| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2006 Location: Bangalore
| It hapenned yesterday I was shocked to see that the Petrol Tank of my just 2 years old Fiero F2 is leaking petrol . I had filled up 4 ltrs of petrol just some hours back back and in no time the tank became empty before my eyes. I managed to take it quickly to a local garage nearby and they managed to save only half a litre of petrol . I asked them to fix the problem temporarily so that I could take it to TVS Service Station. Worst thing is when they were putting the Sealant (M-Seal) in the leakage area, from inside as well as outside the tank, the found the entire tank is corroded by rusting of inside wall. And one can easily poke through the rusted wall to create a hole. I still wonder how it could happen so fast ?? And whom should I blame ?? I really dont know how it hapenned, that too my vehicle is relatively new and well maintained. When I enquired with the service Engineer from TVS they told that the tank replacement would cost me Rs.3200/- and that would not be covered under insurance since I this is not due to any accident. I am really shocked with this kind of bad thing hapenning to my bike (which is still new, had bought it on 2004 Jan). Note From Moderator - TBHP Policy allows only 2 smileys per post. Please read THIS immediately. Last edited by v12 : 12th April 2006 at 13:03. |
| | #2 (permalink) |
| Senior - BHPian | Blame it on TVS guys who makes the bike. No one else. What you could have done?? (No point in telling it now, still heres the solution) Add a little 2T oil in the tank along with petrol. Say about 20ml for 3-4 litres. It will give a oil covering the tank inners preventing rust for some time. This is no permanent solution. 4stroke bike tanks are detined to rust because no oil is added in the tank like 2 stroke bikes(eben if you have a oil pump) |
| | #5 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Feb 2004 Location: Bombay / New York
| Quote:
How full do you keep your tank on average? If you are one of those people who uses is sparingly till the last drop and then re-fills, think again. By keeping the tank full will fuel, you are helping prevent rust. I'm not sure how bad the condition of your tank is (sounds REALLY bad from your description of poking though with your finger), but there is this expoxy that they use for marine applications that you can coat the inside of your tank with. You might want to consider that. Ask your local mechanic, he will probably know. cya R | |
| | #6 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Quote:
Sourav, Rehan has given you the right reasons though for the happening. Remember, if you fill up the tank occassionaly and then the fuel level drops down and stays that way for a long time then you got this problem coming. Never fill more than you use up say in every one week. Earlier I used to fill upto 4 liters in a week... Nowadays since I primarily drive the car I never fill more than what I need... I just consume that much up in a day or two and then again the bike is back in reserve and keeps waiting for the next week end when I again run her around for local errands. By the way yours is a typical problem that many TVS owners have complained about in the past. I am aware of two similar cases. I think unlike other manufacturers they do not treat the tanks with anti-rust coats.
__________________ Announcements are important. Last edited by Zappo : 12th April 2006 at 11:57. | |
| | #7 (permalink) | ||||
| Quote:
Just an update: I spoke to the senior engineer in TVS Service Station, and he told this would have hapenned if you use Power Petrol (very high octane) petrol in your TVS bikes. That would definitely corrode the petrol tank and cause the rust. The corrossion is also possible due to the bad quality of petrol from fraudulent petrol pumps. Also the engineer is giving me a 10% discount on the petrol tank and no labour charges. So now I would have to pay Rs2750/- instead of Rs3200/-. Quote:
Also cant blame on TVS, because my friends are using it without any problem. Quote:
I usually keep the fuel above the reserve and fill up whenever it goes to the reserve. I usually refill for Rs100-200 max. I never fill up the tank to full as I dont travel a long distance; Also considering the fact that the octane value of petrol decreases due to prolong storage. Last edited by souravbasu : 12th April 2006 at 11:59. | ||||
| | #8 (permalink) | ||
| Quote:
Thats actually the opposite of what i was suggesting!! I was suggesting to keep it FULL as much as possible, as that would (IMO) prevent rust! Quote:
cya R | ||
| | #9 (permalink) | |
| BHPian Join Date: Mar 2006 Location: Thane
| Quote:
Anyways now since the damage is already done ....... A suggestion , before changing the tank from the TVS service guys try asking some garage wallas also, (those u know very well) cause showroom guys allways charge more (the tank cost+the fitting cost). | |
| | #10 (permalink) | |
| Quote:
Dude u got it wrong than what Rehan is saying... Anyways, I havent heard ,petrol causing rust... Can you please explain how and why ? | |
| | #11 (permalink) |
| BHPian Join Date: Aug 2005 Location: Bangalore
| Rusting of fuel tanks is quite common with TVS Bikes. My Shogun's fuel tank was replaced FOUR times under warranty by TVS. TVS engineer had suggested me to put about 50 ml 2T oil for a full tank of petrol on a regular basis to avoid the rust. So, the last replacement did not suffer from the Rust malice for a long time. But, now the tank has rusted through and through since it is used sparingly. Guess the anti-rust coating should do the trick. Sad that TVS has still not found the solution for this problem. -HARSHAVARDHAN |
| | #12 (permalink) |
| Now I am confused :( !! Which one from the following option is the recommended to prevent rust in fuel tank ?? Option 1: Always fill the tank to the full. Option 2: Fill the tank with how much ever it is required. Please help !! |
| | #13 (permalink) | |
| Quote:
![]() Keep the tank FULL Heres a nice explaination, though some of the stuff mentioned (fuel pump) applies only to cars. And just to clear your doubts, it's also mentioned here, and this site says Gasoline also contains chemicals such as lubricants, anti-rust agents and anti-icing agents that are added to improve car performance. So basically its the moisture that evaporates from the petrol that causes rust, and it is given more of a chance to evaporate the more empty space(air) there is in your tank. And something tells me that Indian fuel will have more moisture than most other fuels due to adulteration! cya R | |
| | #14 (permalink) | |
| Thanks !! Now I know what to do FILL IT TO FULL. I am planning to start a new thread (under "Technical Stuff" Forum) on this so spread the same awareness to others. And also to know others habbits and best practises for refueling their fuel tanks. Quote:
| | #15 (permalink) |
| Hi All, I got a free replacement of the fuel tank (absolutely zero expense). The senior engineer in TVS Service centre had helped me a lot and he only suggested me write a request letter to the company asking for free replacement. After two days I got the replacement. I guess this was made because of their goodwill. I also came to know that we should fill the fuel tank only upto 75% and not to 100%. There should be some space for the air to expand otherwise the vaccuum in the tank may result inadequate supply of petrol to the engine. I was also adviced to use "Iftech cleaning oil" (additive). Each pouch of such oil costs Rs4/- and to be added to 2.5ltrs of petrol. I have added 2 souch pouch to 5 ltrs and since two days I am feeling vehicle much smoother. Cheers! SOURAV |
| Thread Tools | |
Similar Threads | ||||
| Fuel tank capacity measurement, how? | giri | Technical Stuff | 36 | 5th September 2007 19:08 |
| Location of the fuel tank lid? | mohit333 | Technical Stuff | 4 | 23rd July 2007 02:44 |
| fuel tank 42lt.- fuel in-44lt. | v.tec | Technical Stuff | 55 | 29th August 2006 20:50 |
| Santro fuel tank and siphoning | johy | Technical Stuff | 6 | 22nd April 2006 19:28 |
| can the fuel tank capacity be increased | speedsatya | Modifications & Accessories | 3 | 28th May 2004 19:22 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
