Old 15th February 2015, 23:37   #91
ashis89's Avatar
Thanked: 1,351 Times
Default re: Bajaj Pulsar 180 : Long term ownership report. Edit, sold!
Originally Posted by Rugged View Post
Hi
I have noticed slight oil leakage at the oil-level "check" on the bottom right side of the engine. I never saw this before .
What might be the issue?
Experts please educate me on this .
Its a Pulsar 180 Dtsi 2006 model. Sevicing was done 5 months back and I hardly use the bike (I can say a few Km's/ Week), as I have another bike a Bullet to commute daily to office.
Is it the transparent glass on the gearbox? In earlier days, the glass used to crack leading to oil leak. Clean the area with some soap water and observe for a few days. Also check if the oil level has reduced significantly (topup the oil if necessary). If the oil leak persists then you need to change the glass or the gasket around it.
ashis89 is offline   Reply With Quote
Old 16th February 2015, 07:12   #92
mehuel's Avatar
Thanked: 77 Times
Hi
The oil seal on the glass window often gives way over a period of time. Its an easy fix, next time you get the oil changed, just get the oil seal of the glass window changed aswell.
mehuel is offline   Reply With Quote
Old 2nd June 2015, 11:51   #93
ashis89's Avatar
Update: Bike Sold
I found a new home for my bike. With my studies over, I am about to move to Hyderabad for my next job. Even though I longed to take my bike along, my father thought it to be "risky" and "unsafe" to ride a "powerful" and "speedy" bike at this age (he says I am getting old and matured ). Thus he requested me to let go of my bike and "slow down". I had to relent so as not to hurt him. He was happy and the next thing he says is, "nothing to worry. You have your car for regular use. Buy a new Activa and ride it whenever you feel like riding" .
Thus after 33 months and 18k kms, the bike has moved on to another caring owner.
Update for the last 4 months:
- Engine oil was changed after 1.9k kms/8 months to Elf Moto Gold 20W50. The bike felt smooth as usual.
- The chain was tightened after ~1.5 years/5k kms. Inspections every 500 kms showed that it was perfect. First time I saw a Bajaj bike holding the chain tension for more than 2k kms. My earlier 2 bikes' chain needed attention every 500-1000 kms.
- After 32 months, original battery (Exide make) got discharged every 2-3 days a few times. Got it replaced with a Amaron (1400 INR. after replacing the old one) without inspecting the old one (my blunder). After a few days I faced the same discharge problem again. I suspected some leakage and took it to the battery shop. They found some leakage in the Minda security system that I had fitted (probably some rodent mischief). They simply disconnected the security system and charged the battery. The problem never recurred in the 20 odd days that I had the bike before selling it off.
- I realized the original battery was absolutely fine. Had I inspected the wiring earlier, the Exide battery would have run fine for some more time. For reference sake during Dec'14 to Mar '15, the bike stood idle for 20-25 days at a stretch and yet started in a single self without any drama.
Note to Mods: You can close this thread or keep it open for the benefit of other owners' discussion.
Long term ownership report - Pulsar 220 DTSi parik_ind Motorbikes 46 22nd March 2016 18:16
Long term ownership report of Pulsar 150 DTSi ashis89 Motorbikes 10 14th August 2015 20:52
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
Short Term vs Long Term Ownership, New Car vs Used Car Ownership architect The Indian Car Scene 10 9th May 2008 11:39
