Old 24th October 2012, 14:09   #76
sagarpadaki's Avatar
Thanked: 1,276 Times
Originally Posted by Amarendranath
I have done around 12k km. ( previous set did not wear out till 20k km ) zapper vyde isn't tubeless right. Also vyde increases the overall weight. I will have to ride or some pretty bad roads on way to work and cant image a puncture without tubeless tires. got so used to rolling with tubeless tires cant go back to the tube ones.
Any idea on how michelin pilots would suit r15?
Vyde in 120 80 section is tubeless. Yes it does increase the weight but does not get punctured easily .
So you are running on second set of tyres is it?
Michelin pilot sporty is another option but its also prone to puncture. So you better stay away from it. Pilot sporty comes in two variants. Made in Thailand and made in India. Made in India ones are hard and less grippy. Made in Thailand ones are very grippy but are like your stock tyres. Mine had 6 puncture during its 14k kms usage.
So your best bet is zapper vyde
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 24th October 2012, 14:47   #77
Amarendranath's Avatar
Thanked: 407 Times
Default Re: Motorcycle Tyres : Compared!
Thank you sagar,
But the tyre making the overall feel heavy and needs some getting used to.
Any idea on the continental conti- go.? Many here in Hyderabad suggested that it less prone to punctures. If that isn't great then ill move to vyde. I guess the fuel economy also drops with bigger tires? I never really changed the tires apart from the stock one's. And yes this my second set.
The rear tyre is the third one. The second one got badly punctured after usage of 300km only. The puncture was on the side wall of the tyre and hence nothing could be done.
I just didn't want to alter the Tyre size , as it may affect the overall feel etc of those perfect yet puny tires.
Amarendranath is offline   Reply With Quote
Old 24th October 2012, 23:25   #78
revtech's Avatar
Thanked: 35 Times
hey sagar firstly, Thank you so much for this much needed thread and perfect timing cause its about time i change the rubber on my 180 as well.
its great the way you've analyzed them.it makes things a lot easier when it come down to selecting a tire
my requirement is just GRIP. dont care about tire life at all so even if it lasts about 10k kms thats great
for the front ive zeroed down on the zapper FY/FY1 depending on availability. and for the rear im still confused between the
mrf vyde
micheline pilot sporty not too keen especially since the recent stock isnt too great from what i have read
pirelli mt 75. not too keen on the sports deamon cause its hard compound ? always thought it was soft
and lastly IRC NR48
i guess ill have to make a call from these ? unless something better is available.
what size rear tire are you using ? stock is 100 and was thinking 110 or at the most 120, nothing more
rev
revtech is offline   Reply With Quote
Old 25th October 2012, 22:51   #79
mrf vyde
and lastly IRC NR48
rev
If you can lay your hands on nr48, then just go for it. Pirelli mt 75 would be next best. But make sure you don't buy it if its more than a year old. Pilot sporty is too puncture prone. The last choice would be zapper vyde.
I used the stock zapper till 22k. Then changed to pilot sporty 110/80 and used it till 36k. Now running on vyde.
Old 31st October 2012, 21:30   #80
Sheel's Avatar
Thanked: 5,101 Times
Originally Posted by Amarendranath View Post
I dont think the sealant would help. Should upgrade to something durable.
And what makes you think so?
A sealant's only handicap is a tire cut, rest everywhere it does a great job. Fills even minute air leaks.
Old 31st October 2012, 21:35   #81
Thanked: 407 Times
I agree with you. But then the tyre is getting punctured often and ending up with atleast 2 punctures so i feel changing tyre is better. Sealant would be great when the tyre is in a good condition right.
Old 31st October 2012, 21:54   #82
jeeva's Avatar
Thanked: 546 Times
Has anyone over here used Avon tyres on the Bullet?
Would love to know more about those tyres and its availability in India.
Sometime back, I had met a french guy on his RE in the middle of his India tour and he vouched for the Avon Speedmasters.
jeeva is offline   Reply With Quote
Old 31st October 2012, 22:44   #83
Sheel's Avatar
Not really.
If the holes causing punctures are visible and you know they are large enough for the sealant to not work, then I would suggest changing the tire.
Else, I have seen FZ & R15's having a dozen puncture and the sealant seems to work fine.
If getting a new tire, stick to stock (at least on the R15) and get sealant filled up.
Sheel is offline   (1) Thanks Reply With Quote
Old 1st November 2012, 13:47   #84
Thanked: 407 Times
Not really.
Im sure the tyre has worn out. No harm in trying tough. Can you share any links on where to order the tyre sealant's?. Just checked with the yamaha showrooms. There is no stock available as of now.
And yes. I tought of moving away from stocks. Chsnge of mind - If sealant doesnt help will order the same old stock tires
Old 1st November 2012, 22:05   #85
Sheel's Avatar
Try accessory or tire shops. I am unsure of the availability at Hyderabad. May be fellow Hyderabad Team BHP-ians can be of help. There is a thread running about the meets.
And yes, I believe sealants are available on-line as well.
Please do not change the tire. I mean, if you need to have a new tire, stick with the ones which came as stock.
Old 3rd November 2012, 22:03   #86
Thanked: 407 Times
Hi sheel,
I have just come across this link in ebay
http://www.ebay.in/itm/PYROIL-PUNCTU...item1e73ce66a4
and also another product by name " slime ". Hoping these might be helpful. any idea on the product in the above link?
Old 7th November 2012, 18:35   #87
prateekm's Avatar
Thanked: 320 Times
I had posted in this thread a few months back about the rear tyre upgrade, but I didn't go ahead because of some reasons. Now, I'm frustrated with the stock tyres on my Apache and need to upgrade it ASAP. There are just 2 must-haves for the tyres; should be hard compound and should have a good grip on all surfaces. The size I'm looking at is 110/80-17 or 120/80-17. I'm not having a fixed budget, can spend 3-4k if the tyre is good. I can't find IRC, MRF in the nearby shops, they have Dunlop, CEAT, Pirelli and Michelin.
prateekm is offline   Reply With Quote
Old 7th November 2012, 18:56   #88
Thanked: 109 Times
I have an Apache RTR160, 2008 Refresh Series. Planning to change the rear tyre (priority). I was told that the tubeless won't fit!
Looking for excellent wet grip and less prone to puncture.
How about Pirelli MT75? Any other suggestions?
MotoNanu is offline   Reply With Quote
Old 7th November 2012, 19:22   #89
Thanked: 1,017 Times
Hard Compound and Good grip on all surfaces is not possible in the same tyre. A medium compound is a good compromise. You can consider MRF Vyde if available, if not then Pirelli MT75 is a good tyre which I am using currently but it is a soft compound tyre. Good in almost all surfaces. Should last around 15-17k kms. Michelin reviews are present in this thread and is a very good tyre but again a soft compound. Take your pick.
abhinav.s is offline   (1) Thanks Reply With Quote
Old 7th November 2012, 20:30   #90
prateekm's Avatar
Thanked: 320 Times
How about the Michelin Sirac and the IRC NR48? Heard good reviews about the IRC.
Why less engine braking in cars compared to 2-Wheelers ? mithun Technical Stuff 24 5th July 2008 16:38
Is the Aveo really so bad as compared to the Fiesta?? Puffdamgcdragon Sedans 64 17th July 2006 12:03
Which box do u recommend for this woofer ? Result will be compared ! low_bass_makker In-Car Entertainment 10 17th April 2006 10:13
Compared-ZMA vs 180 dtsi-type 1... veyron1 Motorbikes 87 28th March 2006 05:39
Car Prices In India Compared To States IndianDawg The Indian Car Scene 12 9th December 2005 18:10
