Old 24th February 2014, 20:47   #46
dreamseller's Avatar
Thanked: 351 Times
Default Re: Honda CBR 250R Tire Query
Changed the front and rear tyres of my 248xx kms run CBR 250R to Michelin Pilot Street, about 800kms back. They seem much better now. Very well rounded profile. Although not exactly VFM, but great product nevertheless.
Below is the testimony to a good corner that it took on my way back home. Don't know if you guys can make out from the pic or not, but I sure did have fun!
P.S. Now I know how the TWI wears out. The ContiGo left so much to be desired.
dreamseller is offline   (2) Thanks Reply With Quote
Old 16th September 2015, 11:38   #47
Sheel's Avatar
Thanked: 4,808 Times
Wish to change both tires of my CBR-250R. Any further updates on tire front?
At few places, the front tire/handlebar sometimes tries to turn on its own. Say on a concrete road with unevenness. This did not happen with the R15 or any other bike [same place, same rider]
Usage will be commuting & small highway runs.
With the Continentals, I have flown over bad roads [roads peeled off for construction and or stones lying prior to relaying the road] with 2 tonne weight and nothing went wrong but grip on dry isn't very good.
Old 16th September 2015, 14:42   #48
naveenroy's Avatar
Thanked: 694 Times
Yeah I got Michelin Pilot Street fit just a few weeks back. Got the back first and the front a few weeks after. A world of difference I tell you. And what you are referring to - "the front tire/handlebar sometimes tries to turn on its own" is tramlining. Yes, it is was very pronounced on the Contigos. But it is negligible on the Michelins. These really hold their line well. I have still not had a chance to ride in the wet but the Contigos used to scare me in the wet! In small wet patches of road (rubble, water, tarmac combo), even when turning, the Michelins have held well.
My 2 cents...
naveenroy is offline   (1) Thanks Reply With Quote
Old 16th September 2015, 15:07   #49
man_of_steel's Avatar
Thanked: 1,055 Times
Just Checking. Are the tire pressures maintained correctly?
man_of_steel is offline   (1) Thanks Reply With Quote
Old 17th September 2015, 14:33   #50
Sheel's Avatar
A bit of tramlining should happen with others, but doesn't happen. Tires are the culprit though.
How much for The Michelins? And what about Pirellis?
Been hearing positive reviews for MRF's as well.
Yes, pressure is ok.
Old 17th September 2015, 21:28   #51
aargee's Avatar
Thanked: 2,105 Times
MRF NON Radial is good, but looses air on long run due to wear & tear; if there's a tube inside, good, cheap & best alternative option
Dunlop NON Radial - good, VFM but < MRF radial
MRF Radial is good, VFM
Michelin NON Radial is so-so, I'm not having a great opinion on it though, still experimenting & might have different opinion later
Michelin Radial - not used, heard its good, will try them next
Only tire left out is Conti, I don't think you'll want to know about it
Old 18th September 2015, 09:40   #52
Sheel's Avatar
I have had very good experience with MRF's on the R15, if the tire compound is any closer, then I can go for them, else I am veering towards Michelin. Have used Pirellis about a decade back. Lets see what might be readily available.
I am not a very gifted rider to explore CBR's limit on Metro badged Contis.
Will update post a shoe change.
Old 18th September 2015, 18:27   #53
naveenroy's Avatar
Thanked: 694 Times
Front - around 4.2k and 5.3k for the rear. Depends on your bargaining skills too - I am not good
naveenroy is offline   Reply With Quote
Old 23rd October 2015, 13:40   #54
Mashblue's Avatar
Thanked: 253 Times
Just changed the front tyre to michelin radial and realized how pathetic the stock contigo was (had 11 punctures). Now the bike can properly take corners and doesn't tramline. Rears will be replaced shortly.
Mashblue is offline   Reply With Quote
Old 17th January 2016, 23:02   #55
phamilyman's Avatar
Thanked: 3,451 Times
Is there a knobby tyre recommended for the CBR besides the Pirelli / Michelin reccos?
I was hoping to buy one which has a tread like the ceat vertigo but can't find any such tyre in the gurgaon market.
Old 17th January 2016, 23:06   #56
bblost's Avatar
Thanked: 6,661 Times
I don't know about CBR and ceat.
But I used such a Dunlop on my Thunderbird.
It was the worst thing to have on good roads.
bblost is offline   (1) Thanks Reply With Quote
Old 18th January 2016, 00:11   #57
phamilyman's Avatar
Interesting. Why do you say that? Tell me more.
I had the most scary fishtails of my life in a 10km downhill on muddy under-construction NH22 30km from Bilaspur on the OEM Contis. Even at 15 kph the CBR was all over the place.
While on the pulsar with the vertigo sport, I would just fly through the same with confidence at the usual 60-80 kph!
Old 18th January 2016, 09:58   #58
Sheel's Avatar
The OE tires are BS, they aren't good on the road [designed to be] so off-road behavior like that is norm for them.
I bet on any sports bike with road biased tire, you would be fishtailing in similar fashion.
KTM riders have fitted groovy tires on their trip to Leh, but I am unsure as to how would they perform on tarmac.
Sheel is offline   (1) Thanks Reply With Quote
Old 18th January 2016, 11:43   #59
Mostly Ceat Vertigo Sport. Usual opinion I have heard is that they hold good on the tarmac till about 120kph. Beyond which it is just plain dangerous.
man_of_steel is offline   Reply With Quote
Old 18th January 2016, 16:01   #60
phamilyman's Avatar
Please help me understand your comment: "plain dangerous".
That kind of behavior sounds perfectly fine. I have never pushed my CBR beyond 110 kph so a 120 top speed is more than I'd want! I cannot ride my bike confidently on any tour, at the moment knowing how bad it would perform in just 100m of wet mud.
Honda gives CBR 150R, CBR 250R new colours, decals for 2015 ashwin.terminat Motorbikes 23 31st October 2015 22:32
Honda recalls CBR 150R & CBR 250R for defective starter relay Added_flavor Motorbikes 0 15th August 2015 11:42
2014 Honda CBR 250R shares design with the recently unveiled CBR 300R JayPrashanth Motorbikes 6 25th October 2013 17:21
Honda CBR 250R Police Edition showcased JayPrashanth Motorbikes 5 9th October 2013 11:22
CBR 250R or CBR 600F2 sharad_kmc Superbikes & Imports 8 14th March 2013 21:04
