Old 27th August 2015, 13:38   #16
Thanks Navin_v8, given its holidays here, most of the seat shops are closed. I will go with the bum break in theory
I will see if I can get a hold of the gel pack for now. Thank you.
sreenath13 is offline   Reply With Quote
Old 27th August 2015, 17:33   #17
Default Re: Tailbone pain on Royal Enfield Thunderbird
I had the exact same issue with the seat on my Iron. I could ride it only for 45 mins at a stretch and then my tailbone started hurting. I searched all over the internet for a solution but didn't get a certain solution.
So to experiment i bought a gel seat pad from redline plus, Pune.
It helped to an extent and i could now easily drive for 50% more time but didnt solve the issue completely.
Then i took a gamble and bought a sundowner seat primarily because it had much more padding and voila, my pain was gone and i can now easily drive for 150 odd KM's before i need a break and the ride is much more comfortable.
Hope this helps
fiorano88 is offline   Reply With Quote
Old 27th August 2015, 18:45   #18
Thanks fiorano88, Is there a link to read more about the sundowner seat or pictures that you may have handy ?
Old 27th August 2015, 19:16   #19
VW2010's Avatar
Thanked: 2,124 Times
Tailbone pain to me is more of radiating paid due to posture. When you sit on the bull are you have a 90 deg bend at your arms while your arms are tucked within your body.
The tailbone pain is purely your posture and i get it even in cars sometimes only to realise i am either leaning too forward or i am too away from the handle.
1) Are you reaching out to hold the bike?
2) Are you bending down because of your heignt to reach the handle bars
3) How is your leg position.
4) Are you feeling cramped at the legs as well.
In a racing bike if you look at the riders position its fairly at right angles all around.
My aim always would be to correct this right angles.
I use a wider handle bar in my bullet and on long rides i ensure my back seat is filled with things to actually lean on
The RD handle bar is good, but you need an extended RD handle bar to free that crampedness it creates for tall folks. My handled bar before the wider one i have was RD extended. It was custom made and it has the same shape and form as RD but much wider and closer to my body.
I also tend to ride with my foot on the rear pegs. And post that made some adjustments and customization on where i keep the foot.
Not adviced but i ride 99% on front brakes and hardly use the rear and also since i used the CI engine i always had the neutral lever which meant i was either at neutral or riding at 4th gear at whatever speed
- Raise your seat if required
- Get rear support if possible including a belt
- Check if engine vibration is higher. If so try to find ways to lower then. Rubber support at points where it will help
- Check the suspension setting as well. If its too hard you are taking most of the road hits.
- Most importantly see if your shoulders are at relaxed position and your legs are failry relaxed as well.
Make modifications to handle bar and foot pegs that will make your position far more relaxed.
VW2010 is offline   Reply With Quote
Old 27th August 2015, 20:20   #20
Shanenanigans's Avatar
Thanked: 98 Times
I have a feeling your tailbone pain is not because of the seat of the bike, but your posture instead. I used to ride an avenger, and since I'm 6 feet tall, I used to ride like I was reclining on the bike. But the thing is, it isn't a Harley and I started developing tailbone pain. I fixed my posture, sat more upright on the bike, (and specifically stopped crouching and stooping) and since I had long hands, stayed a little closer to allow more free movement of my rear end.
One more thing - your regular seating position (say while riding to work and doing chores) is very different from your touring position. The former should ideally be designed to have quick access to both the rear brake and the shifter, put the foot down in case of slowing or stopping, etc. The latter should be designed so that you're sitting in a more natural body position. An example on my current CBR250R is I sit in front, close to the tank, while riding to work and all, even though most of my trip is on the outer ring road in Bangalore. But while touring, I sit further back so my body goes into a more comfortable crouching position, my knees are less bent, and the balls of my feet are almost on the footpegs. At this point, for curves/lane changes, I'll be using my knees/feet to tilt the bike. While this may not seem relevant, your body works as one entity, and more pressure on certain areas result in lesser pressure on others.
Someone correct me if I'm wrong. After all, I've put over 70k miles in cars and only 10k on motorcycles.
Shanenanigans is offline   Reply With Quote
Old 27th August 2015, 22:01   #21
I can surely send the details but these seats are Harley OEM and are bike specific.a seat upholsterer can do the same job for much lesser and will be equally effective.
The details are widely available online. If i can be of any help,please let me know
Old 14th September 2015, 18:07   #22
Thanked: 70 Times
Originally Posted by shivshan View Post
Hi
I have a 2003 TB that's sparingly used ( 13k km). I have started riding regulary within city over the last few months and while i am quite happy with the bike, am now facing severe pain in my tail bone. It's no fun riding in pain.
Shivshan
Shivshan, even I have the same issue with my TB but not on my Continental GT, the pain happens because our bum - from the tailbone to the coccyx region is being pressed. One solution is to get a gel seat with a depression in the centre so that the raised area ensures your tailbone is not being pressed. A lot of bicycle riders who do long distance riding have it put on their seat. The other option is to get yourself a Airhawk R seat which is available on amazon.com. It's basically a seat cushion with air pockets that stand up when filled with air like large blisters. This ensures that relief for the tailbone and coccyx region as well as the under side of thighs which get raw because of sweat. Hope this helps.
gopalmg is offline   Reply With Quote
Modifications - Royal Enfield Thunderbird agbenny Motorbikes 52 28th April 2018 08:29
How much for a 2006 Royal Enfield Thunderbird? streetrage911 Motorbikes 8 1st October 2013 07:33
Royal Enfield Thunderbird with Twin Spark madbullram Motorbikes 125 17th July 2013 12:46
Need information on Royal Enfield Thunderbird torque.steer Motorbikes 10 6th March 2010 20:29
I brought her home finally…(its a Royal Enfield Thunderbird) vinayvtec Motorbikes 87 22nd August 2008 23:00
