Old 23rd April 2013, 08:24   #1
Unhappy New Honda Activa : Airlock Problem
Hello All,
I had taken delivery of a brand new Honda Activa on March 28. First 2-3 weeks, the machine was okay. I took it back to the dealer to fit couple accessories (buzzer, grip) that got missed out during delivery. At that point there was a very minor rattle that came from the front of the machine. The dealer guys opened up some front panels and re-seated them. One of the guys while raising the throttle to check for rattling, fell on it and for few seconds the throttle was twisted to the maximum and the vehicle was almost shuddering.
After getting back home, there was a gap of 2-3 days and when I tried to start the vehicle, it wouldn't start no matter what. Neither kick-start nor electric worked. Fuel level was okay. Rolled it to the nearest mechanic and he fixed it saying it was an airlock and pretty rare in new vehicles. It ran okay that day. Now again after 2-3 days gap, problem re-occurs. Vehicle is not starting. I'm close to first service and want to raise this directly with the dealer.
What could be the problem here? Is there a permanent fix for this issue?
Thanks for your suggestions.
chakraps is offline   Reply With Quote
Old 23rd April 2013, 10:12   #2
aargee's Avatar
Thanked: 2,143 Times
Default re: New Honda Activa : Airlock Problem
Change the fuel hose connecting fuel tank to carb; happens on rare circumstance due to heat the fuel supply hose cracks up
PS - Joined in 2011 Jun & making first post in 2013???
Old 23rd April 2013, 13:07   #3
ghodlur's Avatar
Thanked: 2,438 Times
Red face re: New Honda Activa : Airlock Problem
It might have to do something with the throttle which was twisted during the accessories installation. Did you ask the dealer to check it after the installation was done?
As Aargee suggested, the fuel hose might be a culprit too. Suggest you to take it to the workshop and get the scooter checked thoroughly.
ghodlur is offline   Reply With Quote
Old 23rd April 2013, 15:43   #4
lightpower's Avatar
Thanked: 15 Times
Default Re: New Honda Activa : Airlock Problem
My experience may be similar to yours but was on TVS Wego where it suddenly stalled and shut off after riding for 20kms approx. I didn't had any other option ( Thanks to the wonderful tools provided with the scoot. I couldn't remove even a single Nut in the seat unit. Kudos to the brilliant brains who thought about it :( ) other than pushing it to a mechanic. It was finally found out that there is a breather pipe from the cylinder connecting to the air filter. It got loose from the air filter and due to this there was not sufficient vaccum created to pump the petrol to the carb ( This is the way I understood it ). Once the tube was fixed back. Problem got resolved.
Now I am counting on whether it was a design problem or an one off quality issue. I will be happy if its the 2nd one though.
lightpower is offline   Reply With Quote
Old 23rd April 2013, 19:05   #5
hellmet's Avatar
Thanked: 638 Times
I'm not sure how scoot fuel lids are designed, but on a motorcycle, you could end up with this issue if you clog up the fuel lid's spring action. The tank breathes from the lid. In your case, since the vehicle is new, it must have no lubrication which could have locked it up thereby cutting out air from the tank. I could be totally wrong, though.
hellmet is offline   Reply With Quote
Honda Activa vs Honda Dio vs TVS Wego vs Hero Maestro vs Suzuki Access 125 90BHP Motorbikes 172 12th October 2016 10:40
Jeep airlock - in fuel system cooldude1988765 Technical Stuff 21 22nd April 2015 14:33
Activa to finally Activa i: My Honda Tales appu.bhandari Motorbikes 11 9th December 2013 12:23
Problem with new Honda Activa _abhishek Motorbikes 14 29th November 2010 16:01
Airlock Problem yemshivakumar Technical Stuff 5 31st October 2007 20:38
