Old 29th May 2014, 12:37   #361
saket77's Avatar
Thanked: 5,043 Times
Default Re: Motorcycle Tyres : Compared!
Ya both are tubeless.These are not for Leh ladhak. They can handle bit off roading but nothing more. But on tarmac they grip like leech in both dry and wet conditions. Last for 20-25K kms depending on driving conditions
The numbering meaning is same for cars and bikes
I am sure that the grip levels would be excellent, as you rated them very good in the previous review too, but won't 90/80 (F) and 100/80 (R) will a downsize over the stock size which is 100/80 & 100/90? Immediate effect of this will be error in speedo readings. Anything else?
saket77 is offline   Reply With Quote
Old 29th May 2014, 13:36   #362
sagarpadaki's Avatar
Thanked: 1,337 Times
Yea you will get a bit of speedo error! But hey the grip levels will be awesome. Or you can go for R15 V2 front tyre - Zapper FY1 in 90/80-17. Your speedo also intact and grip level even more because of bit wider contact patch
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 29th May 2014, 13:41   #363
saket77's Avatar
As you said, I was considering MRF Zapper FY1, but that comes in 90/80, where as the stock size is 100/80, which means 80mm of side profile. A 90/80 tyre means a 72mm side profile which means some speedo erros will be induced. Though, the tire change is not due anytime very soon, but I hope that some good tires are introduced in stock size for my bike. Thanks a lot for patiently looking into all my queries.
Saket
Old 29th May 2014, 18:45   #364
amit_purohit20's Avatar
Thanked: 486 Times
My experience with the Ceat Secura Sport tyre (button type) on rear wheel of RTR180:
1) It does not corner well as other tyres. Although nothing very serious to complain unless you corner very hard.
2) The tyre is good in slush for sure. Also on gravel its good but dont trust your luck beyond a limit.
3) On road in wet conditions the tyre is better than crappy stock TVS tyres, it does not slip but at the same time it does not inspire confidence to be fast. Till now I never had slips but I drive very safe on wet roads.
4) On dry roads the grip is ok, hmm braking is a bit tricky but we can expect it to have some less grip on-road as its a button type tyre.
5) The biggest problem with this tyre is it follows the ridges on the road which run parallel to the direction of motorcycle travel. So you might find the bike pulling you in the direction of the parallel ridges (usually these ridges on road are formed during road reconstruction).
6) Its not a soft compound tyre so better protection against any punctures. Being tubeless repairing will be easy too.
If you are the one who does not often go off-roading/bad roads and drive mostly on tar roads, I would suggest to go for normal tread tyres (rather than button type).
amit_purohit20 is offline   Reply With Quote
Old 8th June 2014, 11:24   #365
aargee's Avatar
Thanked: 2,143 Times
I'm looking to buy MRF Zapper C, TL, 140/70-17 for over 4+ months (yes FOUR MONTHS) now & I'm unable to find one at MRF exclusive & T&S shops in Chennai.
Tried online as well & couldn't find one that sells 140, but 110.
Other option is to settle with Dunlop, which I want to try something else this time. Michelin's are way too expensive for my usage. Another & last option is to settle with CEAT Dhoom 3, but, MRF being TL, I have a great faith in it.
Please help! Thanks.
Old 8th June 2014, 22:04   #366
That size is very rare and dealers won't stock it. Suggest you go for Michelin. Although costly, extra money spent on two wheelers tyre is never waste. More grip the better
Old 9th June 2014, 10:58   #367
aargee's Avatar
I'm aware of Michelin & I don't want that "extra" grip; I'm not sure & hence asking, do Michelin offer a Radial tire in that size? Because, MRF is Radial & I've seen how MRF Radial performs in 110/70-17 for over 40000 Km in 2 sets of tires.
Plus, I've seen a MRF 140/70-17 fitted to C250R here in Chennai, unfortunately that was at ASC & hence couldn't talk to the owner to find out where it retails.
Hence asking here if someone could help. Thanks.
Old 9th June 2014, 12:06   #368
What Michelin offer in that size is Radial !
I can check with few dealers in Bangalore if that size is available in Zapper C
Old 9th June 2014, 12:49   #369
Thanked: 16 Times
I have been using Dunlop since a long time. The threads do not wear out easily. However the tyres tend to get hard after a year. This is very scary under hard braking as the wheels skid off the line.
Servegaar is offline   Reply With Quote
Old 10th June 2014, 01:14   #370
aargee's Avatar
Super saar
Fantastic; thanks & much appreciated. I don't mind riding to BLR to collect the same.
Wow; how long? Because I've been using Dunlop for last 17000+ Km & it started developing weak spots causing the tire to puncture. The RevZ in the front is working dutiful for nearly 20000 Km & I'm sure it can withstand another 2K easily. OTOH, I've used MRF Tube type (without tube ofcourse) for more than 22000 Km with one issue in the last 4000 odd Km that it looses air from the side walls for no apparent reason.
Old 10th June 2014, 02:57   #371
aargee's Avatar
Correction - It's MRF Zapper S (not Zapper C) RADIAL & tubeless tire
Old 10th June 2014, 12:02   #372
Thanked: 16 Times
Wow; how long? Because I've been using Dunlop for last 17000+ Km & it started developing weak spots causing the tire to puncture. The RevZ in the front is working dutiful for nearly 20000 Km & I'm sure it can withstand another 2K easily. OTOH, I've used MRF Tube type (without tube ofcourse) for more than 22000 Km with one issue in the last 4000 odd Km that it looses air from the side walls for no apparent reason.[/quote]
It has done 24000 kms of rural roads and it has had only one puncture till date. The tyre pressure however needs to be checked on a weekly basis.
Old 10th June 2014, 13:15   #373
theexperthand's Avatar
Thanked: 1,242 Times
which will be the grippest tyre I can put on Unicorn ? This is for the rear tyre and I am ok with a thread life of 10K - 15K, but the tyre should perform well in tarmac and in gravel \ slush conditions.
The current tyre is Michelin Pilot Sports and though the tyre have amazing grip in tarmac, the less said about the gravel \ slush the better. Coming from M45, Pilot sports have been a huge disappointment - I am looking for something similar to M 45.
--Anoop
theexperthand is offline   Reply With Quote
Old 10th June 2014, 15:13   #374
saket77's Avatar
Wanted to ask a general question to tyre gurus!
Is is necessary to have a thicker section rear tyre than the front? Will there be any issues in stability or anything else if we use a thicker section front tyre than the rear?
For eg. The MRF Zapper Vyde for rear is available in 100/90. Will it be okay to club it with a tyre like FY1 which is 110/80?
Old 10th June 2014, 16:04   #375
r_nairtvm's Avatar
Thanked: 1,574 Times
Hello,
I am looking for the following (preferably Dunlop)
1) 3.50.18
2) 3.00.18
Any idea if this size is still available - any where in Bangalore
Also can some one advise if the comparable sizes in Radial available, if so which brand and what is the size ?
Best Regards & Ride Safe
Ram
r_nairtvm is offline   Reply With Quote
Why less engine braking in cars compared to 2-Wheelers ? mithun Technical Stuff 24 5th July 2008 16:38
Is the Aveo really so bad as compared to the Fiesta?? Puffdamgcdragon Sedans 64 17th July 2006 12:03
Which box do u recommend for this woofer ? Result will be compared ! low_bass_makker In-Car Entertainment 10 17th April 2006 10:13
Compared-ZMA vs 180 dtsi-type 1... veyron1 Motorbikes 87 28th March 2006 05:39
Car Prices In India Compared To States IndianDawg The Indian Car Scene 12 9th December 2005 18:10
