Old 26th April 2013, 21:52   #31
Awaiting Email Confirmation
Thanked: 4,221 Times
Default Re: Royal Enfield Thunderbird 500 : My Motorcycle Diaries
Originally Posted by rajneeesh View Post
Congrats Ravi and welcome to the club.
Thanks a lot for the wishes and nice words, rajneeesh.
It is good to see people following their hearts and not getting swayed by stereotypes when deciding to buy their rides.
I own and enjoy two products of the most-bashed brands in their respective segments!
J.Ravi is offline   Reply With Quote
Old 27th April 2013, 14:45   #32
Smile More Photographs Of My Bird
Here is a bird's-eye view of my bird:
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-0.jpg
Some more photographs.
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-1.jpg
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-2.jpg
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-3.jpg
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-4.jpg
Today, while exploring my TB500, I found out that the cables were secured with the handlebar in a different, better way as compared to my son's Classic 500 Black.
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-dsc09501.jpg
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-dsc09502.jpg
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-dsc09505.jpg
In my son's Classic 500 Black, rubber belts were used to secure the cables with the handlebar to avoid dangling.
This is the latest odometer reading of my bird:
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-dsc09504.jpg
I find the general fit and finish and handling and riding qualities of my Thunderbird 500 are far better than that of my son's 2012 Classic 500 Black.
J.Ravi is offline   (5) Thanks Reply With Quote
Old 28th April 2013, 18:05   #33
bharat.joshi's Avatar
Thanked: 36 Times
Nice to know about a T-bhpian who owns both a RE TB500 and Bullet Classic 500.
Since you have experience with both the motorcycles may I ask which one would be a better motorcycle to buy?
bharat.joshi is offline   (2) Thanks Reply With Quote
Old 29th April 2013, 02:17   #34
Thumbs up Re: Royal Enfield Thunderbird 500 : My Motorcycle Diaries
Congratulations on your TB500 sir. I am also in process of acquiring one.
Few questions though:
1. How much is the reserve capacity?
2. How is the electric starter performance? Did you face any problems?
3. How are the suspensions? I found the rear ones hard in comparison to the older TB.
4. Does the engine heats alot after riding it continuously for more than an hour? Simply asking, how is the heat dissipation?
5. You said the engine oil grade used during first service was 15W50. Is it what RE recommends or default? What would you say about other grades?
6. Does it come with twin horns / single? If yes, hows the loudness?
7. How did you find the new TB500 silencer? Would you recommend changing to the Classic ones? Or its just about sound note?
8. Is instrument cluster backlit always on?
9. During shifting from higher to lower gears, did you encounter any problems? I mean false neutrals or "kar-kar" sound?
10. Can we adjust the projector lamp throw?
11. Does the fuel cap comes out completely or is locked at a position?
and lastly did you find the ground clearance too low? Even with the pillion rider? I mean did you have any moments of scratching the bike's bottom?
Pardon me for asking this much. But, as you've already ridden it for more than 500KMs, i thought your experience will provide better answers and review. Thanks.
gold_heart007 is offline   (2) Thanks Reply With Quote
Old 29th April 2013, 08:28   #35
Thanks, bharat.joshi.
Selecting a model depends upon your requirement and budget. If you intend to tour a lot, go for Thunderbird. Otherwise, Classic.
Thank you, gold_heart007.
Advance congratulations. Here, are my responses to your queries:
Since Thunderbird 500 is electronic fuel injection programmed, there is no reserve capacity, per se, as there is no tap to turn to the reserve. The owner's handbook advises refuelling as soon as possible when the lowest bar starts blinking.
My Thunderbird 500 and my son's Classic 500 start at the very first cranking by electric start. So far, I haven't faced any problem.
The front fork is sturdier than that of Classic 500. The rear ones are adjustable gas-filled. I find them perfectly alright.
500 cc engines do generate a lot of heat; but, heat dissipation is also faster. I haven't ridden my TB500 for more than an hour due to running-in. Now that the first servicing is completed, I will ride it for longer duration and post my experience in this thread later.
It is company-recommended one. I will stick with the company-recommended one always.
Thunderbird 500 and Classic 500 have double horns, which are more than adequate. The horns are as loud as that of a premium sedan!
My TB500's silencer has a metallic insulator covering on the top. It reduces the loudness to a greater extent while retaining the Royal Enfield trade-mark thump to some extent. Changing the silencer is a personal choice. But, I have no intention of changing my TB500's silencer.
Yes.
Before the first servicing, leave alone the false neutrals, I had difficulty in getting the true neutral. By the time I get the true neutral, the signal used to turn to green! This problem was set right in the first service. Now, I get the true neutral easily. I dont get any false neutral anytime in my TB500. Yes, I get false neutrals in my son's Classic 500, but not in my TB500.
I think so.
The fuel cap comes out loose from the tank, if opened. You have to hold it while filling petrol.
My TB500 has 5 mm more ground clearance than my son's Classic 500. So far, I haven't faced any issues even with pillion.
Not at all. You are welcome to ask more questions. In fact, I asked more questions before I bought my TB500 and when my son got his Classic 500.
J.Ravi is offline   (3) Thanks Reply With Quote
Old 29th April 2013, 09:11   #36
ampere's Avatar
Thanked: 8,761 Times
This really goes on to say that, there is only one life to live! As long you can wield the sword nothing like it. All the best for many miles!
Btw, an inane question. What's the FE?
Avi, You ruined the question! It should be :
"Kitna deti hai" ? (with a serious face)
ampere is offline   (3) Thanks Reply With Quote
Old 29th April 2013, 09:23   #37
hillram's Avatar
Thanked: 961 Times
Dear Ravi..Hearty Congratulations for acquiring the TB 500. At your age, owing a RE gives inspiration for younger generation. Needless to say, my next motorcycle to acquire is a Royal Enfield.
hillram is offline   (1) Thanks Reply With Quote
Old 29th April 2013, 11:15   #38
Thanks a lot for good wishes, ampere.
"Kitna deti hai" ?
Not yet measured. I am in Bangalore and my Bird is in Chennai for the next 2 weeks! :(
Thank you very much for nice words, hillram.
Old 29th April 2013, 11:33   #39
jacs's Avatar
Thanked: 715 Times
Congrats Ravi on your TB500, that too with CL500 in the stable and an italian beauty resting under the roof. Appreciate your passion for wheels, I respect your age. TB has gone through a great transformation with the 500. Looks great.
Just couple of days back while driving along Kochi, I mistaken TB500 for Harley but then it had a black roaring exhaust. Amazing note and road presence. It didnt feel outside showroom fitment, well set with the black engine unit. Did you see any optional exhausts offered by RE?
jacs is offline   (1) Thanks Reply With Quote
Old 29th April 2013, 12:37   #40
Thanks lot for your good wishes and nice words, jacs.
No. I like the the optimum blend of Royal Enfield thump and reduced roaring noise. So, I don't intend to change the factory-fitted silencer.
Old 29th April 2013, 17:11   #41
mobike008's Avatar
Thanked: 8,037 Times
RE offers an upswept exhaust for the Bullets and its priced at Rs.2800. It marginally improves the visual appeal and also the exhuast note.
Nowhere compared to custom jobs that can be done on stock bullet.
Old 29th April 2013, 17:18   #42
jacs's Avatar
Thanked: 715 Times
I got the update that this bike belong to a timber mill guy in Tripunithra. Shall give a shot to take a pic and some details if possible. It was so good in terms of tone and looks. Did not look after-factory fitment.
jacs is offline   Reply With Quote
Old 30th April 2013, 05:12   #43
Thank you so much sir. I really appreciate your response. I'll keep bothering you with more queries per se. Until then ride safe and sound.
gold_heart007 is offline   (1) Thanks Reply With Quote
Old 1st May 2013, 14:43   #44
Smile Cramster Jacket For Me & Saddle Bag For My Bird
Today, I visited Cramster at Cunningham Road and bought Breezer jacket and Stallion saddle bag.
Royal Enfield Thunderbird 500 : My Motorcycle Diaries-dsc09524.jpg
I shall write about my experience here after using them.
Old 1st May 2013, 15:02   #45
Thanked: 297 Times
"Kitna deti hai" ? (with a serious face) [/quote]
Well I have clocked 2350 odd km to date . I have averaged between 28-30 kpl. Mix of city and expressway riding. Generraly ride at 80 kph.
rajneeesh is offline   Reply With Quote
Royal Enfield Thunderbird 500 : Brakes Failed : No Quality Control shan2129 Motorbikes 45 21st April 2016 11:24
Royal Enfield Thunderbird 500 Twinspark Ownership Report rajneeesh Motorbikes 108 5th April 2016 20:26
Royal Enfield Thunderbird 500: Lightning strikes ChiranJeev31 Motorbikes 15 26th May 2015 11:19
