Old 15th November 2012, 11:28   #1
Default Fuel leak from the carburettor (Royal Enfield CI)
All,
Today morning, I notice this fuel leakage from the carburator of my enfiled ( 1999 model, 350 CI, 20kms done). Have been browsing teambhp since then.
I see certain other threads which point to 'float' or a 'needle' problem in the carburator. I thought I will post the pics and consult anyways.
Photographs are taken after I cleaned the fuel on the bottom of the carb.
To elaborate, Yesterday evening I rode all the way to Ranigunj from Mehdipatnam to meet Sudhakar Anna. (Wanted some basic service done since the bike is my new acquisition.) Unfortunately his shop was closed. ( But atleast located his shop). I came back home and forgot to close the fuel tap.
Today I see this leakage :(. The leakage stops when I close the fueltap properly. But it starts immediately, once I open it.
Here is pic1. The fuel drips exactly from where the arrow points. (accumulates and drips since that is the bottom most point)
The area circled seem to have the fuel accumulated. The source of the leak is not on the lateral surface of the carb. But somewhere in that circled portion.
Please help, if you have come across such a issue.
-Vivek
8090guy is offline   Reply With Quote
Old 15th November 2012, 11:40   #2
Jaggu's Avatar
Thanked: 8,695 Times
Default re: Fuel leak from the carburettor (Royal Enfield CI)
Its classic overflow case.
Check - Float level - Best to take to competent mechanic.
Check - Float Pin - If its worn out or getting stuck - Again a competent mechanic is the best bet, if you are not a DIY guy.
Jaggu is offline   (2) Thanks Reply With Quote
Old 15th November 2012, 13:59   #3
Thanks Jaggu. I'm not YET a DIY guy. I am taking it to an expert mech. But could I ride the bike for 10 kms in its present condition?
I was supposed to visit the mechanic today but since I saw this leakage, postponed it by a day so that I can do so research.
Old 15th November 2012, 14:26   #4
Thanked: 175 Times
Default Re: Fuel leak from the carburettor (Royal Enfield CI)
Take to a mechanic and get it sorted.
desideep is offline   Reply With Quote
Old 15th November 2012, 17:39   #5
Float trouble. Usually a simple cleanning & adjust is enough. If you are worried about riding to the mech, switch off the fuel tap once the overflow starts. Ride the bike and once it starts missing open the fuel tap again. Close the tap before it overflows again. Painful but can be done.
Leop is offline   Reply With Quote
Old 15th November 2012, 19:47   #6
Simple job. Just take it to a mechanic and he will fix it. Nothing so major to worry.
WanderNomad is offline   Reply With Quote
Old 15th November 2012, 21:02   #7
drsingh's Avatar
Thanked: 484 Times
To take it to the mechanic wrap a brick in a towel and hit the Carb from below. This will dislodge the obstruction and close the float. I learned this the hard way!
Most probably your float is eroded and is flooded with petrol.you will need a new one.
drsingh is offline   Reply With Quote
Old 25th November 2012, 00:17   #8
Thanks everyone for your kind reply's. The leak stopped on its own next day .
I finally managed to take it to him today( I was sick last w/e) who said that, sometimes due to dirt accumulation in the carb, fuel leakage happens. If the leakage has stopped, well and good. Will get in checked as a part of full service.
Old 24th October 2016, 11:36   #9
Hudson's Avatar
Folks, will the bike(Bullet CI) start if the carburettor is flooded? I am trying to start the bike but no success. Tried for 20 min & gave up with a sore right sole.
Hudson is offline   Reply With Quote
Old 24th October 2016, 11:45   #10
The Great's Avatar
Thanked: 643 Times
If the carb is overflowing, either tap lightly on the side of the carb and wait for sometime and then try to start it (desi method as we call it, and it worked many times for me), or else get a mechanics help who will adjust the float.
The Great is online now   (1) Thanks Reply With Quote
Fuel Taps in Royal Enfield shantanupsingh Motorbikes 4 25th August 2011 11:16
When did Royal Enfield become "Enfield"? pullin Motorbikes 1 25th June 2010 13:34
500cc Royal Enfield vs NEW 350cc Enfield scottoe Motorbikes 22 13th October 2009 16:47
Petrol leak from Carburettor - Mach 500 Ketan Technical Stuff 5 12th July 2007 13:19
How does one find a vaccum leak in a carburettor? techn0l0gist Technical Stuff 1 14th January 2007 00:54
