Old 2nd August 2017, 10:36   #31
Thanked: 18 Times
Default Re: Want to own a Honda motorcycle from the 70s
Originally Posted by ashwinprakas View Post
That my friend is a backfire!
Reasons:
1. You're running absurdly rich.
2. Your choke circuit is open.
EDIT:
Sorry, I missed to take the age of the motorcycle into consideration.
Please make sure your valves are operating as expected, a decent means of ensuring the same would be to conduct a compression test. A backfire can also be caused by the intake valve not sealing properly and Honda’s are known for stuck valves.
Thanks for the advice. By " Compression test", i guess you are asking me to check if there is alternatively vacuum and compression on the cylinder when the pistons move?. i did put my thumb on the spark plug hole and checked earlier and it did seem to perform properly. However , i will check once again and try to open the cylinder head to see if the valves are opening and closing properly too.
srini1785 is online now   Reply With Quote
Old 2nd August 2017, 10:57   #32
ashwinprakas's Avatar
Thanked: 926 Times
Unfortunately that won’t do, you would need a compression gauge to perform a compression test. First you would need to find out what the factory rated compression for the motor is, then you'd have to check your motorcycle and see if it falls within the recommended range. If yes then you can move on to diagnosing the fuelling, if not then first make sure that the piston and rings are fine and then do another compression test, if you are still not within recommended range then you would need to overhaul the head.
ashwinprakas is offline   Reply With Quote
Old 2nd August 2017, 11:34   #33
james's Avatar
Thanked: 544 Times
Suggestion: Fill in fresh engine oil. Put in a tiny bit of oil down the spark plug hole and then check the compression with a gauge. It should be 160+ PSI and almost equal in both cylinders.
If you got the bike without spark plugs or carbs or exhaust bend pipe in place, i would suggest opening and cleaning up the top end. You dont know what may have gone in there over time. Even the slightest bit of sand or mud is enough to ruin the motor. This way you can ascertain the condition of the liners as well. You will need a new packing kit to put the motor back together.
Cheers!!
james is offline   (1) Thanks Reply With Quote
Old 3rd October 2017, 15:44   #34
Thanked: 18 Times
Its been sometime since I updated this thread. I have not been able to do much on the bike since I was held up trying to start a TVS Suzuki supra power up model. However , I did manage to open the top cover and check the timing belt and valve seat. I have posted a video on this link
From what I have read online, this model seems to be a parallel twin. However , when you see the valve timing sequence, it seems to me that only one cylinder fires at a time. Am I correct?.
Meanwhile , I have got the upper sealing kit and have ordered the lower sealing kit. This next step is to just take the engine off the frame and check the valve timing.
Old 4th October 2017, 09:33   #35
MonsterPatrol's Avatar
Thanked: 141 Times
Nothing like finding a CBX 1000, the ultimate collectors bike for a Retro Bike enthusiast like me. Extremely hard to find though. I remember seeing an for it a couple of years back on Facebook. The dude was quoting FIFTEEN LAKHS!!
MonsterPatrol is offline   Reply With Quote
Old 11th June 2018, 10:21   #36
Thanked: 18 Times
Some Updates regarding the restoration. The bike is now painted and mechanically complete. The backfire issue has been sorted out. It was due to improper timing. The bike has been rewired. The cylinder head was also machined and now the engine starts without problem. However, it is still not a rider since there is a un pluggable leak from the front sprocket oil seal. By leak I don't mean a drop or two , it just pours.
I tried to find a suitable oil seal locally and also bought two of them from UK but no avail. I need some help in locating a suitable seal. The size I bought ( the one that came from UK claiming to be OEM seal ) is TC 20x34x7. I need to find a seal that is at least TC 19x35x8 if it is available. I also tried Anabond red quick seal maker with no luck. Any suggestion on how to select a suitable oil seal would be welcome.
Further , just wanted to know if the oil pore on the drive shaft ( pictured ) needs to be plugged or kept open?.
Harley brings back the ’70s with a low rider: The Superlow 1200T dkaile Superbikes & Imports 1 8th March 2014 12:39
God's Own Country, Linea T-Jet, Devil's Own Roads and Meen Pollichathu palitrana Travelogues 32 18th February 2014 17:35
Wayanad - 'Gods Own District' in 'Gods Own Country'!!.. dhanushs Travelogues 30 17th April 2012 14:36
Time to own my very own italian beauty - Fiat Linea Petrol E+ rajagopal_j Test-Drives & Initial Ownership Reports 50 13th January 2010 12:51
