Old 17th September 2013, 13:35   #286
Thanked: 427 Times
Default Re: Motorcycle Tyres : Compared!
Originally Posted by am1m View Post
The Sirac Street seems like I'm riding on a 'ridge'. That's the best way I can put it. It seems unstable, yet it's not really. Confusing, I know.
Happy to report that the 'riding on a ridge' sensation has gone. Either I've gotten used to the tyre or the tyre itself has 'bedded in', or something like that. All in all, the Sirac Street has been a good tyre upgrade for my P180.
am1m is offline   Reply With Quote
Old 17th September 2013, 15:10   #287
Thanked: 114 Times
Guy's, i own an Avenger 180 which is about 8 years old has done some 28K on the odo the stock MRF's have done a good job till date but has hardened considerably i guess due to my useage pattern, i would like to replace the tire's for my bike and my confusion is that should i stick to MRF zapper's or is their any other superior option available in the market?
Visran is offline   Reply With Quote
Old 22nd September 2013, 16:33   #288
Urban_Nomad's Avatar
Thanked: 1,371 Times
Need urgent help please peeps.
I ride an RE T bird 2004 model n need to change both tires as of yesterday. It runs 19 inch rims. The fattest rear tyre it would accommodate is 110. I'm frantically searching for an appropriate set but am hitting wall after wall. My requirements:
- super grippy rubber, meant for cornering. Do not care for tyre life. Am happy if it lasts 10k
- would not like to go lower than 100 width for the rear. Front needs changing as well. Do not want to go for the rib type tyre.
- rim size 19 inches
- if at all possible please suggest the approx cost of recommended tires n where I could source them in Delhi.
I have contacted multiple tire dealers in Karol bagh but no one seems to stock 19 inchers anymore. Am speaking to a ceat dealer about secura sport (only 3.25 width available. )
Tx for ur time guys!
Urban_Nomad is online now   Reply With Quote
Old 23rd September 2013, 13:16   #289
CARDEEP's Avatar
Thanked: 1,546 Times
Infractions: 0/1 (5)
Hi @Urban_Nomad
Have you tried MRF dealers for MRF Meteor (rear tyre), which is available in 110/90-19 size. For the front you can go for Zapper FM (size - 90/90-19). IMO these should cost around Rs.3000 (maybe bit upwards for 19 inchers).
Even I plan to upgrade to these on my brother's '10 TB in a year or so.
PS: I am pretty happy with the superior grip of the MRF Mogrip range (using a MOTO-D on my P150), & the nose diving trait of Pulsar is reduced a lot because of the better grip at back.
CARDEEP is offline   (1) Thanks Reply With Quote
Old 23rd September 2013, 23:32   #290
Originally Posted by CARDEEP View Post
Hi @Urban_Nomad
Thanks Cardeep!
I spoke to a dealer in Dwarka who said he will have 110 90 19 coming in tomorrow morning and I can check those out. Its some MRF tyre. I time and again clarified that the tire first needs to be grippy and then all else follows. He could not give me too many details as he was apparently quite busy (seems to be the case almost every time I contact him).
Will pen down further details soon. In the meantime; if anyone has further suggestions please do let me know. I will probably check out the tyre on Wednesday.
Old 24th September 2013, 09:02   #291
tharian's Avatar
Thanked: 3,104 Times
The best tires for grip as well as life were the MRF Meteor and CEAT Secura Sport both of which are out of production AFAIK. The Secura Sport is available in 3.25 now which is of no use since you are looking at wide profile.
There is Pirelli MT60 for 19 inches which provides amazing grip, but is again on the thin side. I am not sure if they are available in Delhi.
Best option would be Dunlop JAPs for you. 3.25 front and 3.50 back. Both are button thread designs. You will need to check with users how good they are since I used them years ago and wore out quite fast.
tharian is online now   (1) Thanks Reply With Quote
Old 24th September 2013, 14:46   #292
Thanked: 289 Times
MRF Meteors are still being made and they cost RS. 2200 here in Pune. On the other hand, it is a tyre for rough roads, being almost puncture proof. Grip, not so good.
Try some Michelin or Pirelli tyre .
john doe is offline   Reply With Quote
Old 24th September 2013, 20:30   #293
^^ Which one? Have heard good feedback about Michelin M45. Is it available in the tyre sizes I have mentioned above? Is the Pirelli Sport Demon available in 19 inches?
Old 27th September 2013, 04:32   #294
Hi @Urban_Nomad
Got the tires replaced today.
Rear - mrf meteor. Has a sirac type "pineapple skin" pattern. The rubber did not seem to be super soft but not hard either. In comparison my very old tyre (kings) seemed rock hard, given its age. Size 110 90 19
Front - mrf zapper fm. Rubber compound seems slightly harder than the rear. Size 90 90 19
Initial impression:
Too early to be talking grip levels. I've barely ridden the bike 2 Kms post the install. It was raining though and there was no slippage. Admittedly I was not pushing it at all. However, I did lock up the front wheel (knowingly and at very low speed) and the front did lose a bit of traction n skidded sideways. The road was quite wet n was grimy too. But I ll reserve my comments till I have clocked at least 100 Kms.
Paid a total of rs 4600 (2500 rear + 2100 front)
Will keep you all posted. Thanks to everyone who took time to respond to my queries.
Old 27th September 2013, 07:36   #295
Thanked: 22 Times
If you can source a Michelin M45, nothing like it. Excellent grip . Been using a combination of M45(2.75 * 18 ) for the front and Sirac street (3.00 * 18 ) on my CBZ extreme for over 13k km and no complaints yet except for the fact that cornering will get some time to used to given the block pattern of Sirac street.
kaka46 is offline   Reply With Quote
Old 27th September 2013, 07:52   #296
tharian's Avatar
MRF Meteor is a good tyre, grip as well as good stability and lasts long.
I have been using one for around 30k kms now and the thread looks still good.
Only one problem, as the tire is being used, the width of the tire tends to increase and the sidewall ends up rubbing on the swingarm. Shouldn't be a problem on the TB.
I have a 96 500 on which I was using this first and over time, it started rubbing the swing arm,after which I shifted it to my 02 Electra which has a wider swing arm and runs fine.
Should start hunting for this model in Bangalore as I thought they are out of production.
tharian is online now   Reply With Quote
Old 27th September 2013, 16:33   #297
parrys's Avatar
Thanked: 5,949 Times
Boys,
The rear tyre on my R15 2.0 will be due for replacement next month.
The Revz-S has lasted for ~30,000 kms and I am very satisfied with it.
However, I was planning to get tail tidy done, and hence wish to get a 140 section rather than the OEM 130. (So that it looks better with the tail tidy)
Request you to suggest a tyre which would satisfy me as much as the Revz-S did.
The first page talks about Conti Go & MRF Zapper C with the 140 section; since the Conti Go gets a no from almost everybody and the Zapper C looks very Pulsar, what are my options?
parrys is offline   Reply With Quote
Old 27th September 2013, 17:38   #298
Happened to read a little on this "tyre flattening" phenomenon. Mostly happens with soft compund (sportbike tyres) tyres. If one tends to ride mostly in straights and does not lean the bike much during cornering; the tyres develop this flatness given the soft rubber & extended pressure on the center.
Solutuion - Corner; corner HARD & do it often
Old 27th September 2013, 20:37   #299
tharian's Avatar
Should happen more so on hard compound tire over time since even with cornering, the wear on the sides will be less and most of the time the centre part of thread is in constant contact , this happens.
I noticed this on the MRF Nylogrip and now the Meteor. Both are hard compound.
It hasn't occurred on the Pirelli MT60 which is 100/90 and is very soft compound.
Mainly will depend on the width of the tire.
Old 27th September 2013, 21:06   #300
Hashim's Avatar
Thanked: 32 Times
Guys I want to change the rear tyre of my Yamaha Gladiator as its getting puncture again and again and gone a bit bald too. I want a tyre which gives best cornering grip coz I have fell twice slipping while cornering wet road, even on dry roads the grip looses.
I don't mind cost, low tyre life, low mileage etc but it should grip well. Please advice.
Tyre size is 3.00 - 18
Hashim is offline   Reply With Quote
Why less engine braking in cars compared to 2-Wheelers ? mithun Technical Stuff 24 5th July 2008 16:38
Is the Aveo really so bad as compared to the Fiesta?? Puffdamgcdragon Sedans 64 17th July 2006 12:03
Which box do u recommend for this woofer ? Result will be compared ! low_bass_makker In-Car Entertainment 10 17th April 2006 10:13
Compared-ZMA vs 180 dtsi-type 1... veyron1 Motorbikes 87 28th March 2006 05:39
Car Prices In India Compared To States IndianDawg The Indian Car Scene 12 9th December 2005 18:10
