Old 9th April 2013, 11:55   #16
sagarpadaki's Avatar
Thanked: 1,337 Times
Default re: Pulsar 180 - Unpredictably rough <-> smooth engine behaviour
You can upsize to old P200 jets or the P220 jets for your P180. I have a 8 month old P180 and believe me I am facing the same music since it was 1 month old.
But yes, redlining it a few times or long ride does open up the engine in a very good way and improves the throttle response. It may be the same harsh story the next day but instantly you get a smoother better performing engine. The downside is, P180's FE is exponentially related to throttle input. Redlining might drop the FE to an extent.
Over and above these points, do get your chain checked for slack/dryness as it is also responsible for a smooth pickup/ride. Pulsar chain needs regular attention.
I will think of up-sizing to P200 jet during next service. Power wise i am satisfied. Bike hits 110 kmph with ease.
If he existing jet is clogged wont the performance drastically come down?
Chain part- i got the bike serviced only a couple of weeks ago so now its good. Thanks for the suggestion, i will get the chain adjusted frequently.
I think all carb bike's FE is exponentially related to throttle
Old 9th April 2013, 12:02   #17
doctorque's Avatar
Thanked: 380 Times
Bought the 180dtsi V1 in 2004 an still have it (amongst others). I would be suggesting on the same line as other Pulsar owners of similar generation bikes. No matter what you do, you will not have a Unicorn'ish experience. However upgrading the engine oil, spark plugs, Air filter and keeping the clutch plates and de carboning in check can help substantially.
Petronas synthetic has worked well on my bike for many years, but cant find the same oil anymore. Its close to a lac kms now.
doctorque is offline   Reply With Quote
Old 12th April 2013, 09:12   #18
Default Re: Pulsar 180 - Unpredictably rough <-> smooth engine behaviour
An update. I switched over to shell unleaded, one day before i posted this issue. I had filled up for 3 lts . After about 100 kms , i started feeling that the smoothness has increased a bit. So was sure that shell made some difference. Went ahead and tanked up completely with shell normal petrol! Voila - the bike's character has changed by leaps and bounds. The engine is lot smoother.The jerkiness in acceleration in 2,3,4 gear is reduced quite a bit! And the engine feels good over-all. Wondering why i did not switch to shell earlier
Hopefully this smoothness will continue. Will update this thread once i complete about 1000 kms on Shell to verify if the change is indeed permanent!
Thanks for the suggestions guys!
Puzzling gear shift behaviour in my Pulsar 180 UG3 sagarpadaki Motorbikes 11 13th January 2012 22:29
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
Rough idle and exhaust note not smooth - Please help me! ece2k2 Technical Stuff 22 13th January 2008 01:59
