Closed Thread
Old 9th April 2013, 23:28   #376
praful's Avatar
Thanked: 442 Times
Default re: KTM Duke 390 - 375cc, 45 PS, 150 kg
Looks like 0-100 of 5 seconds .. with a mis-shift!!
Last edited by benbsb29 : 10th April 2013 at 09:38. Reason: Correcting video embed.
praful is offline   (2) Thanks
Old 10th April 2013, 02:10   #377
This is much better than the 7 seconds I was expecting.
0-100 :5.1seconds
0-120 :77.7seconds
0-140 :13.6 seconds.
Also, you might want to see this to have a look at the bike, with ABS, by the way
This video was posted on the 9th of April, so I am guessing they should launch it in India today as well. Keep your fingers crossed.
jhonmathews is offline
Old 10th April 2013, 04:41   #378
Joxster's Avatar
Thanked: 520 Times
I like the sound of the Duke 390's engine in the video. Not that I like the sound of the Duke 200 any less, because it is addictive
Joxster is offline
Old 10th April 2013, 07:39   #379
praful's Avatar
Thanked: 442 Times
I think the real sound of the engine is muffled because of the GoPro or whatever recording device they are using.
I wouldn't go by that sound in the video.
praful is offline
Old 10th April 2013, 10:14   #380
aks_karthik's Avatar
Thanked: 232 Times
I've just spoken with KTM, Manager, Adyar, Chennai.
He told, KTM Duke 390 will be launched only by June 2013.
Today they are launching Kawasaki Ninja 300 and already some consignment with Green and whiite has come and is in Display.
Kawasaki Ninja 300 - Ex.Showroom - Rs. 3.6 Lakhs (OTR 4.25 lakhs) approx.
aks_karthik is online now
Old 10th April 2013, 12:09   #381
ebonho's Avatar
Thanked: 3,182 Times
Originally Posted by jhonmathews View Post
Though now, I am pretty confused as to how the wind dynamics actually work. some say the Fairing cuts through the air as well.
A fairing is designed for aerodynamics in the direction of motion - i.e. moving forward into the wind.
A cross wind hits you from the side. There the fairing acts like a sail, providing increased surface area for the wind to buffet.
Anyways, no matter how heavy your bike, even a big Harley, if the cross winds are strong enough, you will need to slow down and exert and compensate against the direction of the wind. Its nature.
3. I did hear of a few people who ended up with scratches on their lower side of the fairing on their CBR while riding to leh.
Courtesy: arunrk85 @ www.xbhp.com
This is the "effective" ground clearance of a Ninja 300. Yes you can thread your way gingerly avoiding small rocks and even medium deep troughs and depressions, but would it be any fun?
Ride the bike normally, and you would be coming back with zero scratches to show for your efforts.
Why?
Because you left the lower part of your fairing somewhere up there .....
P.S. Please no "sir" buddy.
ebonho is online now
Old 10th April 2013, 13:39   #382
nasirkaka's Avatar
Thanked: 531 Times
All the discussions/ videos etc are fine but where is the real thing??? Looks like all the halla about 10th launch was a part of extended fools day!! Emotional atyachaar. Was really looking forward this day, but the wait seems to continue.. :(
nasirkaka is offline
Old 10th April 2013, 14:49   #383
praful's Avatar
Thanked: 442 Times
Actually that front bit won't touch at most speed breakers, unless one is ridding on uneven rocks.
Because, that front end will get lifted when the wheel goes over a bump, its the middle and rear end of the fairing that would have to be worried about.
I'm playing that 390 acceleration vid again and again, still unable to believe this faster than the N650 to 100!
praful is offline
Old 10th April 2013, 14:52   #384
n_aditya's Avatar
Thanked: 2,779 Times
The only thing that i have managed to scrape is the underside of the rear shock absorber on really huge speed humps. But taking such speed humps at crawling speeds will not scrape the bike.
n_aditya is offline
Old 10th April 2013, 14:54   #385
ebonho's Avatar
But then equally, this is taken on an unladen bike on the side stand. Speed breakers are not what I am worried about.
In fact, even though the Duke has good ground clearance on paper, the ridiculous pointed beak at the bottom seriously reduces the "effective" ground clearance. What the SUV guys would call the "approach angle" I guess.
Yes, I've seen you getting excited everywhere. I will check it out once I am home as utube is blocked here. Good things come to those that wait!
Personally I would still feel cheated though if its not closer to 180 than 170.
Old 10th April 2013, 15:15   #386
Thanked: 459 Times
...the ridiculous pointed beak at the bottom seriously reduces the "effective" ground clearance.
Can't that beak-thingie be removed? Does it serve any practical purpose on the bike (apart from design/looks)?
You said it Doc.
am1m is offline
Old 10th April 2013, 15:18   #387
ebonho's Avatar
The beak is a good tough hard plastic sump guard. I have bashed and scraped it a couple of times pretty good. So unless I get a tougher metal one, I am keeping it on. No other "functional use" I guess.
P.S. Even the WR250 of Ashish Maudgil which I checked out at the IBW has a hard plastic sump guard. Not metal.
ebonho is online now   (1) Thanks
Old 10th April 2013, 23:05   #388
Joxster's Avatar
Thanked: 520 Times
The Sump Guard is the only part of my bike I scraped, and it happened just once due to my not being conscious about the weight of the pillion at the back. Has never happened otherwise.
A gentle reminder from KTM that this bike is not really made to have someone sitting at the back
Joxster is offline
Old 11th April 2013, 03:34   #389
GreaseMonk's Avatar
Thanked: 87 Times
Will adjusting the preload mitigate scraping with a pillion? On a friend's KTM I couldn't put the side stand down while sitting on it due to my well-endowed-big-bonedness.
GreaseMonk is offline
Old 11th April 2013, 10:04   #390
ebonho's Avatar
To an extent it will. The factory setting of 3 is way too soft. 6 seems ok for me solo, but the bike was close to bottoming out with fully loaded saddlebags on hitting at speed undulating dips in the road. 7 would have been better.
Closed Thread
The KTM Duke 390 Ownership Experience Thread parrys Motorbikes 6220 27th June 2018 18:00
My Tryst with Orange: KTM Duke 390 sriramv.iyer Motorbikes 257 4th December 2016 09:46
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
Bullet Thunderbird TBTS 500 versus KTM Duke 390? sridhu Motorbikes 174 29th November 2015 17:53
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
