Old 31st May 2014, 12:41   #2416
ebonho's Avatar
Thanked: 3,182 Times
Default Re: The KTM Duke 390 Ownership Experience Thread
Originally Posted by aditya.bhardwaj View Post
Doc, the person who has the above duke said that the tire does rub the front fender. After running for around 1500 kms it becomes fine.
By the way, I am getting the Michelin pilot streets for my bike tomorrow.
Does not look like it fom the photo though. There seems to be more than a finger width clearance between the fender and the tyre.
ebonho is online now   Reply With Quote
Old 31st May 2014, 12:43   #2417
aditya.bhardwaj's Avatar
Thanked: 228 Times
Well maybe. By the way how are these tires for the city ? And what options do I have for the front. Can you help.
aditya.bhardwaj is online now   Reply With Quote
Old 31st May 2014, 12:57   #2418
ebonho's Avatar
These are good dual purpose tyres. And can run on tarmac as well as give decent purchase off road in mud, slush, snow, and gravel.
They will not be nowhere close to as good as the stock Revz on good tarmac though.
But they would be a lot better than the Revz off road and off perfect tarmac.
Plus if they too as tubeless (as they are from what's being reported), then thats a major advantage of the Revz equalized if not negated.
And a major advantage of these over the Revz (or the Metz) is that these will not allow the rims to bend or get damaged (and sometimes cause dangerous instant deflations from the damaged side). This is THE Achilles heal of the tyre profile of the Revz/Metz. Now way around it.
Old 31st May 2014, 12:58   #2419
Thanked: 228 Times
Plus if they too as tubeless then thats a major advantageof the Revz equalized if not negated.
Alright doc. But now I am more confused as to which one to go for. Michelin's or the ceat ?
Old 31st May 2014, 13:01   #2420
ebonho's Avatar
Depends on the use. If the Revz have life in them, why not keep those for the city, and get these for your trip to the mountains?
Both the Michelins together ar 10-11 K. The Revz are nearly the same.
Both the Ceats are less than half of that.
OR
Another way of looking at it, especially if you are a 390 rider.
You can get BOTH, and still be under the price of a set of new Metzelers.
Old 31st May 2014, 15:45   #2421
Thanked: 228 Times
OR
Yup that's what I plan to do. Get a set of Michelin's for the city and a set of vertigo's for touring.
Old 31st May 2014, 15:59   #2422
Urban_Nomad's Avatar
Thanked: 1,377 Times
I'm probably being paranoid here but between your home and that off road haven is the highway, mostly good roads.
Won't braking n overall stability be compromised? It seems like a dangerous proposition to me. These ceats are less than 4 times the price of Metz. If this indeed is a safe option what stops Bajaj from putting these on the bikes at the factory itself n reduce the price another 15k ....... Lure in some more junta by upping the vaue quotient.
I truly believe in using an item based on the fit for purpose concept as opposed to try and make it something it was never meant to be.
Urban_Nomad is offline   Reply With Quote
Old 31st May 2014, 16:44   #2423
ebonho's Avatar
But that's exactly the point!
I believe the Revz and the Metz are the right tyres for the bike. But the wrong country.
We just do not have the roads here. And every time a wheel goes, you are set back by around the price of a revz tyre.
Cheap right?
But when you sit and calculate the mathematics come home to you.
Tyres add about 75 paise to a rupee per km to your running cost.
Petrol is about 3 rupees a km.
Service, spares, consumables is about 40 paise to 50 paise per km.
If you hit one bad pothole at speed once every 10,000kms, that's an addition ONE RUPEE PER KM.
Its time Bajaj/KTM rethink their tyre choice.
Old 31st May 2014, 16:49   #2424
SunnyBoi's Avatar
Thanked: 2,832 Times
Cheap right?
Please correct me if I'm wrong, are you inferring that running 120/80-17 tubeless tyres on the rear of dukes can lessen the chances of bending the alloys when hitting a pothole hard?
Is it really safe to run a 120 section tyre on a rim which is meant to take 150 section tyres?
SunnyBoi is offline   Reply With Quote
Old 31st May 2014, 17:12   #2425
ebonho's Avatar
Based on the side wall height and air cushion yes.
If you've been following this discussion from the begining, this is exactl one of the concerns I had earlier. But if its been used by rally guys and that too in competition then it must mean its taken more than a few serious whacks. If there was an issue of the tyre popping out, we would have heard of it by now probably.
Old 31st May 2014, 17:20   #2426
Thanked: 1,288 Times
So no modification to the front fender needed. That's super news. Thanks buddy.
Doc, the person has removed his front mudguard and is due for some mods on it and has said it would take a week for this. Let us wait for him to reveal this.
Although the pics tells a different story, I think if the mudguard flexes during travel, it might touch the tires. He mentioned that this may not be an issue after 1.5K kms by which the tires would have lost some rubber.
@Aditya: Let us know your experience on the MPS. By the way how much mileage have you clocked on the ride?
unk9ja is offline   (1) Thanks Reply With Quote
Old 31st May 2014, 17:35   #2427
Thanked: 228 Times
I have done 8.5k kms on mine and suffered two minor and one major puncture on the rear tire.
Old 1st June 2014, 13:27   #2428
Thanked: 228 Times
Finally after lots of decision making,got the vertigo sports . Now the bike handles well in rough surfaces and bumps. Totally satisfied.
aditya.bhardwaj is online now   (2) Thanks Reply With Quote
Old 1st June 2014, 13:41   #2429
man_of_steel's Avatar
Thanked: 1,085 Times
So you have pulled the ABS fuse?
man_of_steel is offline   Reply With Quote
Old 1st June 2014, 13:43   #2430
Thanked: 228 Times
Nope. The abs works perfectly fine
aditya.bhardwaj is online now   (1) Thanks Reply With Quote
KTM Duke 390 - Accessories Thread sridhu Motorbikes 119 17th April 2018 13:02
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective sridhu Motorbikes 165 1st April 2014 07:46
KTM Duke 390 - 375cc, 45 PS, 150 kg djay99 Motorbikes 620 25th June 2013 12:45
