Old 1st June 2012, 23:01   #16
iron.head's Avatar
Thanked: 117 Times
Default Re: Issues with my '04 Pulsar 150 Dtsi ES
as dhanushs advised you, please get the carb fully disassembled and thoroughly cleaned. get it done by an experienced mechanic who knows how to tune it properly.
iron.head is offline   Reply With Quote
Old 30th June 2012, 00:37   #17
Thanked: 84 Times
Fellas
I have Pulsar 150dtsi (2007 Make)
I have to get its engine overhauled, so I was contemplating over few things
1. Will increasing the bore give me increase in torque (but dnt know will this increase the rpm range)
2. WIll this help me in pulling the bike at hills.
Seniors please help.
Also let me know the place in delhi who can expertly do this.
Thanks!
Honda Monk is offline   Reply With Quote
Old 12th July 2012, 10:35   #18
sajo's Avatar
Thanked: 815 Times
Folks, searched around and thought this is the best thread to post my "problem".
My bike is a 2005 150 DTSi , exhaustec and all. Sparingly used for the past 4 years, hence less than 18k on the odo. Serviced once a year at the friendly neighbourhood Bajaj garage, because of the low running.
Even after a couple of weeks of remaining idle, it starts up fine. It even accelerates fine when it has sufficiently warmed up. No problems with the fuel efficiency, it did around 380 kms last time with 500 bucks worth of Shell (~52kmpl).
However, it simply refuses to go above 80kmph in 5th gear. Since my regular usage pattern over the past few years was simply short hops in the neighbourhood, I do not recall exactly when this "problem" started. Its like the bike has had a rev-lock at 7k RPM in 5th. Not that this is hampering my usage as I am a very sedate rider anyway, but still , is there an issue ?
EDIT : When I say 80, I mean speedo indicated. Also, the above figures are for solo rides only.
sajo is offline   Reply With Quote
Old 16th July 2012, 10:25   #19
sajo's Avatar
Thanked: 815 Times
*BUMP*
Is there any big problem with my bike that I should be worried about ?
Old 23rd July 2012, 17:48   #20
ashis89's Avatar
Thanked: 1,042 Times
*BUMP*
Check and clean the carburetor and the air filter. Also check the spark plug, clean/replace as required. This should solve your problem.
ashis89 is online now   Reply With Quote
Old 23rd July 2012, 22:29   #21
sagarpadaki's Avatar
Thanked: 1,256 Times
*BUMP*
Check the diaphragm in the carb. If its out of shape then this is a common problem
sagarpadaki is online now   Reply With Quote
Old 23rd July 2012, 22:41   #22
Technocrat's Avatar
Thanked: 2,477 Times
Looks like a Carb issue, I am surprised that it has no impact on Fuel Efficiency though so looks like the issue is as mentioned by sagarpadaki
Old 30th August 2014, 00:45   #23
Thanked: 17 Times
Default Bajaj Pulsar Dtsi - Power Delivery Problem
My 2004 Bajaj Bajaj Pulsar 150 Dtsi has clocked nearly 49000 kms. Recently, there is a sudden decrease in power. On inspection, the mechanic told that clutch had worn out and it was replaced by him. Then my bike ran fine for almost 200 kms. But now the vehicle won't move fast at all or respond to acceleration. This caused problems at signals as I am not able to move forward, or while crossing from main road to service road. It is like vehicle is having a mind of its own. Max speed attained is less than 50 km/hr on a straight road with full acceleration.
Now the mechanic tells that as the clutch is new, the issue could be with valve clearance and he has to open head and give it to lathe and adjust the clearance. All gaskets needs to be changed. What is valve clearance /setting ? Now I am suspicious of the quality of clutch plate replaced. There is not much reduction in mileage .
Please advice if any one faced such similar issues with loss of power / pulling and how to rectify the same.
zeri is offline   Reply With Quote
Old 30th August 2014, 13:21   #24
Originally Posted by zeri View Post
First thing is you have to change your mechanic before you change parts. No need to open the head to adjust valves in pulsar
Check the diaphragm of the carb. If it's convoluted a lot then you will face pulling issues. Check if the carb is clean, ie, the jets must be clean.
sagarpadaki is online now   (1) Thanks Reply With Quote
Old 30th August 2014, 13:23   #25
ashis89's Avatar
Default re: Bajaj Pulsar Dtsi - Power Delivery Problem
Does the RPM remain high while the speed is low? It seems the clutch is culprit. A shot clutch will result in poor mileage, the speed won't increase in the same ratio as the engine speed. Please get it inspected at some other good FNG before getting any further work done.
Bajaj Pulsar 150 DTSi Series 2- Test Drive islero Motorbikes 17 22nd July 2016 10:02
Pulsar 150 DTSi 45k report cutdcrap Motorbikes 2 3rd January 2014 12:39
Headlight Upgrade for Bajaj Pulsar 150 DTSi ankushmulay Motorbikes 73 6th March 2013 21:32
Pulsar 150 DTSi or Unicorn?????? 1000bhp Motorbikes 5 28th February 2005 21:21
