the first time I have opened the carb so may be out was dirty and choked.
Hope you get what I am trying to convey?!
a4anurag is online now   (1) Thanks Reply With Quote
Old 21st September 2015, 11:07   #19
rakesh_r's Avatar
Thanked: 743 Times
Carburetors can be repaired.Each and every part is replaceable.Carbs are to be replaced at very extreme cases. Clean the tank and get the carb opened and cleaned thoroughly.You should be good to go.During Monsoon better cover the bike if not used.
rakesh_r is offline   (1) Thanks Reply With Quote
Old 21st September 2015, 12:23   #20
ashis89's Avatar
Thanked: 1,350 Times
The drain lines are known to clog quickly if the bike is parked outside. If that happens then rainwater gets into the fuel tank. The key is to make it mandatory to clean the drain pipe during each bike service (3-4 months). I would also suggest to completely drain and clean the fuel tank every 2 years to avoid rusting. As of now, I would suggest clean the carburetor and the fuel tank thoroughly. Also clean the fuel lines and the filter. If this doesn't work, then try the bike with a carb from another bike. If the problem is solved, then think about repairing/replacing the carb.
I was a victim of the notorious "water in Pulsar tank" syndrome. My 1st gen P150 Dtsi (round headlamp) was 30k kms run and used to deliver 55kmpl in the city limits. Performance-wise, it was a beast too (pulled till 115kmph) which is why I never got any warning signs. Then one day, I saw signs of rusting in the lower area of the tank and took it for inspection. Upon draining the tank, we got more 1 litre of water and almost 0.5 lit of sludge (real thick red mud like). The fuel filter in the fuel cock was clogged and even the carb had the sludge. And yet the bike was running like a dream till then.
ashis89 is offline   (1) Thanks Reply With Quote
Old 22nd September 2015, 00:15   #21
Thanked: 165 Times
I got my bike in the evening. The fuel tank was emptied and cleaned. All the fuel lines and the filter were cleaned. Upon my insistence, the carburetor was also cleaned. The whole work cost me mere 50/-. I did not get a chance to drive the bike for a long distance. Whatever I drove, felt smooth. I shall however observe her behavior for the remainder of this month. Thank you Anurag, Rakesh and Ashish for your valuable inputs. I really pressed the mechanic to clean the carburetor. If I had not, he would have just cleaned the tank and the problem would have cropped up again in some way or the other.
While discussing the reasons for water in tank, the mechanic said that when ethanol comes in contact with water, it starts turning petrol into water. And since past one month or so, oil marketing companies have increased the content of ethanol in petrol. I wonder.
Swapnil4585 is offline   (1) Thanks Reply With Quote
Old 22nd September 2015, 00:19   #22
Great news!
Hope they refilled fresh fuel and the old one else it'll cause the same issue again.
Do keep observing and update the thread after riding it for a longer duration / continuous usage.
a4anurag is online now   Reply With Quote
Old 6th October 2015, 17:55   #23
Thanked: 165 Times
I've been advised to add 20 ml of 2T oil in a tankful of petrol in my XCD. I'm not sure if it is a good idea to do that, as it would clog the spark plug and carburetor. But I see many people adding 2T oils in the petrol tanks of 4 stroke motor cycles. How does the practice benefit the vehicle?
Water found with Diesel in my Getz CRDi - Fuel Tank anarchist Technical Stuff 20 19th June 2017 13:53
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
