Old 29th May 2006, 21:26   #16
guys my bro just bought a cycle with shimano 18 gear system but when he recently gave the cycle for tuning of gears the mechanic just spoilt it all, so can u guys tell me where i can get a gear manual or something similar so that i can do it myself
cowiee is offline   Reply With Quote
Old 29th May 2006, 23:13   #17
Thanked: 97 Times
Depends on what he screwed up, if it just a small thing try this, there are two screws that need to be adjusted for the chain lead!!
See the pictures below....
Read: http://sheldonbrown.com/gears.html
Read: http://sheldonbrown.com/derailer-adjustment.html
Edmund is offline   Reply With Quote
Old 30th May 2006, 21:22   #18
thamks for the promt replt will try n figure out to solve the problem, the mechanic has adjusted the grip shift ot the front chain drives such that they have become really hard n r not changing at the marks where they r supposed to change...
Old 30th May 2006, 22:10   #19
Thanked: 97 Times
Ok, so your front sprocket gripshift has been tightened too much, eh?
Just loosen the nut [#5 in the image below] below the gripshift that adjusts the tension of the cable!!!
Old 30th May 2006, 23:04   #20
Thanked: 97 Times
While i was looking for pictures to accompany my explanation i found loads of awesome bikes, few of which i thought i'd share!!!
This one's a beast!!! 7" of rear wheel travel......whoa momma!!!!
The thing has internal transmission......check it out!!!!!
Courtsey: www.gtbicycles.com
Old 31st May 2006, 03:08   #21
Fuelled's Avatar
Wowieeee!!!
The last bike is awesome. Never seen a chain setup like that.
Too bad i won't ever ride cycles again.. Decided it the day i fell off one over the handlebars.
Fuelled is offline   Reply With Quote
Old 31st May 2006, 03:17   #22
Thanked: 97 Times
I agree, the last cycle has a crazy chaindrive setup, with internal transmission!!!!
Well it costs 5000 $, thats 2.35lac Rupees!!!!
Plus, cycling is all about getting back up and pedalling away!!! I've fallen over the bars many times over!!!
Old 31st May 2006, 15:09   #23
Fuelled's Avatar
I kno what u mean eddie.
But my handlebar to front wheel's link broke while i was trying to max the bike. Damm scary with the handle straight, and the front wheel with a will of its own ;-)
Dont trust bikes that much anymore.
Old 31st May 2006, 23:37   #24
Thanked: 97 Times
Courtsey: www.turnerbikes.com
Old 1st June 2006, 15:31   #25
just cant find words to describe these cycles...well thats an understatement..........
Old 1st June 2006, 15:33   #26
@ edmund: thanks bro after the adjustment kind of sorted out the prob but still dosent fell the same, will try to read more n fix it.will keep u posted.
Old 2nd June 2006, 07:11   #27
Rehaan's Avatar
Thanked: 25,043 Times
Prabuddhadg,
Lol.... i thought you meant like the 3 spoke mag alloys sometimes seen on bikes :P
Cowiee,
If you can be a little more specific i can try to help....
Edmund,
That moonlight trail thing sounds amazing!
Those are some pretty sweet bikes u posted...
Its insane the amount of technology that is used in these bikes!
My friend had a GT frame as well but cracked it right near the rear disc mount when jumping on his rear wheel.
Following in your footsteps i thought i would post some more pics....cept this time the bike is mine Its a `05 Specialized Hardrock sport.
When i bought it -
Then i really wasnt impressed with the fork that it came with stock, so i bought a 80-120mm Manitou Black w/ RTWD (Rapid Travel Wind Down). Which made the world of a difference to my bike.
Next i need a new crankset and bottom bracket, and am planning to take of my front deraileur to shed some weight as i never use it.
And then i want to paint my bike like this > (note the new fork PS'd on )
Heres another random pic -
Will post more pics of more interesting bikes later.
cya
R
Old 2nd June 2006, 12:26   #28
@rehaan: the front shift is really screwed.. the cable has been tightened too much... sort of loosened it but still not as original... now at some gear combinations the chai touches the shift mechanism...
@ edmund: loosening the nut did not help much
please help
Old 3rd June 2006, 09:15   #29
Rehaan's Avatar
I'm even more confused now!
Firstly, if the cable has been "tightened too much", the only thing that will happen will be that the bike wont shift to the higher gears (smaller cogs).
Unless you mean that the cable does not travel smoothly in its housing? ie there is a lot of friction for some reason?
The chain touches the shift mechanism? >> If you mean that the chain is not perfectly aligned with the cog that it is supposed to be on, and hence makes a sort of clicking noise (more than usual) this can be fixed by turning the fine tuning barrel adjuster the slightest bit to realign the deraileur.
Let me know exactly what you mean once again and we can take it from there!
cya
R
Old 3rd June 2006, 13:26   #30
the grip shift dosent reach till the place it is marked to go it stops well short of the mark but i am able use all the three gears int he frront... but on some gear combinations like 2nd on the front n third, fourth fivth on the rear i get clicking sound which is of the front cog , it happens on certain other combinations alsi, i tried to adjust the screws as told by edmund but it still isnt working well , its really frustuating me now ...PLEASE HELP
Roof-mounted luggage carrier / roofbox /cycle carrier for Aveo itwasntme Modifications & Accessories 21 4th February 2013 18:39
Thoughts on Dedicated Bus, Cycle, Autorickshaw lanes etc carjinx The Indian Car Scene 21 3rd July 2012 12:30
Cycle carrier for Palio satish_appasani Modifications & Accessories 8 13th August 2010 21:37
My new Motor Cycle Duboy Motorbikes 46 31st October 2007 00:45
Cycle Wala Scratched my car ! nitinhegde Street Experiences 42 21st September 2006 12:30
