Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 22nd May 2006, 08:00   #1 (permalink)
chiragh_bir's Avatar
Default Pulsar's alloys on cbz!!!
Hi guys i wanna fit pulsar's 17'' alloys on my cbz .. please tell what all mods need to be done to fit those alloys. Please help
chiragh_bir is offline   Reply With Quote
Old 23rd May 2006, 07:52   #2 (permalink)
No One To Help!!!!!!!!!!!!!!!
Old 24th May 2006, 12:55   #3 (permalink)
mail4ajo's Avatar
Pulsar alloys are meant for 17" tyres. Get a proper 18" alloys for your bike. It will look neater and wont have any problems later.
If you want your back to look raised, adjust your shocks or fix ribgs below the shock mounting. Beware, this may cause handling issues.
mail4ajo is offline   Reply With Quote
Old 24th May 2006, 15:21   #4 (permalink)
veyron1's Avatar
Hey chiragh, why don't you go in for the karizma's alloys? It would be a perfect fit, and would look much better as well; and since they are 18" alloys, you can fit your existing tyres (which means you're saving around 3G's in tyre costs alone), and the gearing won't be altered.
__________________
DAD
veyron1 is offline   Reply With Quote
Old 24th May 2006, 17:47   #5 (permalink)
i have fitted 15'' wheela and tire plz tell me what size sprocket should i go in for ...
Old 24th May 2006, 20:56   #6 (permalink)
veyron1's Avatar
By 15", I'm guessing you have gone in for the Eliminator/Avenger's tyre/rim combo. The previous combo gave your bike a total dia (or wheel height) of 63.72 cms (100/90 tyres on 18" rims). The rolling circumference was 200.18 cms. Now, the bike runs on 130/70 tyre, R15 wheel at the rear. The wheel height (Overall Diameter) has been reduced to 56.3 cms. The rolling circumference has been reduced to 176.87 cms.
The above calculations show that the gearing of the bike has been reduced. Hence, your bike should give you faster acceleration, but at the cost of top end; also, the F.E is going to decrease, since the wheel will rotate at lesser r.p.m's at the same engine r.p.m's than it used to. Although all this is theoretic, in the real world, the tyre's traction/grip is going to take away the advantage in terms of acceleration; you're not only slower, but you're getting lesser fuel efficiency as well.
In theory, this could have been overcome by reducing the number of teeth in the rear sprocket, but the CBZ doesn't have enough torque to pull off reductions of more than 2 teeth; and that's on 18" rims. Any more reduction, and the top end will be affected even more.
chiragh, be satisfied with the extra grip that you're getting. If you're determined for getting extra performance, do this; Get a K&N, add a freeflow exhaust, disconnect the TPFC, re-jet the main jet to 115 size, adjust the float, tune the carb, and reduce the rear sprocket teeth to 40. And if THIS doesn't work, NOTHING else will.
__________________
DAD
Old 24th May 2006, 22:40   #7 (permalink)
No offence dude, but ur infatuated with posing.
member is offline   Reply With Quote
Old 25th May 2006, 01:03   #8 (permalink)
buzzin_hornets's Avatar
was thinking of the samething..gonna get 18" though.. mayb karizma mags
__________________
..::VeNoM::..
buzzin_hornets is offline   Reply With Quote
Old 25th May 2006, 07:58   #9 (permalink)
is it a better idea to revert back to 18'' wheel again!!!!!
Old 1st June 2008, 02:34   #10 (permalink)
nawabnabeel's Avatar
how much do the karizma alloys cost?
nawabnabeel is offline   Reply With Quote
Thread Tools
cbz extreme honda_dude Motorbikes 8 23rd January 2007 14:57
Help with CBZ Wraith Motorbikes 18 25th December 2006 16:02
Xenons on a CBZ :) blueraven316 Motorbikes 27 12th December 2006 14:03
mobil 1 for CBZ heavy_foot Technical Stuff 0 19th October 2006 06:10
I want know about CBZ 200cc thanksnet Motorbikes 2 10th September 2006 20:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
