Old 11th May 2012, 10:12   #91
ebonho's Avatar
Thanked: 3,182 Times
Default Re: Felt like an Emperor - My Classic Desert Storm
Here's one I had designed and fabricated for my LB500.
Name:  rev cone meg proto.jpg
ebonho is offline   Reply With Quote
Old 17th May 2012, 20:31   #92
Thanked: 91 Times
Some more snaps and i have put original RE sticker on mudguard
ruchirtnt is offline   Reply With Quote
Old 30th May 2012, 09:23   #93
Thanked: 91 Times
I have purchased white light lamp Philips diamond vision 5000k for my DS500 and installed too, it really looks fantastic, they costed me 1000k
I have to procure a white parking light to replace the yellow light, also fitted white parking lights but they are very dim.
Will search for a better parking light in the market
Old 30th May 2012, 13:48   #94
Thanked: 91 Times
Some snaps to add on to the taste
Old 1st June 2012, 16:20   #95
mobike008's Avatar
Thanked: 8,319 Times
Great pictures there Ruchir. Your DS looks hot with those minor mods.
The megaphone exhaust looks so different from regular exhaust. Does it come in black color or you painted it black? Btw, would you mind posting a video of the thump it produces? it would be interesting to hear its note
Old 1st June 2012, 16:43   #96
Thanked: 91 Times
Yes, it does come in black and the thump is definitely better over any exhaust. it is even better than my earlier procurement Monster. will try to post the video over the weekend
ruchirtnt is offline   (1) Thanks Reply With Quote
Old 2nd June 2012, 09:10   #97
Thanked: 91 Times
Snaps of my desert monster during light, the main headlight is white light which dissipates around 5000k with supporting white parking lights
Old 6th June 2012, 08:51   #98
Thanked: 91 Times
I got an update yesterday that RE is again doing a ECU remapping of all the enfield models, this one is more towards misfiring issues. they will give a call to confirm when it will be done
Old 6th June 2012, 10:44   #99
iron.head's Avatar
Thanked: 117 Times
Just checked the validity of above from engineer at RE Chennai. He said that remapping has been done once before and customers who have the old maps can get their bikes remapped. RE is NOT doing any new remapping again.
iron.head is offline   Reply With Quote
Old 6th June 2012, 12:45   #100
Thanked: 91 Times
Yup i did that, since there was an earlier update on post june 2011 motorcycles but they confirmed that there is a latest one. let me check once they give me a call
Old 12th June 2012, 09:18   #101
Thanked: 91 Times
Just an update on my DS500, bike is going good at ODO 3k but the paint finish is really poor and that too at the cost of paying a premium of around 7k for this color.
The color is getting roughened up at some places even with minor hold ups and touching, my earlier TB never had such issues,
I could not fathom that after paying a premium will a customer get this quality?
Old 3rd July 2012, 16:51   #102
MonsterPatrol's Avatar
Thanked: 141 Times
Smile Re: Felt like an Emperor - My Classic Desert Storm
Calling out to all the Royal Enfield gurus out there for some inputs about the Royal enfield classic desert storm.Just booked the bike last week,since this is my first royal enfield bike i really dont have much knowledge about it.Any inputs here to make a great bike better will be really appreciated.Any particular changes required to the stock bike? like change of tires or a handle bar or may be bigger rims. I was also thinking about an upswept exhaust since i live in the jungles and the roads arent that great.
MonsterPatrol is offline   Reply With Quote
Old 4th July 2012, 01:19   #103
ArizonaJim's Avatar
Thanked: 2,106 Times
Perhaps they have improved this but on my 2011 500cc fuel injected UCE I found several places where some of the branches of wires coming out of the wiring harness were passing very close to, or touching the sharp metal edges of the sidecovers or other sharp areas on the frame.
These branches on my harness are protected only with black plastic electrical tape which gives no real protection at all.
To improve this situation I bought a short length of 8mm and 10mm vinyl hose.
Cutting an appropriate length to fit each problem area I then slit the piece from end to end, opened it up and stuffed the wire branch inside of it.
The pieces of vinyl hose have prevented any abrasion to the wiring at each potential trouble area.
During the break in period the motorcycle will have some very notable vibration which seems to diminish as the distance covered increases.
I mention this because it is especially important to check all of the nuts and bolts during this period to make sure they have not loosened.
If you find fasteners which became loose, buying some medium strength thread locking fluid like Loc-Tite (blue) and applying it to the threads before tightening them is well worth the expense and effort.
Beyond that, just follow the break in guidelines in the Owners Manual, be sure to get a oil and filter change at 500 km (there will be a lot of metal fragments in the oil by that time), occasionally check the tyre pressure and enjoy your new motorcycle.
ArizonaJim is offline   (1) Thanks Reply With Quote
Old 14th July 2012, 12:36   #104
Thanked: 91 Times
Monsoon is up and my DS is down with severe rusting at places, its near the saree guard courtesy Saddle bags straps and after market silencer.
Should i remove them or put some anti rust applicants?
Bike is going good at ODO 3800 km, bike is going good only the need of a high handlebar is what i am looking for
Old 25th July 2012, 11:12   #105
Thanked: 91 Times
some inputs from my enfield friends, i had came across the below link of panniers which looks super cool, can i get some experience of real pros and cons
Hotdeal
My 1st Bull: Classic 500 Desert Storm //M Motorbikes 119 7th March 2018 10:11
Desert Storm'd into the Thar Desert and the Little Rann of Kutch //M Travelogues 67 28th November 2015 10:52
RE Classic Desert Storm 500 or Used Harley Iron 883? MonsterPatrol Motorbikes 31 15th May 2013 22:18
Rana dose it again, This time in the Desert (Maruti Suzuki Desert Storm 2009) bhogalrajnish Indian Motorsport 2 2nd March 2009 22:38
Just felt like sharing! EngineOil Travelogues 18 30th August 2008 19:01
