Old 22nd May 2012, 20:58   #1
R-Six's Avatar
Thanked: 224 Times
Default Audi e-bike: A bicycle that runs at 80 kmph
Hey All,
I was browsing over the web and stumbled upon this wonderful article in Yahoo News! A cycle that can run at 80kmph!
Hell yea, you read it right! Audi unveiled this amazing creation in Austria. Looks super hot!
Here is a link to the complete article: Audi e-bike: A bicycle that runs at 80 kmph
Mods, tried searching for any related article but couldn't find any. If find inappropriate in this section, please feel free to shift accordingly.
Best,
R-Six
R-Six is offline   (2) Thanks Reply With Quote
Old 23rd May 2012, 00:06   #2
NinadJoshi's Avatar
Thanked: 245 Times
Default Re: Audi e-bike: A bicycle that runs at 80 kmph
Some more info on this one, courtesy Zigwheels:
The lithium-ion battery is incorporated into the frame and needs 2.5 hours to fully charge and is easily replaceable.
The frame and the swinging arm that holds the back wheel are made of carbon fibre-reinforced polymer (CFRP). The same material is used for the 26” wheels, which feature broad flat spokes for an optimized transmission of pedal power.
At the press of a button, the seat then rises up and the biker can adopt a comfortable position. The electric motor is located at the lowest point on the frame and drives the bottom bracket shaft directly. The maximum torque delivered to the rear wheel is 250Nm. The electric motor generates a maximum output of around 3bhp. The complete bike excluding electrical components weighs 11kg.
Cycling modes and other functions can be set using the touchscreen on-bike computer. The computer on the bike can connect to the internet and compare your performance on the bike to others who have the same bike.
The cyclist can choose between a total of five cycling modes – pure muscle power, the electric motor alone, or pedaling supported by the electric motor. In the pure mode, the drive power is purely the product of the cyclist’s legs, while in pedelec mode the rider is supported by the electric motor that then makes speeds of up to 80km/h possible and gives you a range of 50-70 kilometres. If you select eGrip, the Audi e-bike Wörthersee runs solely on the electric motor and can reach a top speed of 50km/h. The cyclist then controls forward momentum using a gripshift and can configure the power as desired using the computer.
Detailed report at : Audi showcases performance e-bike| Zigwheels.com
NinadJoshi is offline   (1) Thanks Reply With Quote
Real Innovation! Convert your pedal-operated bicycle into an electric bike anandpadhye Technical Stuff 3 17th April 2016 13:15
A different travelogue- by bicycle in the Himachal prabuddhadg Travelogues 35 2nd June 2008 12:11
Watch this burnout on....... A BICYCLE !!! salilpawar1 Shifting gears 14 6th March 2007 00:24
Mercedes Benz Bicycle in India RX135 Shifting gears 11 24th June 2005 17:25
