Old 13th January 2014, 14:27   #136
Default Re: Bajaj Pulsar 200 NS : Ownership Review, 2200 Kms
Sorry for changing the topic. but i need some help here.
My 200Ns is 10 days old and 250 kms ridden, The front fork seems to be bent a little to the left. I did take the bike to the Bajaj dealer and the mechanic assured me there is nothing wrong with the front fork, I still feel the fork is bent to the left ( the console seems to be tilted to the left & the bike feels wierds when turining to the right ) I find it hard to trust the dealer.
Is there any way in which i can check if the fork is bent ( apart from showing to a mechanic).
aashish.shah is offline   Reply With Quote
Old 13th January 2014, 19:39   #137
Akhilash95's Avatar
Thanked: 61 Times
Originally Posted by aashish.shah View Post
Sorry for changing the topic. but i need some help here. I still feel the fork is bent to the left ( the console seems to be tilted to the left & the bike feels wierds when turining to the right ) I find it hard to trust the dealer. Is there any way in which i can check if the fork is bent .
Firstly make sure the tyre pressure is at factory recommendation. On a closed empty road , ride upto 40kmph, come to neutral and take off both your hands from the handle bar, if the bike doesn't travel in a straight line at least upto 25kmph, then there might be a fork bend. A simple jugaad would be to place a steel scale beside the inner tube. If there is any gap between the scale and fork ,it suggests that the fork is bent.
(a misaligned rim also shows similar symptoms )
OT- we tend to blow up small things out of proportion on a new bike. Just enjoy the ride and don't worry about every small sound or feeling.
Akhilash95 is offline   Reply With Quote
Old 14th January 2014, 01:21   #138
preetam_KORG's Avatar
Thanked: 378 Times
Check the cone set, it may be way too tight, this is by far the most common problem on all bajaj bikes.
Also check if the front disc rotor is jamming up against the disc pads, if so get it rectified.
Finding that sweet spot where all ergonomics match up to your posture takes some fiddling. 250 kms is way too small to judge that. Ride some more and find out.
preetam_KORG is offline   Reply With Quote
Old 30th January 2014, 18:19   #139
katchkamalesh's Avatar
Thanked: 160 Times
Its been 45 days since I gave my battery for replacement and I have still not got the call from ASS regarding the replacement.
ASS says that the battery is found to be faulty and it will be replaced by exide. He says that 200 battery is low volume production and once manufacturing starts, I would get a replacement battery.
I feel that this is BS and I am not creating an issue cause I have been provided with a temp battery until the replacement arrives.
katchkamalesh is offline   Reply With Quote
Old 1st February 2014, 07:23   #140
Thanked: 378 Times
Its been sometime that I have updated my thread!
There is something really big coming up, keep an eye on the travelogues for more details!
A small teaser here to catch your attention! Bajaj Pulsar 200 NS : Ownership Review, 2200 Kms-imageuploadedbyteambhp1391219577.700645.jpg
preetam_KORG is offline   (4) Thanks Reply With Quote
Old 1st February 2014, 11:49   #141
Added_flavor's Avatar
Thanked: 913 Times
Looks like a good big republic day ride! Looking forward to a travelogue bro.
What windscreen is that on the NS?
Added_flavor is online now   Reply With Quote
Old 1st February 2014, 12:51   #142
Thanked: 378 Times
It was a little bit bigger than that Added_flavor!
Its made for the 200NS by a company called Hindustan Motorcycles.
Old 1st February 2014, 18:31   #143
aviorp's Avatar
Thanked: 744 Times
Bigger? That was mammoth
Glad to have met you bro. Eagerly waiting for the travelogue. 3 Cheers to you mate and you hit the spa soon.
aviorp is offline   Reply With Quote
Old 14th February 2014, 21:40   #144
Achekay's Avatar
Hi guys, I need a little help here. My friend is having his 200NS delivered in a few days and having read less-than-confident reviews about the stock tyres wants to replace or upgrade/upsize them. Also, if the front tyre is kept stock, and only the rear tyre is changed, would it affect the performance or stability of the bike ?
We have zeroed in upon
Michelin Pilot Sporty Radial (Expensive)
Dunlop Radial/Nylogrip
Pirelli Sport Demon(Almost impossible to procure in Nagpur, please advise)
Hrushikesh
Achekay is offline   Reply With Quote
Old 16th February 2014, 07:58   #145
Thanked: 378 Times
Default Bajaj Pulsar 200 NS : Ownership Review, 2200 Kms
Hrushikesh
There is no Pilot Sporty Radial AFAIK, I guess you are referring to the Pilot Street, which retails at around 5300 INR for the rear stock section.
Pirellis are very difficult to come by, these tyres are sourced by the dealers from Baroda, see if you can get it from there.
There is a TVS tyre, ATT230R, a very good and sensible buy, and is also available in the stock section. Your best bet would be to choose between the Dunlop Tuffgrip and the TVS. Both should be about the same price, here in bangalore both are available for about 3500-3800.
As far as putting different tyres front and back, it shouldn't be a problem unless the compounds (hard, medium, soft) of the two tyres are drastically different.
Example: You should not put a metzeler at the rear and a stock tyre up front as the two tyres have very different levels of grip, and thus the handling of the bike will be adversely affected.
Hope that helps.
preetam_KORG is offline   (1) Thanks Reply With Quote
Old 17th February 2014, 22:40   #146
Majumdarda's Avatar
Thanked: 426 Times
When is your travelogue coming up brother? Waiting very eagerly for it.
Majumdarda is offline   Reply With Quote
Old 19th February 2014, 22:13   #147
tracerspiff's Avatar
Thanked: 113 Times
Hi Preetam,
Just got my membership confirmed and it is only apt to write my first post here.
I bought my Pulsar 200 NS in Sep last year and your thread was really helpful in making my decision. So thanks for your detailed ownership review! I have done 3500 Kms on my bike so far and I have not regretted my decision one bit!
I just love the way it lurches ahead when I wring the accelerator. You were exactly spot on when you meant the tyres lack grip. I have had "multiple" rear wheel lock-ups when braking.. even at moderate speeds. Will chuck my stock tyres soon.
Btw, I noticed a yellow 200 NS shod with PSDs at the HSR amba bajaj service center in a very bad state.. looked like it had been dragged along the road, one side of the handlebar was gone. was it yours? If so, what happened??
tracerspiff is offline   Reply With Quote
Old 20th February 2014, 00:59   #148
avishar's Avatar
Thanked: 986 Times
That was his bike,still is.Long story behind it!
Bike's all hail and hearty now.:-)
avishar is offline   Reply With Quote
Old 22nd February 2014, 23:29   #149
Thanked: 378 Times
Originally Posted by tracerspiff View Post
Hi Preetam,
Yes bro, that was my bike. However that is history and I am living every moment of my life in utter epiphany now. The joy is endless and the bike is as good as ever.
For all of you who have been wondering what I have been upto, here goes!
http://www.team-bhp.com/forum/travel...ke-1-soul.html (Discovering India : 8407 Kms | 15 Days | 15 States | 2 Wheels | 1 Bike | 1 Soul)
Lots of Love
Preetam
KA-51-EE-531
preetam_KORG is offline   (3) Thanks Reply With Quote
Old 26th April 2014, 10:04   #150
bullet_chacha's Avatar
Thanked: 274 Times
The Boss reached his hometown (Kolkata) early morning today.
1st Day : 900 Kms (16 Hours)
2nd Day : 1210 Kms (23 Hours)
Attachment 1184806
That is some serious riding Preetam. Well done! You deserve some rasagoolas
Nice looking saddle bags there...did you use any harness's for the same on the inner side between tire and bags as the saddle bags got torn as they made contact with the tire on my C5
bullet_chacha is offline   Reply With Quote
Bajaj Avenger 200 ownership review at 50,000 kms highway_star Motorbikes 42 29th November 2015 17:26
Bajaj Pulsar 180 UG4 - Ownership review. 2 Years & 13,000 kms nilaykmrsr Motorbikes 21 26th December 2014 22:49
New Bajaj Pulsar 180 and 200 bikes Gregory Motorbikes 57 12th October 2011 12:08
Maruti SX4 Zxi - 2200 Kms report sathya_nars Long-Term Ownership Reviews 411 10th October 2007 12:24
