Old 15th April 2006, 12:59   #1
Post pulsar 180 mods
hey...
i have a pulsar 180dtsi 2k6 model.... im intersted in knowin how to make it go faster??? i'm thinkin bout usin a k&n R-1060 fiter... any better ones to use??? what about tyres sprockets n free flow exhaust systems???
how would these affect the mileage???
was also wonderin if i should install an autocop kit???
hopin to hear from u guys soon....
greendevil is offline   Reply With Quote
Old 15th April 2006, 14:37   #2
turbo_v12's Avatar
This forum was where we had discussed quite a lot...
U will find almost all the help you need...
http://www.team-bhp.com/forum/motorb...lp-me-out.html (Hey bike maniacs...PLS HELP ME OUT!!!)
Just,.....
after fitting an air filter - upsizing the carb jets would help, and decide whether you want to increase aceleration of the bike (which is when you drop teeth from the sprocket), or top whack...
Cheers...and happy riding hard...
turbo_v12 is offline   Reply With Quote
Old 15th April 2006, 14:56   #3
veyron1's Avatar
Thanked: 38 Times
@turbo v12: you drop the teeth on the FRONT sprocket to increase acceleration, but decrease top end. you drop some teeth on the REAR sprocket to increase the top end, but lose out on initial acceleration.
@greendevil;simply installing k&n will not be of much consequence. try tuned (free-flow) exhausts with a rejetted carb first, since you're running the slightly restrictive 'exhaustec'. second, try getting 18 inch alloys instead of your O.E 17 inchers; sure, the gearing will go taller (since wheel upsizing will affect the final drive), but the bike'll also be faster.
veyron1 is offline   Reply With Quote
Old 20th May 2006, 14:25   #4
hey guys.. thanks for the suggestions.... veyron... what all free flow exhausts are available.... n where can i get them from??
Old 21st May 2006, 12:11   #5
mail4ajo's Avatar
Thanked: 261 Times
Free flow for bikes are made by several people in the country. We also have imported ones like HRC, Yoshimura etc. But see which ones are custom made for your bike. Exhausts are just not "fix and ride" accessory. They are many calculations based on what is it fabricated. If you just fit any, it will fry your valves.
Try for a custom make. If you have any contacts in chennai, try the tectrac or the proton exhausts.
mail4ajo is offline   Reply With Quote
Old 21st May 2006, 12:30   #6
mail4ajo's Avatar
Thanked: 261 Times
Some snaps I found for Tectrac and proton exhausts.
Old 2nd June 2006, 20:16   #7
thanks dude...... i'll see if i can get hold of one........ by the way. how much of a difference will it make on the initial n top end???
Old 4th June 2006, 14:19   #8
Thanked: 21 Times
Generally, puting protons exhaust or even tectrac exhuast gives u good mid range in ur bike. As fitting , it will give good intial pick up, n for good mid range u can fit a tectrac exhaust.
nosfreak is offline   Reply With Quote
Old 6th June 2006, 22:27   #9
guys... i've got my knn filter installed.... there was a bit of gain in horsepower but nothin out of this world.... will the exhausts be a better investment in bhp terms??
Old 6th June 2006, 22:47   #10
jkdas's Avatar
Thanked: 1,436 Times
did you change the jets? upsize I mean
Old 16th June 2006, 12:38   #11
no... havent done that yet.... what size should i use??? n how am i supposed to do that???
Old 16th June 2006, 17:46   #12
mail4ajo's Avatar
Thanked: 261 Times
Source a jet that is atleat 10 sizes larger than your stock jet size. For example, Ambition jet size is 95. So I need to source a 105 size jet. Luckily CBZ jets are 105.
Old 16th June 2006, 19:32   #13
nikkibike's Avatar
Default Hi Ajo,
Any idea bout Pulsar 150 DTSi stock jet size??!! And which is the best upsize jet I can fit-on directly?
Nikhil.
nikkibike is offline   Reply With Quote
Old 19th June 2006, 13:12   #14
guys, can anyone tell me where can i get KNN filter in bangalore?
adityaac is offline   Reply With Quote
Old 19th June 2006, 16:20   #15
Thanks Sushrutha,
I have Bajaj Pulsar 180 dtsi.
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Vtec vs Karizma vs Pulsar 180 dts-i Shan2nu Street Experiences 75 31st January 2010 12:06
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
The CBZ vs The Pulsar 180 Wraith Motorbikes 53 7th July 2005 11:41
