Old 1st July 2014, 22:05   #406
Thanked: 13,056 Times
Originally Posted by Urban_Nomad View Post
Where can we find tyre manufacturer recommended PSI ratings?
Does anyone know if the motorcycle manufacturer's and the tyre manufacturer's recommended PSI is the same? If not, which one do you / would you rely on?
Bike manufactures will give the tyre pressures based on - Seating - Single only or single + pillion.
Now major of it is tested to extract maximum fuel efficiency. Finding the right tyre pressure from the bike manufacture will be found on the swing arm (left side) whereas the tyre manufacturer gives only the maximum tyre pressure that the specific tyre can handle.
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 7th July 2014, 12:23   #407
aargee's Avatar
Thanked: 1,976 Times
Default Re: Motorcycle Tyres : Compared!
Please post a review in on this thread in the format mentioned in the first page once you burn some rubber on the road.
This is just a quick update, so pls excuse the format...
After 1091 Km yesterday, I noticed a mild crack in the tire, that should've probably been due to the deep passionate kiss on the pothole last week in the darkness. Anyway it only appears like a skin peeling off. Really not sure if it should occur or not because I've had similar hit in the past, but on front tire (MRF Radial) & never been an issue. Otherwise, there's no symptoms of air leak or anything.
Regular riding experience with tire grip on tarmac, off road (with confidence) & sandy tarmac surface has been good & as expected. Haven't really tried panic braking, slippery surface or wet conditions.
Old 5th August 2014, 13:09   #408
adhiraj's Avatar
Hi Guys,
Need your valuable suggestions.
My current ride is Yamaha R15v2. Both tires have gone bald.
I would like to stick to the stock tires only.
Stock tyres are :
Front: MRF Nylogrip Zapper-fy1 90/80-17m/c
Rear: MRF Rev Z-s 130/70 R17
Please provide me with stores in bangalore from where I can buy these. I know JC road has got a lot of them but I need reliable and pocket friendly ones
Also if anyone knows the current market price of these tires, please let me know.
adhiraj is offline   Reply With Quote
Old 10th August 2014, 12:02   #409
sagarpadaki's Avatar
Thanked: 1,214 Times
Originally Posted by adhiraj View Post
Hi Guys,
Need your valuable suggestions. My current ride is Yamaha R15v2. Both tires have gone bald.
Call up MRF showrooms nearby your place and check with them the availability. Don't go to Tyre shops on JC road. You will get ripped off.
FYI, I purchased the zapper FY1 from MRF dealer for 1900 bucks.
Last edited by mobike008 : 10th August 2014 at 12:57. Reason: Please dont quote entire long post for a reply
Old 11th August 2014, 19:34   #410
Thanked: 20 Times
Hi guys...
I've read a lot about Fzs rear tyre but couldnt find much detail about the Ceat Zoom xl 140/70-17 tyre.
Anyone who might be using it?
Is it good(much puncture resistant) or not?
Dunlop is not available in my city.
Only options I've are:
Ceat Zoom(Dhoom3): 3000/-
Ralson Blaster: 2800/-
MRF revz(stock): 2800/-
Need expert comments on Ceat specifically.
I'm most concerned about punctures(grip doesnt matter much)
Thanks in advance!
akki4 is offline   Reply With Quote
Old 21st August 2014, 07:06   #411
carizma's Avatar
Thanked: 13 Times
Hi Sagar!
Sorry if I am reposting this although I have read the whole thread. Could you please suggest a tyre upgrade for the Classic 500? The current setup is 90/90/19 MRF ZAPPER FM for front and MRF ZAPPER C 120/80/18 for the rear. The rear tyre is not confidence inspiring as I have found over the few kms of riding. It is gets unsettled on rough patches of road and on sharp turns.
Abhishek
carizma is offline   Reply With Quote
Old 21st August 2014, 10:50   #412
Originally Posted by carizma View Post
Hi Sagar!
Abhishek
Abhishek, i am sorry i cant help you on this. I dont have any idea on the options available in the RE size. Fellow members who have used different tyres will be able to guide you better. Ask in the RE ownership threads or PM the owners
Old 21st August 2014, 20:33   #413
Thanked: 289 Times
Hi Sagar!
Abhishek,
Are you saying that you have ridden the bike only a few kms? How new are you to the Enfield?
Let me assure you that Enfields are usually poor at braking and sharp turns.
Hope that I have understood your post correctly
john doe is offline   Reply With Quote
Old 21st August 2014, 20:38   #414
carizma's Avatar
Thanked: 13 Times
Yes, you got that right. This is the first Bullet in my life
Old 21st August 2014, 20:53   #415
Urban_Nomad's Avatar
Thanked: 1,233 Times
My congratulations and condolences
For the rear - I use mrf mogrip-D, 110 section on my t-bird. Recommended. It has a trad pattern very similar to sirac
Not sure if u have ridden in the rains yet but I can tell u this, ur front tyre (zapper fm) is crap. I have the exact same one in a 90 section. I would recommend looking for a better front tyre too. And when you do find one that's worthy, let everyone here know. Good 19" rubber is hard to come by
Urban_Nomad is offline   Reply With Quote
Old 21st August 2014, 21:13   #416
carizma's Avatar
Thanked: 13 Times
AFAIK the mogrip is not available in 120. Does the Thunderbird not come with 120/80 rear tyre?
Old 21st August 2014, 23:15   #417
Mine's a 2004 T-bird. Stock tyre was 90/90/19. Not sure of Mogrip availability in 120
Old 22nd August 2014, 01:22   #418
SriramEfunds's Avatar
Thanked: 42 Times
ZMA - 3 years old
Mode - Tourer
Front - MRF Zapper FS
Rear - M45 4.00x18
I'm already done 10k kms on the M45 and have another tyre for future, however, these offer mileage of 18-22k kms due to their compound, soon, I would need to look for an alternative. I have heard that Ceat Zoom offers very good VFM and it is good on wet tracks too. However, would like to know from here if any one has personal experience. If I had to ask the shop, I'll be convinced but I don't buy that.
Another one, I'm also hearing about Ralco tyres. However, I don't have anyone here in Chennai I know using this tyre or have personally seen them on my visits to tyre stores.
Do we have have any other choice apart from the ones mentioned above?
SriramEfunds is offline   Reply With Quote
Old 30th August 2014, 14:47   #419
swarnava.m's Avatar
Thanked: 254 Times
I have recently purchased a 2009 Bajaj XCD 135. It has run 62k kms and is shod with EuroGrip 2.75-17 in front and 100/90-R17 in the rear. These tyres are absolutely useless and in the wet provide no grip whatsoever.
I am looking at changing both tyres, and following are my options:
Front:
  • Michelin Pilot Sport Tyre Tube
  • MRF Zapper FS Tyre Tube
Rear:
  • Continental ContiGo Tubeless
  • Michelin Sirac Street Tyre Tube
  • MRF Zapper C Tyre Tube
  • MRF Zapper C Tyre Tubeless
Kindly put in your suggestions. Thanks.
swarnava.m is offline   Reply With Quote
Old 10th October 2014, 23:13   #420
rajathv8's Avatar
Thanked: 170 Times
I recently made a tyre purchase :
  • Bike : Bajaj Discover 135, 6 years and 40K Km old
  • Tyre : MRF Zapper FS Front tyre, TT. The tyre comes with a tube
  • Cost : Rs.1750 Incl taxes
  • Fitting Charge : Rs.90
  • Place : Tyre Empire Whitefield
  • Usage : The bike is for commute within the city. I ride at a sedate speed and rarely cross 60 kmph. I ride pretty cautiously in the rains and on bad roads. The bike is predominantly used on broken/bumpy roads in dense traffic
The buying experience was positive. The store is large and has a good collection of tyres for bikes and cars. I checked for availability over a call beforehand. The guy I spoke to seemed to know what he was talking about and was pleasant. The tyre was removed using a machine and work was done professionally. Overall a positive experience. I would recommend the place to others.
rajathv8 is offline   Reply With Quote
Why less engine braking in cars compared to 2-Wheelers ? mithun Technical Stuff 24 5th July 2008 16:38
Is the Aveo really so bad as compared to the Fiesta?? Puffdamgcdragon Sedans 64 17th July 2006 12:03
Which box do u recommend for this woofer ? Result will be compared ! low_bass_makker In-Car Entertainment 10 17th April 2006 10:13
Compared-ZMA vs 180 dtsi-type 1... veyron1 Motorbikes 87 28th March 2006 05:39
Car Prices In India Compared To States IndianDawg The Indian Car Scene 12 9th December 2005 18:10
