Old 12th May 2013, 17:27   #1
swarnava.m's Avatar
Thanked: 268 Times
Default Honda Dio - Vibrations at 60+
My 6 year old Honda Dio has developed this problem recently. Upto 60 kmph, the bike runs fine. Going above 60, slight vibrations start getting felt through the handlebars. Around 70, they are much more prominent and noticeable. Around 80, it gets quite severe and is more of a distinct shudder.
Any clues on what maybe wrong? Service will be due soon, and it will be good if I can tell the service centre noobs to look at something specifically rather than just mentioning a problem to them and getting their blank stares.
MODS, please merge this post with any existing thread if deemed appropriate. I tried searching but could not find anything about this problem.
swarnava.m is offline   Reply With Quote
Old 12th May 2013, 19:01   #2
Thanked: 1,440 Times
Default Re: Honda Dio - Vibrations at 60+
Wheel alignment gone wrong? I am not sure on what it is for two-wheelers, but for cars it is definitely one of the reasons for the steering vibrations at high speeds.
Old 12th May 2013, 19:55   #3
Collector's Avatar
Thanked: 109 Times
There is no wheel alignment on a scooter.Your problem could be wheel bearings either front or back. Or a final drive shaft bearing.
You can also check the fitment of your tyres especialy if you have had a punture recently.
Collector is offline   (1) Thanks Reply With Quote
Old 12th May 2013, 23:06   #4
smrtdvl's Avatar
Thanked: 68 Times
My dad's Activa has the same problem and the reason behind the vibrations are the tyres that are in the end of their life. Add to it the steel rims that are a bit out of shape cos of the beating it had in the past 9 years. Pls have your Dio in center stand and try rotating the front wheel, you'll be able to spot the irregularity in the rotation of your wheel.
Hope this helps.
smrtdvl is offline   (1) Thanks Reply With Quote
Old 12th May 2013, 23:58   #5
swarnava.m's Avatar
Thanked: 268 Times
I was also suspecting wheel bearings. Thanks for the pointer.
Hope this helps.
Tyres are in good shape. I doubt the rims are bad either. Anyways, thanks for the suggestion. Will try it out and report the findings.
Old 13th May 2013, 00:56   #6
Thanked: 112 Times
The steel balls in the bearings (in the fork assembly) coupled with fork dis-alignment. check if you can feel any movement when you try to move the wheel horizontally or you can sense any free-play in the handle movement without the wheel turning when you move the handle bar left/right.
I am suggesting this since you only refer to the handle bar vibrations. Hope there is nothing coming from the other parts (read engine).
null is offline   Reply With Quote
Old 13th May 2013, 04:19   #7
ArizonaJim's Avatar
Thanked: 2,105 Times
After 6 years of use it is entirely possible that the steering head bearings need to be adjusted.
These are the bearings that allow the front wheel to turn right and left and if they are loose they can cause the vibration.
These bearings are installed with a adjustable nut which can be turned to tighten them.
As was mentioned, bent rims, damaged tyres, incorrect tyre inflation, worn wheel bearings and misalignment can also cause these problems. Yes, I know it's a scooter but the mounting for the rear engine/transmission/tyre can wear, allowing the assembly to get out of alignment.
ArizonaJim is offline   Reply With Quote
Old 13th May 2013, 07:37   #8
rajeev k's Avatar
Thanked: 1,750 Times
Check tyres first for uneven wear as it can lead to unbalance and subsequent vibrations. As it vibrates after a certain speed tyre is the most likely culprit. Also check true-ness of the disc.
Once this is eliminated, check for wheel bearing slackness and handlebar column bearings.
rajeev k is offline   Reply With Quote
Old 13th May 2013, 16:29   #9
Frankly I am surprised that you are able to cross 80 on a 6 year old Honda Dio.
The vibrations can also be due to broken screws on your front assembly, the Dio having majority of its components in fiber, it does tend to make a lot of noise and vibrations.
snowmane is offline   Reply With Quote
Honda Dio - Test Ride islero Motorbikes 16 6th March 2018 12:50
Honda Activa vs Honda Dio vs TVS Wego vs Hero Maestro vs Suzuki Access 125 90BHP Motorbikes 172 12th October 2016 10:40
Poor Mileage - Honda Dio aithal303 Motorbikes 9 13th June 2007 22:25
WTS Honda Dio scooter - how to evaluate price ? nsinha Motorbikes 6 27th April 2007 14:08
what do u think about the HONDA DIO? karthik247 Sedans 5 3rd April 2005 11:41
