Old 16th May 2006, 01:51   #16
mail4ajo's Avatar
Thanked: 261 Times
Check xbhp.com. you will fins tons of modded pulsars there.
mail4ajo is offline   Reply With Quote
Old 16th May 2006, 08:33   #17
nikkibike's Avatar
Default Hi 'mail4ajo'
Thanks a ton for that ref!!! I'll browse that site too...
Pl continue mailing!!
cheers
Nikhil
nikkibike is offline   Reply With Quote
Old 16th May 2006, 13:36   #18
mail4ajo's Avatar
Thanked: 261 Times
Check the new thread in Motorbikes section on Proton filters
Old 16th May 2006, 13:41   #19
nikkibike's Avatar
Hi Ajo,
Yeah I'll look into it!! thanks..
Pl continue...
Nikhil
Old 16th September 2006, 15:20   #20
vikram_d's Avatar
Thanked: 940 Times
My brother got his pulsar fitted witht he Unicorn mono-shock which didnt work out very well i'm afraid. The rear portion of the mud flapo used to touch the tyre when riding doubles. Even after adjusting the mono-shock to the stiffest setting this would happen. Also the height of the rear end increased considerably. So for the sake of easy getting on & off, I hope you are a tall.
Vikram
Old 16th September 2006, 17:46   #21
nikkibike's Avatar
Default hi there...
vikram_d, Well... the monoshock work is over now including slight modifications to the tail end to accomodate xma's tail lights! My mechanic was using the bike for the last one month to check whether any such issues pop-up after the initial set-in's.... I too test drove the bike and never felt any such problems due to the mod work!! Mine is 5'8" tall and felt real comfortable with the height settings... the bike is done with normal hieght settings only.. still no rubbing issues anywhere even with two jumbos onboard!!!
After such a long test stint... the bike is stripped last week for paint job!! I'll post the pics once it is back on the road!! I've completed almost all the mods I've listed here!! Now looking for Michelins front tyre with the same thread pattern as of thier rear tyre - Pilot Sport!! So far cudn't identify anyone who are dealing this!! I bot the rear ones from the local dealer here...but he doesn't have front tyre!!! Any infos with you??!!
Anyways... thanks for joining!!! Pl continue your comments...
Nikhil.
Old 16th September 2006, 18:24   #22
vikram_d's Avatar
Thanked: 940 Times
Nikhil.
Hey nikhil,
Then I guess the guy who did my brother's bike did something wrong. Will check out your bike after you post the pics. Also arent Pilot Sports from Michelins for cars?
Vikram
Old 16th September 2006, 21:09   #23
nikkibike's Avatar
Default Hi there...
vikram_d, hmmm.... I too think so!! I'll post the clear pictures of arrangements done for mounting monoshock on my Pulsar. I think that will help you guys to cross check what went wrong!! Main challenge was in correcting the 'tail-wheel arch' to suit the longer wheel base due to unicorn's swing arm!! My mechanic done it almost perfectly!!! I'll explain all the works done when I post the pics here! Untill then.... wait buddy!!!!
Reg Pilot Sport..... well I think they have it for both!! YES!! I have seen 205 (OR 215..I dun remember) Pilot sport in hydrashok's Palio!! Amazing look man!!
cheers..
Old 10th October 2006, 23:07   #24
nikkibike's Avatar
Guys, The major work - Monoshock mod is over now and juz wanted to post the pics here for everyones interest!!! checkout the snaps.... You can see K&N install also....
Will continue posting pics as the work advances.....
[IMG][img=http://img116.imageshack.us/img116/7996/nikkibyk6awu8.jpg][/IMG]
[IMG][img=http://img109.imageshack.us/img109/5269/nikkibyk7apl4.jpg][/IMG]
[IMG][img=http://img109.imageshack.us/img109/7160/nikkibyk8aid8.jpg][/IMG]
Hope this will be interesting to you all....
cheers..
Old 10th October 2006, 23:55   #25
nikkibike's Avatar
Default snaps in photobucket!!!
Old 10th October 2006, 23:56   #26
Nikhilb2008's Avatar
Thanked: 6,610 Times
cheers..
links arent working....
Old 10th October 2006, 23:56   #27
nikkibike's Avatar
Default snap in photobucket 2
Old 10th October 2006, 23:57   #28
nikkibike's Avatar
Default snap in photobucket 3
Old 11th October 2006, 08:59   #29
vikram_d's Avatar
Thanked: 940 Times
Hewy nikhil are you using 16" or 18" rear wheel? My brother has 18" and they touch the under side of the rear end even at the hardest setting of the mono-shock.
Old 11th October 2006, 10:32   #30
nikkibike's Avatar
Default hi there...
vikram_d, Mine is with Michelin's Pilot Sport 130/70/17" on stock 17" alloys!! I never faced any problems during tests even with a hefty guy as pillion!!
In your bro's case, check the orientation of mounting monoshock assy....esp the top mounting!! monoshocks should not be mounted vertically I believe...!
cheers!!
Figo Suspension - to mod or not to mod KiloAlpha Modifications & Accessories 18 13th May 2013 19:00
Need Advise - Planning for a Thailand/China Trip carboy Shifting gears 6 15th October 2008 09:52
Close 2 a Swift deal! Planning listed mods!! Advise please! nikkibike Modifications & Accessories 52 25th September 2006 08:51
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
