Closed Thread
Old 11th May 2006, 09:28   #1
Default compression ratio
hello everybody,
is it possible to increase compression ratio of engine , if it is so then how we could do this for e.g i want to increase compression ratio upto 12.5:1 from 9.1:1 of my bike
devsus is offline
Old 11th May 2006, 10:16   #2
Ram
Ram's Avatar
Thanked: 149 Times
Originally Posted by devsus
hello everybody,
There are several ways to increase the compression ratio of your single-cylinder engine
  1. use a domed piston,
  2. increased the stroke,
  3. change to a head with a smaller combustion chamber,
  4. Shaving the head or block of your engine,
Higher compression ratio generally puts more stress on the piston, the connecting rod and bearings. We can't just assume that they will take the extra load, but must be very careful to build up the rest of the engine as needed.
Sometimes, just going with a thinner head gasket (if available) is a poor man's way to increase compression.
Ram is offline
Old 13th May 2006, 10:05   #3
Rehaan's Avatar
Thanked: 25,038 Times
Increasing compression ratio (Is it possible to increase the compression ratio).
cya
R
Rehaan is offline
Closed Thread
Is it possible to increase the compression ratio pratheesh Technical Stuff 30 10th April 2010 17:58
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
Variable compression ratio engine! amitoj Technical Stuff 8 20th December 2005 21:01
Compression Ratio and NOS Ford Rocam Modifications & Accessories 9 28th June 2005 03:13
Vtec's compression ratio!!! Shan2nu Technical Stuff 8 7th May 2005 23:07
