Old 10th June 2014, 16:36   #376
sagarpadaki's Avatar
Thanked: 1,271 Times
Wanted to ask a general question to tyre gurus!
Is is necessary to have a thicker section rear tyre than the front? Will there be any issues in stability or anything else if we use a thicker section front tyre than the rear?
For eg. The MRF Zapper Vyde for rear is available in 100/90. Will it be okay to club it with a tyre like FY1 which is 110/80?
FY1 is 90/80-17
Rear tyre is bigger since power is put down to the road through the rear rubber. And yes rear should be at least a bit wider than the front
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 10th June 2014, 16:57   #377
saket77's Avatar
Thanked: 4,593 Times
Default Re: Motorcycle Tyres : Compared!
FY1 is 90/80-17
Yes, sorry that I got confused between FY & FY1. Even the FY is 110/70 (& not 110/80)
I have almost finalised the rubbers to be FY1-90/80-17 at the front. I hope that the 90mm section will not foul with anything as the stock tyre is 80mm contact patch.
Little confused about rear as to go with Vyde or Zapper S. Looks like Vyde is not available in tubeless avatar for 100/90, which is the stock size. Zapper S tubeless is available in 100/80.
Was interested in Vyde as it looks a corners craving tire to me but not at the cost of losing the tubeless form.
Thanks,
Saket
saket77 is offline   Reply With Quote
Old 10th June 2014, 18:31   #378
saket77's Avatar
Found a nice website to calculate the speedo error in case of upsizing or downsizing tyres.
1. http://www.agcoauto.com/content/Tire...ror_Calculator
2. http://www.willtheyfit.com
Usable for both car & bikes.
Old 10th June 2014, 21:18   #379
Thanks,
Saket
Zapper FY is 80/90-17.
Go for zapper S at rear and zapper FY1 at the front. No issues will be there. No fouling nothing.
PS : today purchased my second zapper FY2 for my pulsar. Will be changing it next week as my current front tire will complete 25K kms. Besides monsoons are also approaching. Cost me 1900 bucks
Old 10th June 2014, 22:40   #380
aargee's Avatar
Thanked: 2,124 Times
What good is a site without pictorial comparison? Try this - http://www.tacomaworld.com/forum/tirecalc.php
aargee is offline   (1) Thanks Reply With Quote
Old 10th June 2014, 23:06   #381
saket77's Avatar
Zapper FY is also coming in 110/70-17. But yes, will get FY1 for my bike. Pardon me but cannot find FY'2' at MRF's site (?)
Thanks. Will check the website. Though the second website I shared also had a pictorial representation.
Old 11th June 2014, 13:11   #382
Ya Zapper FY is present in 110/70-17 . But i have not seen them in that size in the tyre shops. Have you?
Ya there is no FY2 released yet
@aargee:
Check out this website
http://tyreplanet.tradeindia.com/two-wheelers.html
looks like they can ship the tyres to you
Old 11th June 2014, 13:18   #383
saket77's Avatar
Checked it. Looks like it does not likes my bike's front rubber size - 80/100
So, must be FY1 you meant. But isn't 1900 bucks significantly cheaper than what was posted before. I remember it being priced at about 3100 bucks.
Old 11th June 2014, 13:22   #384
No no what i meant is FY is available in 110/70-17 size . But not available in the shops. Only the 80/90-17 size is available
Ya i paid heavily because then i purchased the tyre from Yamaha showroom. None of the tyre shops had it and i had to get a tyre.Even now it retails at 3000 bucks at yamaha showrooms. But this time i was fortunate to get it from a MRF delear who stocked this tyre. So happily grabbed the tyre before someone else took it!
But no regrets for paying 3100 for the tyre originally. I have used it a lot and now its nearing 25K kms. Will change once it completes 25K
Old 11th June 2014, 22:09   #385
aargee's Avatar
It does; are you talking about the size not being accepted?
Old 12th June 2014, 10:05   #386
saket77's Avatar
Thanks for the work there aargee, but the pic attached shows as the contact patch as 100mm, but mine is 80mm; so there is a difference between 100/80 & 80/100 tires. Sure you already know that, just to bring it to your attention.
Old 17th June 2014, 11:07   #387
aargee's Avatar
I can check with few dealers in Bangalore if that size is available in Zapper C
Finally got what I wanted!! Persistence, Perseverance & Patience Paid off
Thank you for offering your help to find one for me, but I guess I saved your effort & time on me
Old 18th June 2014, 08:27   #388
Attachment 1250827
Which models are these exactly?Size? How much is the price?
Please post a review in on this thread in the format mentioned in the first page once you burn some rubber on the road.
PS- I was not able to start looking for the tyres here in Bangalore since i have held up with issues on family front. Good that you got them in Chennai itself.
Old 18th June 2014, 20:54   #389
aargee's Avatar
MRF Zapper S Radial 140/70-17 (http://www.mrftyres.com/products/tyres/zapper-s)
Will do
I was not able to start looking...got them in Chennai itself.
No issues
Old 19th June 2014, 01:44   #390
r_nairtvm's Avatar
Thanked: 1,531 Times
Not about tyres but related.
Are the major tyre shops equipped to balance the wheels after tyre installation ? Last time I changed a MC Tyre in India was ages ago and hence, this question.
What sort of weights are used - the sticker type or conventional wedges ? Also are led weights which fits on the spokes still available ?
Best Regards & Ride Safe
Ram
r_nairtvm is offline   Reply With Quote
Why less engine braking in cars compared to 2-Wheelers ? mithun Technical Stuff 24 5th July 2008 16:38
Is the Aveo really so bad as compared to the Fiesta?? Puffdamgcdragon Sedans 64 17th July 2006 12:03
Which box do u recommend for this woofer ? Result will be compared ! low_bass_makker In-Car Entertainment 10 17th April 2006 10:13
Compared-ZMA vs 180 dtsi-type 1... veyron1 Motorbikes 87 28th March 2006 05:39
Car Prices In India Compared To States IndianDawg The Indian Car Scene 12 9th December 2005 18:10
